Being the newbie here, I have looked all over hoping someone else had the same problem I've had. This RadioShack unit worked fine for about 2 years as a closed-circuit tv monitor for a security system. Then one day it just went black. I replaced all the caps (except the largest dog on the field) and all I get is the power light flashing red when I plug it in. Upon hitting power (on board or remote) the red flashes about 6 times and turns a steady blue. The monitor flickers, displays the usual "Please Wait..." and goes black. I have check and rechecked solder joints, wiring, plugs, etc. The unit is 3 years old and is good for nothing but a paper weight right now. Any ideas??? Please?
AOC Envision L19W861 failure
Re: AOC Envision L19W861 failure
2) How long does the "please wait" stay on before going to black?--- begin sig file ---
--- end sig file --- -
What caps did you use as replacements?
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Retired Caps:
Thanks for your quick response.
1) With a working pc attached and as bright a flashlight as I could find, there does not appear to be any image on the dark screen.
2) The "Please Wait..." stays on for a mere second.Comment
PlainBill:
Thanks for asking. I bought a kit from LCDalternatives.com which claims "We only sell high quality capacitors manufactured by Panasonic, Nichicon, and Illinois". I can't tell by looking at the caps what brand they are, however. Some are gold/black some are black/silver or white color.Comment
You have two heatsinks opposite each other with a cluster of cap between them. The devices mounted on the heatsinks are diodes that output the 5V and 12V. With your black probe to ground, use your red probe and measure the voltage of the middle leg of each diode and record the voltage.Comment
The inverter transformer is PT801. Report and measure the resistance of the secondaries.--- begin sig file ---
--- end sig file ---Comment
Alexanna, yes, it's a TV. I can identify RF, Composite, S-Video, Component, HDMI, VGA and audio inputs.
Mrfixit01, there are three possibilities, a failure of the backlight circuitry, a problem with the power supply, or a failure on the signal board. Because of your source of caps I will temporarily ignore the power supply as a possible cause of the problem.
In the upper right corner of the power supply / inverter board is CN202, an 11 pin connector linking the power supply / inverter to the signal board. It appears the pins on the connector are labeled. We'll try this the quick way first. One of the pins turns the inverter on and off, another controls the brightness. The first is commonly labeled BL_ON (or something similar), the second is commonly labeled BRI. I'm interested in the behavior of the BL_ON pin. With the TV off, but (hopefully) connected to a signal source, monitor the voltage on that pin while you turn the TV on. It should start at 0 volts, jump to over 3 volts when the backlights come on, and then may, or may not drop back to 0 volts when the message vanishes. Report the behavior.
IF you are unable to identify the pin I am referring to, either list the labels on the connector or post a picture.
PlainBill, I Am always learning when I read about things posted in the forum.
Is there a possibility the source of video in may need to be manually selected?Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
My thought processes was that it would be easier to suggest checking the BL_ON line than hooking up a working signal source and stepping through the inputs. After all, some TVs require hitting 'Input', selecting an input, then hitting 'OK'.
Wow Guys!!! Thanks for all the info. I have been at work all day but will print this thread and try to follow up on it tonight or tomorrow. Super Helpful... Oh, it does have a tuner so it can be used as a TV or just a monitor. Presently it is used as a closed circuit surveillance monitor. BComment
PlainBill
reading the +12v pins: 13.08v, the +5v pins: 4.96v, N/F fluctuated between around 200 & 400 mv off and jumped to 3.96v on. Dim read 2.6v on but varied between 4.0v & 28mv off. Turning pwr on then off Dim went from 28mv to 2.6v, jumped to 3.4v & dropped quickly back to 2.6v and steadied there until pwr off then back to about 28mv. Hope this helps. Thanks.Comment
PlainBill here's what the cn902 labels are on the top right of the PB; (L-to-R) +12v, +12v, G, G, +5v, +5v, +5v, G, G, N/F, Dim.
Possible causes include bad caps, bad CCFLs or the wiring to them, a bad inverter transformer, or a bad component in the inverter protection circuitry. I see several possible approaches. The easiest appears to be a very rudimentary CCFL test. Disconnect all but one CCFL. Turn on the power. Do you get a display on the screen (it will be dimmer than normal)? Turn off the power, disconnect that CCFL and connect the next one. Turn on power. Repeat for the remaining CCFLs. If one CCFL does not produce light, that CCFL or the wiring for it is bad. If all light to the same brightness, I'd pull the power supply / inverter board and look for any signs of problems on the back side. If nothing shows up, replace all the electrolytic caps on the power supply / inverter (with the possible exception of the large electrolytic).
If you have another monitor with 4 good CCFLs with compatible connectors, try hooking up all four. If they stay on, the problem is the CCFLs in this monitor.
This appears to be a case of 'two seconds to black'. You can verify this by hooking up a source with audio and video, stepping through the inputs, and verifying that sound remains after the backlights go away. You test verified that the backlights are shutting down, they are not being shut down by the signal card.
PlainBillComment
by ngmlI am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
This indicates an error in the communication between the outdoor and the indoor unit.
The outdoor unit is fine, so the problem is the indoor PCB.
The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
Does anybody have the schematics of this board,...2 Photos02-01-2025, 12:55 PM -
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by valvashonYesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting... -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by DrDosI have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...1 Photo
- Loading...
