AOC Envision L19W861 failure
  • alexanna
    • Mar 2010
    • 1346
    #41
    Re: AOC Envision L19W861 failure
    Originally posted by mrfixit01
    Lol. It's for a friend, not mine. I'm reusing two of the old tubes. Almost finished with the switch/resolder. Note to self: don't use shrink tubing that comes with rebuild kit. It's too thick. Once the end caps are slid over it the set won't fit into the track. On the second redo I left off the shrink tubing and had no problems. Takin' a break. We'll see if this works in a bit. I just hope the two tubes I'm reusing are good. Originally there was only one that was cracked and blackened on both ends. The circuit would not light any since the one went out.
    The very first one I tried I had terrible luck; There is nothing worse than watching $10.00 bulbs break.
    No matter how hard you try mistakes are going to be made, It's what you learn from the mistakes that makes the difference.
    A suggestion I would make is to assemble everything except the thin LCD panel and let it run to make sure the CCFLs stay on.
    • mrfixit01
      • Mar 2011
      • 28
      #42
      I did as you said and cooled down, took a break, slowed down and started over. Also, I took off any shrink tubing and re-soldered all the bulbs. Then came the reassembly process. Altogether it took about 1 1/2 hours. The tape kit that I purchased was a real time saver. Anyone trying this, please get plenty of figure 8's, end caps, and the tape kit. That is really what you need. Anyway, here are a few final pictures. I am using the monitor/tv as I enter this post. Everything looks good and the screen is bright with correct coloration. Thanks for all your help. Now, I think, I could do another one without the same problems. Next project.....
      • mrfixit01
        • Mar 2011
        • 28
        #43
        Well, I tried to upload the pictures but it gave me a "security token missing" error. Tried 2 more times with same result. The monitor/tv has been running for about an hour with no smoke and no problems. All the tubes are burning fine. Tried powering off and on a few times with good results.
        • retiredcaps
          • Apr 2010
          • 9271
          #44
          The maximum size pics are 2000x2000 resolution and about 3.81MB for a jpg file. If you exceed that, you may be getting those messges? The pics are up and look good.
          Good job and congrats for not giving up.
          --- begin sig file ---
          --- end sig file ---
          • ngml
            Repair of an LG split AC system indoor unit PCB
            by ngml
            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
            This indicates an error in the communication between the outdoor and the indoor unit.
            The outdoor unit is fine, so the problem is the indoor PCB.
            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
            Does anybody have the schematics of this board,...
            02-01-2025, 12:55 PM
          • bauto601
            KDM 480W PSU upgrade succes! (opinions?)
            by bauto601
            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
            A "nice" YoungYear unit? - Badcaps
            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
            12-26-2023, 03:05 PM
          • valvashon
            Repair Success! Middle Atlantic UPS2200R-IP
            by valvashon
            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
            02-06-2024, 12:54 PM
          • CoinCoin88
            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
            by CoinCoin88
            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
            09-15-2025, 03:36 AM
          • DrDos
            Unit runs but no speaker output kenwood KR-6030
            by DrDos
            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
            09-14-2025, 09:57 PM
