AOC Envision L19W861 failure
Re: AOC Envision L19W861 failure
We need a clear focused picture on the backside of the power/inverter board. Yes, measure the resistance with power off and lcd unplugged.
The secondary inverter transformer pins are the ones "leading to" or connecting to the blue high voltage caps.--- begin sig file ---
--- end sig file ---Comment
I see now it is 801, the one to the left center side of the board. Which terminals should I test? Do I ground one probe and test all of them? Sorry for being so slow. Trying to do a million things here. I appreciate all your help, just please be patient with me. I'm just trying to help out some other people with this and not charging anything for the work.
Your previous post just showed up after I posted this one. I see it now. Will do tonight and report back here asap. Thanks.Comment
Here is a close up of the backside of the board. Measured resistance across terminals 8 & 9 displayed .45 m/ohms. I also tried to measure across the two blue caps but received no readings on any setting of my meter. However, I also found another flat panel lcd with similar ccfl plugs so I tried plugging it in to the AOC Envision. The display came up with my desktop and stayed on for several minutes.Comment
I found another lcd that had similar connectors and switched displays (even though they are different sizes) and the new display came up with a normal, if incorrectly sized, display. Reading across the power inverter showed .45 m/ohms. I could not attach an audio source with what I have available.This appears to be a case of 'two seconds to black'. You can verify this by hooking up a source with audio and video, stepping through the inputs, and verifying that sound remains after the backlights go away. You test verified that the backlights are shutting down, they are not being shut down by the signal card.
If you have another monitor with 4 good CCFLs with compatible connectors, try hooking up all four. If they stay on, the problem is the CCFLs in this monitor.
PlainBillComment
Yeah, except the other lcd is the wrong size and belongs to a currently operating system. PlainBill said earlier that it may indicate bad ccfl's. I'm waiting to hear more. Thanks.Comment
Thanks, that's what I was afraid of. I'm checking wiring now to see if something could have been shorted or cut. Next I'll have to find a CCFL supplier that doesn't cost an arm/leg or gallon of gas! Never did this sort of repair before. It's great knowing what to do now.Comment
After thinking on how the monitor was used most likley 24/7 i would think it would be something other than a wire problem.
there several CCFl suppliers that members have good luck using.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!
As Alexanna said, you have identified the problem. If I recall correcctly, CCFL Warehouse has good reviews from members here. I suggest you wait until retiredcaps chimes in to confirm that. He probably also has a link to a video on replacing the CCFLs. It is NOT a job for someone with a surplus of left hands like me.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
If someone like me,[I use to try to put the square pegs in the round holes]anyone can do it
Just take your time, be very careful with the ribbons on the panel. There are some that have a bead of silicone holding the LCD to the framework. Do not force anything.
CCFl warehouse has been very helpful to make sure I get the right parts.
There phone support is very good, and they like talking to you.Retiredcaps dose have some other vendors that are good.Whatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!
You've got that right. I spent the better part of the day just trying to figure out how to take the display apart. I finally got one side out and both tubes are blackened at each end. One is actually cracked. These look like special tubes. They are mated into a channel with fitted ends and glued together. I've sent a request to CCFL Warehouse with the measurements and am waiting for a reply, probably by Monday.As Alexanna said, you have identified the problem. If I recall correcctly, CCFL Warehouse has good reviews from members here. I suggest you wait until retiredcaps chimes in to confirm that. He probably also has a link to a video on replacing the CCFLs. It is NOT a job for someone with a surplus of left hands like me.
PlainBill
(I'm getting my second wind. Next I have a 27" Sharp tv that powers off at random times. We haven't been able to use it in a year +)Comment
Tutorial on taking apart and putting together the ccfls, which you may have already seen, is at
http://www.ccflwarehouse.com/lasotu.html--- begin sig file ---
Good, good. By summer you'll be working on 50" plasmas and repairing iPods.You've got that right. I spent the better part of the day just trying to figure out how to take the display apart. I finally got one side out and both tubes are blackened at each end. One is actually cracked. These look like special tubes. They are mated into a channel with fitted ends and glued together. I've sent a request to CCFL Warehouse with the measurements and am waiting for a reply, probably by Monday.
No, I haven't fallen off the face of the Earth, yet. I have been waiting for money to purchase the ccfl's to repair the AOC Envision tv. Just arrived today and will install them all this weekend. Only cost $43 for 4 lamps, end caps, spacers, shrink tubing, replacement tapes and shipping. Thanks for the suggestion. Cross your fingers for me! More later...Tutorial on taking apart and putting together the ccfls, which you may have already seen, is at
http://www.ccflwarehouse.com/lasotu.htmlComment
Go slow and take pictures so you can re-assemble. Do not force anything because the ccfls are fragile. Work when not tired and have decent light.--- begin sig file ---
Fragile is not the word for it. I had one assembly all together and realized that I forgot the shrink tubing. So I broke one after unsoldering and adding the shrink tubing. As I went to slide it back on, the brand new ccfl broke. I went back through the used ones and picked one that looked ok. Got it all back together - without the shrink tubing. Then I started on the other set. This time I placed the shrink tubing over the wire before soldering. Good Boy! Wrong. As I got to slide the silicone end cap back over it (they are all at a 90* angle) the end wire broke. So now I've wasted that $43 plus the original $10 for the bad caps.
I will never do this again!!!!Comment
Sorry to hear about your repair. For others reading, ccflwarehouse.com also has complete LCD Monitor Backlight Assemblies to make it an easier repair.
http://www.ccflwarehouse.com/cohaccas.html
PS. You can always sell this on ebay to recoup some of your money. The power and logic board are worth something.--- begin sig file ---
Lol. It's for a friend, not mine. I'm reusing two of the old tubes. Almost finished with the switch/resolder. Note to self: don't use shrink tubing that comes with rebuild kit. It's too thick. Once the end caps are slid over it the set won't fit into the track. On the second redo I left off the shrink tubing and had no problems. Takin' a break. We'll see if this works in a bit. I just hope the two tubes I'm reusing are good. Originally there was only one that was cracked and blackened on both ends. The circuit would not light any since the one went out.Comment
by ngmlI am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
This indicates an error in the communication between the outdoor and the indoor unit.
The outdoor unit is fine, so the problem is the indoor PCB.
The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
Does anybody have the schematics of this board,...2 Photos02-01-2025, 12:55 PM -
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by valvashonYesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting... -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by DrDosI have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...1 Photo
- Loading...
