Sony SDM-HS73 on for 2 seconds then off
  • Welchs101
    • Sep 2008
    • 979
    I have a sony SDM-HS73 which turns on for about 2 seconds and then turns off.
    I opened up the monitor and found a few "burnt" caps. See enclosed pics.
    Any idea what caused this?
    I measured the resistance of the burnt blue cap and it measured ~ 14kohm so i think this is a bad cap.
    I measured the resistance of the burnt black cap and it measured open. WHile it may be ok it probably should be replaced i know.
    I did test all 4 of the bulbs and ONE of the bulbs appears to be BAD. Could a bad bulb have caused this?
  • Welchs101
    • Sep 2008
    • 979
    Re: Sony SDM-HS73 on for 2 seconds then off
    ok....just looked at the caps again and i thought it was odd to have 3 blue caps and one black.........turns out the black cap is actually blue but has been "cooked" and turned black.
    I dont think just a bad bulb could cause this could it?
    • retiredcaps
      • Apr 2010
      • 9271
      Never seen a board where the inverter transformer is on the back side!
      I would check the all inverter transformers to make sure they are not shorted or open. They may have caused the blue caps to blow?
      --- begin sig file ---
      --- end sig file ---
      • Welchs101
        • Sep 2008
        • 979
        retiredcaps,
        Can you suggest what to measure to make sure transformers are ok?
        • Rtech
          • Jul 2010
          • 1095
          Why is it unusual ???????Its Sony !!
          • Welchs101
            • Sep 2008
            • 979
            Couple of questions to help me learn a bit.
            1) Those blue capacitors which got burned.........what are they for? From a circuit perspective........what function do they perform.
            2) The marking on those caps are "27K, 3KV". Could i replace those with some "22J, 3KV"..........i dont have any 27K,3kV but i do have an old power supply board which has some 22J, 3KV.
            • PlainBill
              • Feb 2009
              • 7034
              1. They remove any DC offset in the output voltage.
              2. Yes. Table 2 at http://wiki.xtronics.com/index.php/Capacitor_Codes shows the original were 10%; your proposed substitute are 5%.
              PlainBill
              • retiredcaps
                • Apr 2010
                • 9271
                retiredcaps,
                Normally, we would test just the secondaries, but given the extent of the damage to the blue capacitors, let's test all the pins.
                a) Number the pins on the transformers anyway you like
                b) black probe on pin 1, red on pin 2 - record ohm
                c) black probe on pin 1, red on pin 3 - record ohm
                d) black probe on pin 1, red on pin 4 - record ohm
                e) etc
                f) black probe on pin 1, red on pin last - record ohm
                g) black probe on pin 2, red on pin 3 - record ohm
                h) black probe on pin 2, red on pin 4 - record ohm
                i) etc
                j) black probe on pin 2, red on pin last - record ohm
                k) black probe on pin 3, red on pin 4 - record ohm
                l) etc
                m) finally, black probe on pin last-1, red on pin last - record ohm
                All transformers should match. Some will read 0.3 ohms which is normal.
                If you have a ring tester, it would be a lot easier!
                • Welchs101
                  • Sep 2008
                  • 979
                  Thanks for the info on what caps do .....i will have to look up some info on this.
                  Regarding % tolerance. I see the "K" and "J" for 10% and 5% respectively. But what about the 27 and the 22..........what do they mean.
                  Took a while to make the measurements on the transformers T1 adn T2.
                  I entered data into excel and i am enclosing here as a picture.
                  Is this how you wanted it measured.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Oops, missed that one was 22, the other 27. No, that won't work. They are 27 pF, 3KV caps.
                    PlainBill
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Yes. Please post measurements for T2.
                      • Welchs101
                        • Sep 2008
                        • 979
                        retired caps.........i am sorry.......i did include the T2 data i just labeled it wrong............i will correct the excel picture and repost it.
                        let me know if you dont understand the pic or if i have done something wrong and i will corrrect it.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          All the inverter transformer measurements look okay.
                          • Welchs101
                            • Sep 2008
                            • 979
                            Thanks. If you dont mind me asking what were you looking for in the data?
                            Also, the more i think about it the more i think it cant be the bulb.......or can it. Here is what i was thinking. I only found "one" bulb that was "bad". But yet two caps are bad. If only a single cap was bad and it matched the location of the bulb then i would think its the bulb but i dont.
                            What do you think?
                            Is there anything else i can check?
                            • Welchs101
                              • Sep 2008
                              • 979
                              One more question i thought of.
                              From the pics i sent out earlier you can see that there is one cap on each end of the inverter section just prior to the bulb connection that is "burned"..........but there are two caps at each end.........why is only one cap at each end burned........why not both?
                              Does anyone have any ideas?
                              • alexanna
                                • Mar 2010
                                • 1346
                                How do the “JST” style Connectors on the ccfl bulbs look? Any burning or discoloration?
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  1) Before I knew how to identify the secondary transformer pins, I used to measure every possible combination. After a while, you know that some pin combinations are 0.3 ohms and some are 1M+ ohms.
                                  2) For the secondaries, they are within 3%.
                                  3) Both transformers show the same results so that implies both are "good".
                                  • Welchs101
                                    • Sep 2008
                                    • 979
                                    i dont see any discoloration on the bulb connectors using a bright light and magnifying (sp?) glass.
                                    • Welchs101
                                      • Sep 2008
                                      • 979
                                      see enclosed pics.
                                      Between the two transformers are two devices.
                                      Device A: International rectifier F7389
                                      Device B: O2 Micro OZ960
                                      I ohmed out the F7389 based on the datasheet (see enclosed) and it looks ok.
                                      Not sure how to verify OZ960......
                                      Any thoughts?
                                      • Welchs101
                                        • Sep 2008
                                        • 979
                                        I think at this point i dont really have anything else that i know to try. So what i was thinking was replace the bulb.....which i just did...........replace the bad burnt caps, resolder the transformer leads (which has helped in projects in the past) and turn on the monitor and see what information i can get.
                                        But before i can do this i was wondering.........in an earlier post i mentioned i had "22J" caps but not "27K" caps.
                                        PlainBill,
                                        you said that i probablly could not use the "22J" caps to replace the "27K" caps........but could i use the "22J" caps just to power on the monitor and troubleshoot it a little more? WOuld that be ok you think?
                                        • mauda
                                          Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                          by mauda
                                          I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                          Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                          05-21-2023, 11:56 PM
                                        • tec3000
                                          Sony LED 65X9005A shuts down after few seconds - looking for help
                                          by tec3000
                                          Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                          I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                          03-20-2024, 07:29 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • ravi_1617
                                          Sony MBX-223 ,M971 , Shutdown after 40 seconds
                                          by ravi_1617
                                          Hi.! This Sony board turns off after 40-42 seconds.
                                          (with adaptor/battery or both)
                                          Don't turn on until 20 seconds,
                                          If I disconnect Power immediately when off,than I can turn on, than again stays on same time, aprox 40 seconds
                                          Did changed ,
                                          thermal paste, CPU.
                                          Flashed bios also.
                                          fan heatsink also clean
                                          Before turning off fan also turns on.
                                          Any points I am missing
                                          08-31-2021, 11:42 PM
                                        • odie34
                                          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                          by odie34
                                          I am a hobbyist (not a professional) so please be gentle...
                                          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                          02-18-2024, 09:11 AM
