Dell E177fpv Caps and Ribbon Cable
  • mandacat
    • Apr 2009
    • 7
    Dell E177fpv ...
    The monitor would come on but go off quickly. The two 470ufd 25vdc caps in the inverter circuit were bad, but I had to remove them to test as, in circuit, the ESR meter showed good, probably due to a parallel circuit.
    Anyway, the monitor now works great, but I could not figure out how to remove the Ribbon Cable from the LCD side. I finally wound up removing it from the video board side, which was a pain. I must have wasted an hour between trying to figure out how the remove it from the panel side and then replacing it back on the video board.
    Although I've finished the repair, I am very curious as to how to remove that cable from the panel side. It has what looks like spring clips, but I can't see how they release that cable. Any ideas ??
  • PlainBill
    • Feb 2009
    • 7034
    Re: Dell E177fpv Caps and Ribbon Cable
    Originally posted by mandacat
    Dell E177fpv ...
    Well, we can't see them either unless you post a picture!!!
    PlainBill
    • mandacat
      • Apr 2009
      • 7
      PlainBill
      Sorry about not snapping pics when I had it apart. I should have thought of that before I returned it to the owner. If it helps others, the two bad caps are CrapXon 470ufd @25vdc electrolytics closest to the transformer nearest the edge of the power supply board. They're a good distance from any of ther others and will test good - in circuit - with an ESR meter. They are not in parallel !! I replaced them with 680ufd @ 25vdc Nichicon's which were taller and left extra lead so I could bend them over slightly to fit in the same head room.
      As far as the ribbon cable, unless someone has run across that type of ribbon cable connector used in models like it (which I haven't), it probably would be hard to visualize without pictures.
      Again - sorry for the omission
      Mandacat
      • mandacat
        • Apr 2009
        • 7
        Managed to find a shot of the subject E177FPv board here in the forum. I edited it, indicating the Bad Caps.
        Thanks to "johnboy183" for posting it.
        Mandacat
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • lowpost99@gmail.com
          Need a replacement ribbon cable DELL Latitude E5470
          by lowpost99@gmail.com
          Anyone know if the ribbon cables are standard across laptops cases like in a PC, or are they proprietary to each manufacturer? I damaged the one that runs between the MB and the power / HDD / Battery Status Indicator LED Circuit Board. The Dell SKU/DPN: ADM70LED. I just need help finding a replacement. Could I possibly use a similar cable from a donor laptop?
          09-04-2024, 07:42 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • NWArkGuy
          Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
          by NWArkGuy
          Well, I will be the first to admit that I screwed up...
          In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
          I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
          I have 2 that I have found and have in my possession. ...
          10-12-2023, 10:13 PM
