Fixing a DAC-19M005 Power Supply - check my DX:
  • alexanna
    replied
    Re: Fixing a DAC-19M005 Power Supply - check my DX:
    Originally posted by kingofcoins
    Since both or ours only reads about 100 ohms, does your unit work?
    Remember this is a totally different board, I have borrowed some parts from the inverter section, But it will produce 5 volts to the connector at the logic board.
    Al.
  • kingofcoins
    replied
    Rtech...OK now based on your experience, and the fact that so many of the OEM 40T03 fets blow, I'm going to go with the 60V 43A one...its also an IRF like yours...maybe your long success is because of the maker, no ?
    Originally posted by Rtech
    Even 36A is some current rating, for a simple PSU/Inverter.I have used the IRF for the last three years, with no returns,AND these are used on other Boards as well.Its your choice of course,but 'the proof is in the eating'..as they say in some places in the world,and I have proved these are fine.Good Luck.
  • kingofcoins
    replied
    Al..yes I've that one bk'd too, been searching it, its a very long thread:
    https://www.badcaps.net/forum/showth...hlight=l1975nw
    On that F102, now that I've used another light I think we can agree its a resistor banded orange- black- orange- w/gold, value = 30k ohms. Since both or ours only reads about 100 ohms, does your unit work?
    I will be ordering the 1/2w size from Digikey: P30KBBCT-ND....its like 14 cents.
  • alexanna
    replied
    You should search L2046NV.Its a Westinghouse monitor but it uses the same P/S
    And there is some good information
    Al
  • Rtech
    replied
  • alexanna
    replied
    Has 5 bands but the 5th band is black....so I'm guessing a fuse resistor...I think its orange, black, orange w/ gold....but it could be red, green, red ...either way its way more than 100 ohms.
    What does yours measure ?
    I have a good Delta DAC-12m033 board. It has the same gray component next to Q102 it is
    Orange- black- orange-gold-black assuming my eyes are correct in the colors and its measuring 98.2 ohms.
    Al.
  • kingofcoins
    replied
    Thanks but I think I may want to stay with the 30V 40A spec...I see the
    IRF540 is rated at 100V 36A.
    However Digikey has a 60V 43A version, is this a better choice than either the 30 V or the 100V ?
    https://cdn.badcaps-static.com/pdfs/...0e3ce33550.pdf
    Also I have corrected the F200 fuse choice to a Bourne 2 amp, cause that '5' is not what's on my fuse , its a capital 'S"...and S in Bourne=2amp
    My Digikey choice is now:SF-0402S200-2CT-ND
    For your 40T03GP, an IRF540 is an excellent alternative.
  • Rtech
    replied
  • alexanna
    replied
    Well i am sorry but my reads open,
    Al.
    Did you have voltage to the large cap?
  • kingofcoins
    replied
    Originally posted by alexanna
    I scraped some of the white glue away, the board is marked F102.The component is gray in color with some different colored bans on it.
    I guess the board could be mismarked or could this be a fuse resistor?
    Al.
  • alexanna
    replied
    Thanks Al, F102 looks like a resistor in my Ver 01A! It measures about 100 ohms...but I can't tell
    the band colors, do you know the spec ?
    Did you happen to have found a schematic of this board ?
    Al.
    no on the schematic
  • kingofcoins
    replied
    look right next to the center leg of Q102
    Al
  • alexanna
    replied
    Al...
    My sentiments exactly. The parts list my be overkill, but I'll have them to re-build as needed.
    Also for that F102 fuse you asked about, would you please check my pics and point it out...can't seem to find it on my 19M005 board. Thank You !
    Al
  • kingofcoins
    replied
    Al...
    PlainBill,This monitor may be the exception to several failures ,What I have noticed is that failing capacitors cause a two second to black problem. The owner can get the monitor to work by pushing the power button multiple times and the monitor works until it goes to sleep,and the owner will repeat the power button process multiple times until it starts to work. Eventually the monitor quits altogether, and things get really fun to try to repair.
    I agree with your systematic diagnostic process, Start with why there is no 164v to the large capacitor and build from there.
    Al.
  • kingofcoins
    replied
    BILL:
    Sorry for the confusion on parts and data sheets...this P/S was an old 'learning trial' I want to re-use. If you look closely at my attached pics, you should find several mistakes...one serious one on top and some goofs on bottom. As I recall not only was there one original failed component as you point out, but then as a newbie tester I made a few sparks, and blew my VOM fuse. That's why I pulled and tested so many parts now.
    The 8 Leg SMPS controller is U 104, part DAP8A PWKJ.
    Yes I found all the links to 40T03GP, but was at a loss to find such at my favorite Digikey (they don't carry AP's and I'm not a fan of FeeBay).
  • alexanna
    replied
    Al.
  • PlainBill
    replied
    equevarae...regarding the oem Mosfet, seems to be a no-name generic make and couldn't find any links anyway to 40t03GP.
    Google brings up over 6000 hits. There are 26 auctions for them on eBay.
    Retired...regarding the SMPS controller, since I've no schematic, so am I to look into part U102 a 4 pin chip labeled L0649 817B ?
    The 817B is an optocoupler, not the SMPS controller. The SMPs controller is an 8 pin IC mounted on the bottom of the board near the SMPS transformer.
    I note that you seem to be 'shotgunning' this (throwing a bunch of parts at it, hoping that one fixes the problem). While that is a way of fixing it, it's not an efficient way. One of the truths of electronics repair is that most failures are caused by a single component. Cascading failures are not impossible, but they are rare. And they follow a logical pattern.
    Note the links in my signature. Pictures of the power supply board, top and bottom. Also, the part number of the SMPS controller.
    PlainBill
  • alexanna
    replied
    One request, could you post photos of your board.
    Some questions, when you checked the bridge rectifier did you remove it from the circuit?
    There is another fuse you did not mention, it is F102 it is by the SMPS coil close to Q102.
    Al.
    F102 is coverd with white, I guess glue?
  • kingofcoins
    replied
    Originally posted by eguevarae
    Why don't use the original one?
  • kingofcoins
    replied
    Re: Data sheet links
    Here's what I found on OEM and Digikey data sheets:
    40T03GP Mosfet OEM sheet.... Can't find
    DIGIKEY :
    https://cdn.badcaps-static.com/pdfs/...8448f1f7d5.pdf
    SBT 150 10 Shottky diode oem sheet (same make as Digikey) :
    D2SB 60A Bridge rectifier oem Sheet is at: http://kazus.info/datasheets/102915/D2SB60A.html
    DIGIKEY :
    F200 fuse ...'S'on oem no schematic available, size 0.126" L x 0.063"
    DIGIKEY SHEET:https://cdn.badcaps-static.com/pdfs/...29bd6ba8e7.pdf
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • karatzdi
    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
    by karatzdi
    I know some might say... just buy another one. Sell it as parts..!
    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
    Spent some time downloading the Service...
    06-11-2024, 08:38 AM
  • gica69
    Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
    by gica69
    I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
    Resistor shows orange range silver gold and green lines.
    Thanks in adv...
    07-21-2025, 09:49 PM
