Sony SMD-HS73
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Sony SMD-HS73
    Originally posted by torin3
    Edit: Crud, I'm out of 470uf 25V caps. I have 680uf 25V caps. Too much of step up in capacitance?
    For test only purposes, I would substitute the 680uF in. This reasoning could be totally WRONG, but
    470uF * 1.20 (+/-20%) = 564uF
    680uF * 0.8 (+/-20%) = 544uF
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Sony SMD-HS73
      That would be normal. Usually the 5V output is regulated, the 12V output floats depending on the load on the 5V supply. I'd expect the 12V output to be very close to 12V if the inverter was on, higher otherwise.
      PlainBill
      That makes sense. Arrgh, missed this reply earlier. Darn, 9 inch netbook.
      • alexanna
        • Mar 2010
        • 1346
        Re: Sony SMD-HS73
        Don't forget
        it is entirely possible to have more than one bad ccfl, to rule that out you could hook up all the ccfls from your good monitor, The ribbon cable does not need to be hooked up just make sure it's well insulated, A video source is required
        Al.
        • torin3
          • Aug 2009
          • 178
          Re: Sony SMD-HS73
          Originally posted by jetadm123
          What points on T1 and T2 did you check when you first took these readings?
          The points Retiredcaps circled. I realize they weren't exactly the same, but they were less than 30 ohms apart at about 1000 ohms.
          Edit: I'm also currently letting it warm up to see if I can adjust the brightness control.. Currently it isn't staying on long enough to access the menu.
          • torin3
            • Aug 2009
            • 178
            Re: Sony SMD-HS73
            Well, with the 680uf cap in, it doesn't light up at all. Power light is green, but the screen stays black. Putting the 470uf cap back in now.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Re: Sony SMD-HS73
              Of course, I didn't do the math the other way.
              There is a possibility that the 470uF cap is still bad. Right now, I'm out of ideas and have to head out soon.
              • torin3
                • Aug 2009
                • 178
                #27
                Re: Sony SMD-HS73
                Wel, with the 470uF cap back in, it is working the way it was before.
                I'm going to try 2 lamps at a time from another monitor, but I don't think I can get all 4 to reach.
                I'll be putting together an order for all the other caps that haven't been replaced and see if that helps.
                Have a good evening.
                • torin3
                  • Aug 2009
                  • 178
                  #28
                  Re: Sony SMD-HS73
                  Ok, I tried with 2 known good CCFL lamps at a time, and got the same behavior.
                  I can't try 4 at a time just yet because the only monitor I have available for this has all 4 plugs close together and this monitor has them on opposite sides of the inverter board.
                  I'll order the rest of the caps to make sure they are all replaced. Should get them in by Wednesday or Thursday.
                  I'll be happy to try any other tests.
                  • torin3
                    • Aug 2009
                    • 178
                    #29
                    Re: Sony SMD-HS73
                    Ok, I tried 4 known good CCFLs all at the same time.
                    Same flashing behavior.
                    Caps should arrive tomorrow.
                    • torin3
                      • Aug 2009
                      • 178
                      #30
                      Re: Sony SMD-HS73
                      Well, I guess not.
                      Looks like Christmas mail slowdown has hit already...
                      • torin3
                        • Aug 2009
                        • 178
                        #31
                        Re: Sony SMD-HS73
                        Caps arrived today. Replaced all the cans, including the surface mounted electrolytics.
                        No change in behavior.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #32
                          Re: Sony SMD-HS73
                          Can we get a clear focused close up photo (as close to 2000x2000 and without flash) of the area in red?
                          edit: What is the part number of that 20 pin IC in the red area?
                          • torin3
                            • Aug 2009
                            • 178
                            #33
                            Re: Sony SMD-HS73
                            Sorry, had to use flash, as I don't have bright house lights.
                            I think I got a clear enough photo. If not, I can try again.
                            • alexanna
                              • Mar 2010
                              • 1346
                              #34
                              Re: Sony SMD-HS73
                              Have you done any thing, as far as re soldering the inverter transformers?
                              Al.
                              Never mind missed it in an earlier post
                              • alexanna
                                • Mar 2010
                                • 1346
                                #35
                                Re: Sony SMD-HS73
                                Ok I have something for you to try.
                                Substitute one ccfl at a time again, but find a place on the back of the lcd where you can see the light of the ccfl.As you try the ccfl in each socket dose the brightness look the same on the test ccfl in each socket.
                                I am hoping this might find a area of the inverter to look at closer.
                                Al.
                                • jetadm123
                                  • 2169
                                  #36
                                  Re: Sony SMD-HS73
                                  Can you give us the part numbers for U1, U2 and U3?
                                  • fuhrer
                                    • 16
                                    #37
                                    Re: Sony SMD-HS73
                                    hi to all ze members.im new here at badcaps.umm we usually encounter that kind of problem.same brand,same model.very hard to find ze culprit. what we do is we replace the inverter with a home made one..it works..but maybe a ten percent degradation in contrast..i
                                    • torin3
                                      • Aug 2009
                                      • 178
                                      #38
                                      Re: Sony SMD-HS73
                                      Al.
                                      When I had all 4 known good CCFLs plugged in, they were all 'bare' and I didn't see any obvious light difference. I will try again.
                                      / = new line
                                      U1 = 0Z960S / 0326B1 / V31228.2
                                      U2 = 4542 / (logo)AD(Delta smbol) / W37A
                                      U3 = same as U2
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        Re: Sony SMD-HS73
                                        This is a low probability, but just for my own curiousity, can you carefully measure the voltage across the main filter capacitor (the big one) and see if you get steady DC voltage?
                                        You are looking for a steady voltage while the screen is flickering. You can use the original ccfls for this test.
                                        For this test, I like to use aligator clips with my multimeter so I can do this measurement without using my hands. It is high voltage that you will be measuring (about 165V DC).
                                        • jetadm123
                                          • 2169
                                          #40
                                          Re: Sony SMD-HS73
                                          Did you ever verify that you can see an image if you shine a flashlight on the screen? The logic board is getting 5V and the voltage regs are working, therefore, you should at least get an image.
                                          • LINCKODE
                                            Sony Bravia KDL-37S5600 inverted color and flickering
                                            by LINCKODE
                                            Hello!
                                            I have a Sony Bravia(the specific model is in the title) that is exhibiting the following behaviors:
                                            - Color inversion on the whole screen(or rather it has trouble displaying gray and black correctly)
                                            - Static-like flickering on the dark parts of an image(it will flicker between black and white on some dark parts of an image)
                                            - Bad image detail/sharpness
                                            These issues switch between each other from time to time.
                                            After consulting some online resources and the LCD TV troubleshooting guide I found on this forum, I believe I am...
                                            12-14-2022, 08:34 AM
                                          • storexxm
                                            Sony 65AG9 Oled Flickering
                                            by storexxm
                                            https://youtu.be/lIy3wANcWKA
                                            Does anyone have an idea what can cause this "flickering" i ve never seen something like this before on an oled TV
                                            Hope someone can help me :-)
                                            08-16-2023, 08:55 AM
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
                                          • Jaysean
                                            Acer VN7-591G-70RT Display Flickering
                                            by Jaysean
                                            Hello Badcaps coummunity hope you all are having a bless day,
                                            Hope I didn't post it wrong kinda new at forum site rules and tradition
                                            So I'm dealing with screen flickering problem on my laptop.
                                            I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                                            so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                                            [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                                            [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                                            10-27-2023, 10:22 AM
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
