Sony SMD-HS73
  • jetadm123
    • 2169
    #81
    Re: Sony SMD-HS73
    I could be wrong, but Q7 may not be a transistor, but some sort of voltage detector. Referring to spec sheet, pin1=5V and pin3=4.2V. Try measuring for these voltages.
    • torin3
      • Aug 2009
      • 178
      #82
      Re: Sony SMD-HS73
      Pin 1 to 2 = 4.39 VDC
      Pin 3 to 2 = 1.17VDC with lamp off, up to 5.7VDC with lamp on.
      • alexanna
        • Mar 2010
        • 1346
        #83
        Re: Sony SMD-HS73
        This inverter controller has been discused look at the last 2 posts.
        No fix was listed but an explantion of how the oz960 works.
        https://www.badcaps.net/forum/showth...ighlight=oz960
        Al.
        • jetadm123
          • 2169
          #84
          Re: Sony SMD-HS73
          Try measuring the same points using a different ground. If you get a voltage on pin 2, I either guessed wrong on what Q7 is or it may be defective.
          • torin3
            • Aug 2009
            • 178
            #85
            Re: Sony SMD-HS73
            Same readings using a ground point near CN1.
            Ground to pin 2 is 0.00VDC.
            • alexanna
              • Mar 2010
              • 1346
              #86
              Re: Sony SMD-HS73
              Off = .12V
              On = .14V
              Light on, hard to tell with my slow meter, but it looks like close to 5V.
              I think you are going to find a problem with the logic board. Could you re check the voltages on the on off pin at CN1?
              If you look at page 2 of the data sheet of the oz960 the enable or the on off voltage is 2 to 3.3volts when on.[you have to lay your head on your left shoulder to read it].
              I think I would also take a closer look at the voltage regulators on the logic board, monitor the output voltages as you power the monitor on and do it several times.
              I really don't know if this is the answer it's just something to try.
              Al
              • torin3
                • Aug 2009
                • 178
                #87
                Re: Sony SMD-HS73
                Al
                Voltages at the on/off pin are the same as before at CN1.
                Checking the Enable voltage from the oz960, I'm getting 1.17V for off, then frequent drops to about .5V.
                Should I be looking between pin 3 for U1 and the on/off location at CN1 for possible bad components? Or should I consider getting a replacement oz960?
                Also, the two voltage regulators on the logic board. 3.3V seems to be pretty close to that. When on, a steady 3.34V when off steady 3.37V. The 1.8V chips bounces between 1.09V and 1.24V when left on. When turned off, it goes immediately to 2.35V and gradually works it way up to 2.48V and stays steady there. When turned on it goes to 1.17V for a second or two before bouncing between the 1.09V and the 1.24V.
                • alexanna
                  • Mar 2010
                  • 1346
                  #88
                  Re: Sony SMD-HS73
                  The 1.8 volt regulator may be a problem,
                  I am going to ask for help on it, let's see what the other guys say
                  Al
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #89
                    Re: Sony SMD-HS73
                    Also, the two voltage regulators on the logic board.The 1.8V chips bounces between 1.09V and 1.24V when left on. When turned off, it goes immediately to 2.35V and gradually works it way up to 2.48V and stays steady there. When turned on it goes to 1.17V for a second or two before bouncing between the 1.09V and the 1.24V.
                    I'm a bit confused and it is almost 1am in the morning, but back in post #9, the regulators were identified as 1086D25 a 2.5V regulator and BA033 a 3.3V regulator. Where did 1.8 come from?
                    --- begin sig file ---
                    --- end sig file ---
                    • torin3
                      • Aug 2009
                      • 178
                      #90
                      Re: Sony SMD-HS73
                      I was up late and tired too and reading the wrong leg on the regulator?
                      • torin3
                        • Aug 2009
                        • 178
                        #91
                        Re: Sony SMD-HS73
                        Ok, I had a chance to remeasure this morning. I was reading the wrong leg. Between ground and Vout I'm get about (If I'm remembering right, I'll check again when I get home) about 2.63V. It is rock steady when on or off or the lamp coming on or off.
                        Checking the datasheet, if my memory is correct, the voltage looks a little high.
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Re: Sony SMD-HS73
                          It is. The LDO regulators are usually specified as +- 1%. It's either the regulator or your meter.
                          PlainBill
                          • torin3
                            • Aug 2009
                            • 178
                            #93
                            Re: Sony SMD-HS73
                            PlainBill
                            I wouldn't be surpised at all if it was my meter. I've got 2 cheapie meters, and I'll try with both of them when I get back home today. On the presumption that even if both meters are inaccurate, they aren't likely to be inaccurate in exactly the same way and amount of error.
                            I should probably get a better multimeter for when I need accuracy rather than continuity checks.
                            But it will have to wait until after I get my ESR meter kit.
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #94
                              Re: Sony SMD-HS73
                              Back in post #9, you measured the 5V rail as 5.05V DC stable and you measured the regulator as 2.48V
                              PlainBill says that the 5V rail is usually regulated.
                              So 1.01 (1%) x 5.0 = 5.05V.
                              1.01 (1%) x 2.5 = 2.525V
                              0.99 (-1%) x2.5 = 2.475V
                              So I think the multimeter that you used in post #9 is okay?
                              Something has changed since then to cause this higher voltage reading (17V and now 2.63V). We had one case a few days back where the battery in the multimeter was low and causing funny readings. You may want to try a fresh battery?
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Re: Sony SMD-HS73
                                A correction, retiredcaps. LDO regulators, such as the AS1117-3.3, etc are spec'd +-1%. The 5V output is regulated, but the actual voltage is determined by a number of components added by the monitor manufacturer.
                                I'd expect it to be within 5%, but is often deliberately set high to compensate for drop through the conductors. 5.1V is very common.
                                PlainBill
                                • jetadm123
                                  • 2169
                                  #96
                                  Re: Sony SMD-HS73
                                  What's been puzzling me is that when you measure the same voltage(s) a second time you seem to get something different each time. Like the 12V output going to 17V, the difference in the 2.5V voltage regulator output, the "bouncing" voltage feeding the CCFL controller, etc. Very confusing.
                                  • torin3
                                    • Aug 2009
                                    • 178
                                    #97
                                    Re: Sony SMD-HS73
                                    Well, either I didn't remember correctly, or like mentioned, I might have a low battery, and it might be giving me screwy readings.
                                    2.5V regulator is at 2.49V on both meters right now. 3.3V regulator is 3.36VDC.
                                    And just to verify, I checked the 12V rail again. Up in the 17V range when peaking.
                                    Oh, and while it is somewhat frustrating, and I probably should be up so late before staring to work on this particular monitor, I am finding this process fascinating, and I'm learing quite a bit. Thanks again for all the help.
                                    • alexanna
                                      • Mar 2010
                                      • 1346
                                      #98
                                      Re: Sony SMD-HS73
                                      Should I be looking between pin 3 for U1 and the on/off location at CN1 for possible bad components? .
                                      What is the voltage on the enable pin #3 of oz960 when the back lights are on?
                                      Al.
                                      • torin3
                                        • Aug 2009
                                        • 178
                                        #99
                                        Re: Sony SMD-HS73
                                        Al.
                                        It is hard to say. I didn't get a 1 to 1 correlation for the .5V range for when the lamps were on. The voltage drop happened more often than the lamps came on. It might be that it was trying to turn them on more often than they acutally turned on. But the lights are on and then back off again so quickly that my meter can't say for certain exactly what the voltage was when they were on. There also may be spikes of more than the 1.17V, but if so they happened so quickly it didn't register on the meter.
                                        But the 1.17V reading was only when the light was off.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #100
                                          Re: Sony SMD-HS73
                                          Just out of curiousity, what is the part number for IC2 on the backside of the power board?
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • LINCKODE
                                            Sony Bravia KDL-37S5600 inverted color and flickering
                                            by LINCKODE
                                            Hello!
                                            I have a Sony Bravia(the specific model is in the title) that is exhibiting the following behaviors:
                                            - Color inversion on the whole screen(or rather it has trouble displaying gray and black correctly)
                                            - Static-like flickering on the dark parts of an image(it will flicker between black and white on some dark parts of an image)
                                            - Bad image detail/sharpness
                                            These issues switch between each other from time to time.
                                            After consulting some online resources and the LCD TV troubleshooting guide I found on this forum, I believe I am...
                                            12-14-2022, 08:34 AM
                                          • reessi
                                            ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                            by reessi
                                            The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                            They are black on the right and gradually fade to nothing on the far left.
                                            They start either after 5 mins or up to 2 hours after so annoying for testing.
                                            They flicker continuously very fast! With a slight pause milli-second every second.
                                            Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                            I tested each half by removing the first the left flex from...
                                            06-03-2025, 09:58 AM
                                          • storexxm
                                            Sony 65AG9 Oled Flickering
                                            by storexxm
                                            https://youtu.be/lIy3wANcWKA
                                            Does anyone have an idea what can cause this "flickering" i ve never seen something like this before on an oled TV
                                            Hope someone can help me :-)
                                            08-16-2023, 08:55 AM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
