Sceptre x20g-NagaIII (x20wc-gamer) issues.
  • Flababa
    • Oct 2010
    • 41
    Re: Sceptre x20g-NagaIII (x20wc-gamer) issues.
    Came up with P/N T491A226J006AT for the original unit. Sounds right: http://www.mouser.com/Passive-Compon...=A226J&FS=True
    Just not available. :s Looking for alternatives.
    http://www.mouser.com/ProductDetail/...hbdTe7YC6BE%3d
    and
    http://search.digikey.com/scripts/Dk...=478-3865-1-ND Is all I could come up with.
    Thoughts?
    • Flababa
      • Oct 2010
      • 41
      http://cgi.ebay.com/ws/eBayISAPI.dll...ht_2377wt_1085
      Sometimes I love ebay.
      Parts ordered. I'll let you know how it works out. :o
      • Flababa
        • Oct 2010
        • 41
        After a long vacation (sorta), I've installed the parts. Bam, working perfectly for the last two days! Thanks for your help all!
        • Moose
          • Aug 2013
          First step, there are two connectors on the lower right corner of the picture of the back of the power supply / inverter card. Note that some pins are labeled Gnd, 5V, 12V. With DMM measure the voltage from GND to 5V (should be 5 volts) and from Gnd to 12V (should be 12 volts). If either of those are missing, it's most likely a problem with the power supply, disconnect the logic card to be sure (turn off power before disconnecting it!!!).
          PlainBill
          I've got a problem with my screen going blank after a few seconds - backlight just shutting off, seems like. I went to take measurements but don't understand the bolded part here - you can't get power to the power supply card without the logic card being plugged in.
          There are three bulging caps (of 8) on the power card so I suspect this is my problem, but the voltages are ~12.3, ~5.15, and ~5.15 (both before and after the [what I assume is the] backlight cuts out). If the caps were the problem, wouldn't these voltages not be correct? Or could the logic board be cutting the load when there's a voltage drop?
          I should also note that there's a slight hissing that lasts for 1-3 seconds whenever I turn the monitor on - anyone know what this could be from? Nothing smells especially odd.
          To any one else reading this thread for info, I got the same values as in post 3, though the regulator brands/model numbers are different.
          • Moose
            • Aug 2013
            (Apologies if it is in bad form to revive this thread with a tangential question ... is there no edit button for new members?)
              You have to replace at the bulging caps first before going further, otherwise you will be chasing your tail. The hissing sound may becoming from bad solder connections at the end of the lamp.
              • japlytic
                • Oct 2005
                • 2086
                I see some Samxon GF Series on the power board - a series known to go bad.
                • Verlengsnoer
                  Bios splash/logo change
                  by Verlengsnoer
                  at firs, i hope this is the right place to post my question.
                  Im looking for a tool to change the bios logo.
                  everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                  i know that HP has a build in option to change the splash logo.
                  but i want to change the manufacturer logo to an own logo.
                  I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                  10-28-2022, 09:52 AM
                • coasterghost
                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                  by coasterghost
                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                  System Hardware:
                  Processor: AMD Ryzen 7 PRO 5850U
                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                  09-08-2025, 10:46 PM
                • ngml
                  Repair of an LG split AC system indoor unit PCB
                  by ngml
                  I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                  This indicates an error in the communication between the outdoor and the indoor unit.
                  The outdoor unit is fine, so the problem is the indoor PCB.
                  The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                  I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                  Does anybody have the schematics of this board,...
                  02-01-2025, 12:55 PM
                • carrzkiss
                  Cyberpower cps1500avr not charging batteries
                  by carrzkiss
                  Hello, all.
                  Cyberpower Battery Backup Unit.
                  I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                  When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                  In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                  Checking the voltage, it was down to 22v.
                  I quickly removed everything...
                  06-15-2024, 02:10 PM
                • Echoo
                  Fujitsu D757 sff desktop pc bios logo reset
                  by Echoo
                  Fujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?
                  11-25-2024, 01:54 AM
