Sceptre x20g-NagaIII (x20wc-gamer) issues.
  • Flababa
    • Oct 2010
    • 41
    I've been trying to find information as to what may be wrong with this thing, but I haven't found anything that fits the symptoms I'm experiencing.
    Normal operation:
    • Connect DVI / D-sub cable to PC.
    • Plug display power in.
    • Press power button.
    • Sceptre logo appears, and fades out.
    • Sceptre logo on front of unit blinks red.
    • Display detects PC / Laptop / Etc, picture is displayed.
    • Sceptre logo on front of unit turns blue.
    Current operation:
    • Sceptre logo on the front of the unit turns red- Solid. No blinking.
    • No picture. No menus. Unit will not turn off by pressing the power button.
    I was using the monitor one day, then suddenly red lines from top to bottom on the center of the screen (but not spanning the entire screen) showed up, and then the display went black. No backlight, nothing.
    I pulled the unit apart, and can't for the life of me find something obviously (visually) wrong. I've searched for similar symptoms, but haven't found anything at all. Attached are photos of the power and video board from the unit. I'm an amateur at best when it comes to repair theory. I can solder and follow instructions quite well, but that's about where it ends.
    The capacitors look to be intact. No burn marks around any of the components. Attached is a few photos I took.
    Anyone have any ideas for me? This monitor has a twin on my desk that's getting lonely. =/
    Thanks in advance for any help you can offer!
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sceptre x20g-NagaIII (x20wc-gamer) issues.
    First step, there are two connectors on the lower right corner of the picture of the back of the power supply / inverter card. Note that some pins are labeled Gnd, 5V, 12V. With DMM measure the voltage from GND to 5V (should be 5 volts) and from Gnd to 12V (should be 12 volts). If either of those are missing, it's most likely a problem with the power supply, disconnect the logic card to be sure (turn off power before disconnecting it!!!).
    Second step, the logic card. There are several voltage regulators, U7, U9, U11, and U12. In the 'normal' orientation the tab is at the top, the three legs are at the bottom. The legs are numbered from 1 to 3 from left to right. Use one of the mounting tabs of CN2 as ground. Measure and report the voltage on each leg of U7, U9, U11, and U12. Also report the part number of each IC.
    PlainBill
    • Flababa
      • Oct 2010
      • 41
      Tested the 5v and 12v lines. All showing normal.
      Voltage Regulators:
      U7 - AXH 548
      • 0.0
      • 1.8
      • 3.8
      U9 - ABF 512
      • 0.0
      • 3.3
      • 5.1
      U11 - ABF 512
      • 0.0
      • 3.3
      • 5.1
      U12 - AKE 407
      • 0.0
      • 2.5
      • 4.5
      Hopefully I reported this properly. Let me know if not, and I'll fix it. If I'm going to learn as I go, I wanna do it right.
      • jetadm123
        • 2169
        Voltage Regulators:
        U7 - AXH 548
        • 0.0
        • 1.8
        • 3.8
        U9 - ABF 512
        • 0.0
        • 3.3
        • 5.1
        U11 - ABF 512
        • 0.0
        • 3.3
        • 5.1
        U12 - AKE 407
        • 0.0
        • 2.5
        • 4.5
        Typically, the outputs are 1.8V or 3.3V. U7,9 and 11 look good. U12 output of 2.5V seems low or high, since I'm really not sure what type of regulator the AKE 407 is. The part number AKE 407: is there any other number like 18 or 33 stamped on it?
        • PlainBill
          • Feb 2009
          • 7034
          Tentatively, I would say those voltages are correct. 3.3, 2.5, and 1.8 volts are all standard voltages for processors; 2.5 is rarer, but is (I believe) used for the memory interface.
          What is slightly interesting is the input voltages seem to be slightly 'off' from what I would expect.
          PlainBill
          • Flababa
            • Oct 2010
            • 41
            Yeah, there isn't any other information printed on the component itself. Here's a slightly better photo of it, but I don't see it being of much help.
            This is probably the best I can do with my little camera. =/
            • Flababa
              • Oct 2010
              • 41
              It seems that here in this thread, they have the same board, but the printing on U12 doesn't seem to match up. I can't quite make out the numbers:
              https://www.badcaps.net/forum/showpo...18&postcount=1
              Then here, the wire on the bottom crossing that connection...is going to a different spot on my board:
              https://www.badcaps.net/forum/showpo...21&postcount=3
              It appears to be the same board that I'm using.
              I can't make any sense of it really. Anyone? haha
              • PlainBill
                • Feb 2009
                • 7034
                The voltage regulators appear to be working. The red lines could indicate a failure of the processor on the logic card. While it is possible it is another component on the board, in my opinion it is unlikely . The best approach would be to find a replacement logic card.
                PlainBill
                • Flababa
                  • Oct 2010
                  • 41
                  I was afraid you'd say that.
                  Guess I'll have to hunt one down. (unlikely I'll find one. haha)
                  Thanks for all your help!
                  • jetadm123
                    • 2169
                    Since you have only one electrolytic cap (C117) on the logic card, I would go ahead and change it. I've had weird problems caused by dried out caps on the logic card. Since the size of the logic card is generally much smaller/compact than the power board, manufacturers tend to use physically smaller size caps. The Gateway monitor I worked on had several 220uf caps that were super small in size. Because of their small size, they dried out very quicky. At this point, you've got nothing to lose.
                    • Flababa
                      • Oct 2010
                      • 41
                      Hrm. While removing the capacitor from the logic board, I think I found a burned component. Not sure how I missed it before.
                      C118 on the board. One of the orange / yellow components. Top-right of both photos, right next to U11.
                      Think that could have something to do with it? I don't even know what that thing is! haha
                      Text reads (far as I can tell):
                      A226J
                      93AF3
                      • jetadm123
                        • 2169
                        C118 does look a little discolored, but it's hard to tell because of the lighting. It's a cap because of the "C" in C118. These type of caps seldom fail on their own and if it is burned out, it might have been caused by another component shorting out.
                        As for the A226J. Not sure what the "A" stands for, but
                        226J = 22000000pf = 22,000nf = 22uf, where "J" = +/- 5% tolerance
                        • Flababa
                          • Oct 2010
                          • 41
                          Was actually just taking photos. This is after cleaning it off to make sure it wasn't just 'dirty' from whatever.
                          It's actually a sunny day today, so I can follow the guide. haha
                          The only writing on it I could make out is what I posted above:
                          A226J
                          93AF3
                          Two lines. The A is superscript it seems, it that matters.
                          http://i.imgur.com/p0z0x.jpg isn't resized.
                          • jetadm123
                            • 2169
                            See post #12 for cap value. Try tracing the path of C118 to see what each end of the cap is connected to, maybe D25, D26, U11?
                            • Flababa
                              • Oct 2010
                              • 41
                              Yeah, from what I gather the A relates to the physical size of the unit. (http://www.scienceprog.com/few-words...nt-components/)
                              Now, how does one obtain the rated voltage from something like this?
                              Far as tracing where it goes: It seems to eventually run under the board? (maybe?) It's hard to tell since I have limited experience doing this..but just at a glance it seems to contact D25, D26, U11, then shoots down to several others and possibly the back via the pins above it? Could connect with C119, R110 etc.
                              Think it would be easier to replace both that, and the capacitor I've already removed to see if it works / blows out again? I did use the display a lot. At least 8 hours a day, seven days a week for ~3-4 years. Give or take. (home 'office')
                              I only ask because we're going well beyond my troubleshooting experience at this point. I'm not above having my hand held, but I won't expect it, is what I mean.
                              • jetadm123
                                • 2169
                                Since the logic card seems to run off of 5 volts, my guess at a voltage for the cap would be at least 10V or greater. What was the voltage of C117 rated at? You can probably use the voltage of C117 as a guide.
                                • Flababa
                                  • Oct 2010
                                  • 41
                                  C81 - 3.3
                                  C18 - 5.1
                                  C71 - 1.8
                                  C92 - 3.3
                                  C72 - 5.1
                                  C118 - 5.0 - Burned
                                  C107 - 2.5
                                  That's what I got from each individual of that type. I'm not sure how I'm supposed to rate these. Meaning, how much voltage over what they're using SHOULD they be able to handle?
                                  Also, any idea as to where I could order this part without buying 100 of them? :s
                                  • jetadm123
                                    • 2169
                                    C81 - 3.3
                                    C18 - 5.1
                                    C71 - 1.8
                                    C92 - 3.3
                                    C72 - 5.1
                                    C118 - 5.0 - Burned
                                    C107 - 2.5
                                    What was C117 rated at? 10 or 16V? I would use that as the benchmark for voltage selection and would only replace C117 and C118, since the logic board may have more serious problems as suggested in post #12. If you're in the USA try digikey.com and select USPS shipping for the lowest ship rate.
                                    • Flababa
                                      • Oct 2010
                                      • 41
                                      I must be blind. Looking over and over expecting to find a surface mount component labeled C117.
                                      16v 470uf. haha
                                      • Flababa
                                        • Oct 2010
                                        • 41
                                        Hrm. I can't seem to find either on Digikey. =/
                                        I think I found C117, but C118 is being problematic. I can't find anything matching the specs from this thread. 10v or 16v, I can only find one rated with 5% tolerance. Checked Digikey to find nothing. Mouser is closer, but just not there.
                                        • Verlengsnoer
                                          Bios splash/logo change
                                          by Verlengsnoer
                                          at firs, i hope this is the right place to post my question.
                                          Im looking for a tool to change the bios logo.
                                          everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                                          i know that HP has a build in option to change the splash logo.
                                          but i want to change the manufacturer logo to an own logo.
                                          I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                                          10-28-2022, 09:52 AM
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • ngml
                                          Repair of an LG split AC system indoor unit PCB
                                          by ngml
                                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                          This indicates an error in the communication between the outdoor and the indoor unit.
                                          The outdoor unit is fine, so the problem is the indoor PCB.
                                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                          Does anybody have the schematics of this board,...
                                          02-01-2025, 12:55 PM
                                        • carrzkiss
                                          Cyberpower cps1500avr not charging batteries
                                          by carrzkiss
                                          Hello, all.
                                          Cyberpower Battery Backup Unit.
                                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                                          Checking the voltage, it was down to 22v.
                                          I quickly removed everything...
                                          06-15-2024, 02:10 PM
                                        • Echoo
                                          Fujitsu D757 sff desktop pc bios logo reset
                                          by Echoo
                                          Fujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?
                                          11-25-2024, 01:54 AM
