Backlight constantly On after repair
  • kingzzz
    • Oct 2010
    • 5
    Hi guys, My Benq Fp91g had the backlight problem. Ordered a repair kit from Ebay and replaced all 4 c5707 transistors and the 3A picofuse. One of the transistors was shorted on the pins so I guess that was the problem. Now it works but the backlight is always on even when I press the button to turn off the monitor and the LED indicator shows it is off. If leave the monitor alone and the PC goes to sleep, the same thing happens with the backlight being fully on when the LED indicator is orange. There appears to be no problems during normal usage ( only tested for about 30mins though) but the monitor seems to get quite warm, I cant remember if this was normal or not.
    Any ideas on what could be causing the backlight to be constantly on?
  • kingzzz
    • Oct 2010
    • 5
    Re: Backlight constantly On after repair
    ha, looks like i didnt take enough care when testing, It appears one of the fqu11p06 fets was shorted, replaced both and now monitor is all good. When taking out of the the fets one of the tracks got lifted. Had to ghetto wire it directly to the pad the trace it was connecting to. Hopefully nothing blows up in my face . This was the middle leg of the fu024n mosfet
    • Krankshaft
      • Jan 2007
      • 2328
      No worries I've had a few Benq boards with a surface mount FET that did the same thing. When there was over current and a C5707 transistor shorted the heat incinerated one of the traces on the On / Off FET.
      Extending the leads and soldering directly to a trace or jumper wiring is fine.
      If it's a through hole component and you solder directly to a thin trace instead of using a stranded jumper wire just make sure that you don't bend the component after soldering since the tiny trace is more likely to rip off due to less surface area.
      • kingzzz
        • Oct 2010
        • 5
        Yea it was a through hole component. I pretty much just bent the leg and it happened to reach the next component directly. So the track was bypassed altogether. Monitor is not running so warm now either so looks to be a good success.
        • retiredcaps
          • Apr 2010
          • 9271
          Benq boards that require a c5707 replacement also *must* have their inverter transformer pins all resoldered. Otherwise, you may be ordering another repair kit in the near future,
          --- begin sig file ---
          --- end sig file ---
          • kingzzz
            • Oct 2010
            • 5
            Haha speak of the devil, the monitor just died again today, and have ordered another kit, good thing they arent expensive. Live and learn I guess.
            regarding re soldering. Just heat the solder up/apply a bit more to all the pins and that's it?
            • jetadm123
              • 2169
              Since the manufacturer probably used lead free solder, ideally, you should remove the old solder using desoldering braid or a solder sucker bulb and reapply fresh lead/tin solder.
              • Wizard
                • Mar 2008
                • 2296
                The flux that is used with the no-lead solder is so ineffective, I prefer in some situations to remove these transformer and lightly scrape the pins with razor knife.
                Cheers, Wizard
                • kingzzz
                  • Oct 2010
                  • 5
                  have replaced all 4 c5707s and resoldered the transformers, monitor is back to life. We'll see how long it lasts this time.
                  this time however none of the replaced c5707s had any shorts between the pins so i wasnt sure which one was actually broken. if there a good way to test?
                  • Toasty
                    • Jul 2007
                    • 4171
                    There is a thread on the forums about MOSFET testing, but I can never find it when I need it.
                    Google: mosfet test procedure
                    The first few results are good enough. You're going to use your DMM on Diode test to switch the MOSFET on and off. Hopefully yours produces enough volts to cause the device to work. If you have a 2nd meter, test them against each other to see what volts are produced when in Diode test position.
                    The 4QD-TEC page explains this. The ezine page does not, but has you check the protection diode if it exists in the C5707.
                    Toast
                    veritas odium parit
                    • DanPoka
                      by DanPoka
                      02-15-2025, 05:05 AM
                    • Zilicon
                      NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                      by Zilicon
                      Greetings everyone.
                      Please I need help with the above monitor.
                      Below is the summary of what happened and what I have done:
                      The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                      The backlight driver IC is 0b3350cp.
                      I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                      11-07-2023, 09:12 AM
                      by momaka
                      03-15-2023, 10:17 PM
                    • turmix
                      AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                      by turmix
                      Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                      The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                      At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                      During another reassembly, I made a mistake, and...
                      01-29-2024, 03:48 AM
                    • Chiro
                      DIGMA PRO Art M Monitor 5K IPS 60hz only backlight
                      by Chiro
                      The monitor has no visible external damage and has not been dropped. Currently, the backlight is on, but no image is displayed. I have replaced the power and HDMI cables, and connected it to my laptop (the graphics card detects the monitor, but no image appears). The service menu is also unresponsive. Could anyone share insights on troubleshooting or repair options for this issue?
                      07-06-2025, 02:21 PM
