AOC 2217v goes blank after power on.
+ More Options
Posts
  • Heliotropic
    • Oct 2010
    • 14
    My problem is the same as ones I've seen posted here and on the net.
    When I turn on my monitor I can see my desktop display perfectly for about 3-5 seconds, but then goes blank. It is not going into "sleep" mode. I can hold down the power button to shut down the monitor. When I power it back up, I get the same result everytime...desktop display for a few seconds, then black.
    I've tried the suggestions I've seen for similar problems people have posted, but I'm still having no luck.
    Here's what I've done so far:
    Replaced all 10 of the capacitors (c802, c803, c905, c908, c922,c915, c917, c918, c939, c940) though none of them looked bad by bulging or leaking.
    Replaced diode (d906) because it had a little discoloration on the circuit board around it.
    Desoldered and scraped clean the coils (L903 and L904).
    Reheated quite a few other solder points on the board incase of cracked or cold solder joint.
    If possible I'd like to avoid troubleshooting (and buying) every little component on this board by trial and error, so I'm hoping someone can help me narrow it down.
    Here are the pictures of the circuit board and schematics.
    http://i746.photobucket.com/albums/x...rcuitboard.jpg
    http://i746.photobucket.com/albums/x...schematic1.jpg
    http://i746.photobucket.com/albums/x...schematic2.jpg
    Thanks for any help.
  • PlainBill
    • Feb 2009
    • 7034
    Re: AOC 2217v goes blank after power on.
    1. Note the links in my signature on attaching pictures and do that. I dont go to other sites for pictures - I've been burned once.
    2. Thanks for supplying schematics. That will earn extra help AFTER you attach the .jpgs.
    3. What brand and series capacitors did you use.
    4. Even though in your case it's 3-5 seconds, these symptoms are often referred to as 'two seconds to black'.
    PlainBill
    • Heliotropic
      • Oct 2010
      • 14
      https://www.badcaps.net/forum/attach...1&d=1286574554
      The brand of capacitors are Panisonic and all but 3 are FM series. The c905 is a TS-HB, c939 and c940 are EB series. I didn't realize they were different when I ordered them, and with my very limited knowledge of electronics, I probably wouldn't have even thought to check. Is that going to be a problem?
      It probably is closer to 2 seconds before it goes blank, I didn't use a stop watch and figured the reader would get the general idea.
      Thanks for the help.
      • PlainBill
        • Feb 2009
        • 7034
        Using general purpose caps in the 12V supply or the inverter WILL cause the two seconds to black problem. Unfortunately, the schematic is a little too small to identify which ones are the non-FM series. A link to the schematic would be a big help.
        What is the part number of the Inverter Controller (the 16 pin IC?)
        PlainBill
        • Heliotropic
          • Oct 2010
          • 14
          PlainBill
          The pictures I linked in my first post display larger than the ones shown on the second post...but you won't visit external links...so I'm a little suprised you're requesting a link now.
          Regardless, the only place I was able to find schematics for this monitor was at elektrotanya.com (download link here). The site isn't in english but "Get Manual" link is. Also, the manual itself is in Japanese but the schematics are legible enough as you can see from the pictures. The .doc file schematics are much sharper and easy to read.
          The part number for the IC is 715G2510-2.
          Hope that helps.
          Thanks again.
          • PlainBill
            • Feb 2009
            • 7034
            Hope that helps.
            Thanks again.
            Read this FAQ for the reason for uploading pictures to this site, not photobucket, etc. Also, I had one case where pictures uploaded to a third party site were unreadable by a .jpg viewer. It made me wonder what had been inserted in them - and why.
            EB series are not acceptable for C939, C940. They require Panasonic FM, FC, or other equivalent low ESR caps.
            The part number 715G2510-2 is not a legitimate IC number. Perhaps if you read it off the IC or attached a good picture?
            As far as the 'two seconds to black' issue, I'm going to recommend two tests. First, accurately measure the resistance of the secondaries of the inverter transformers. Shorted turns in a transformer will reduce the output voltage and cause this problem. The resistances should match to within 3%.
            Next, try substituting a known good CCFL for each of the existing ones, 'walking it through' each of the 4 output connectors to see if one of the existing CCFLs is bad.
            PlainBill
            • Heliotropic
              • Oct 2010
              • 14
              PlainBill
              So do I need to replace C939 and C940 EB series capacitors first, before I go any further? Or will they work long enough to find the cause of the "black" issue?
              Does TL494IDR SOIC-16 sound more like the IC number you're asking for?
              I'll try checking the transformers. Im assuming they cant be tested on the board and need to be pulled for testing, correct?
              • smason
                • 1652
                Perhaps, but they're still unreadable.
                Can you not post pictures of the actual boards?
                • PlainBill
                  • Feb 2009
                  • 7034
                  That is a judgment call on your part. The EB series caps should not directly affect the inverter. However, I am of the opinion that the excessive ripple on the 5V supply associated with failing caps is responsible for corruption of the EEPROM.
                  That is a legitimate number AND the part has been used in inverters. It also happens to be an IC that may make troubleshooting the inverter more difficult.
                  Nope - they can be tested in circuit. All you are doing is comparing the resistance of the secondaries - the windings that connect to the CCFLs.
                  PlainBill
                  • Heliotropic
                    • Oct 2010
                    • 14
                    Maybe these will help...
                    • Heliotropic
                      • Oct 2010
                      • 14
                      On T801 and T802 (pwr xfmrs) I'm getting 0 ohms between 1 and 4, also 0 ohms between 3 and 6.
                      I get 'open' between 1 and 6, 3 and 4.
                      Shorted?
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Shorted?
                        No, that's normal. The primaries of these transformers are only a few turns of a (relatively) heavy gauge wire.
                        Notice I said secondaries. Pin 8 is one end, the @#$%@#%@!$ that drew up the schematic obscured the other number.
                        PlainBill
                        • Heliotropic
                          • Oct 2010
                          • 14
                          PlainBill
                          My mistake, I was thinking 1-6 side were the secondaries.
                          I'm at about 470 ohms on pins 7 and 8.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            That does it. Note my original suggestion.
                            PlainBill
                            • bonney
                              • Oct 2008
                              • 74
                              I would say you have a weak or lazy CCFL
                              • Heliotropic
                                • Oct 2010
                                • 14
                                PlainBill
                                Is that not what i just did?
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Did you? "About 470 ohms" does not tell me that you measured both secondaries and the two readings matched to within 3%.
                                  I emphasize several things repeatedly.
                                  1. I don't have a crystal ball, I can't see what is happening.
                                  2. I'm not a mind reader, I only know what you say (yes, I realize this works both ways and sometimes I'm negligent on the information I give).
                                  3. The 'customer' often does not recognize the significance of what he sees. The worst example that comes to mind occurred about a year ago. The guy had a 'two seconds to black' problem on a Gateway monitor. All caps looked fine, according to him. After trying several things over a few days, I asked for pictures. Surprise, surprise. Most of the caps on the board had bulging tops. He 'didn't think they looked bad'.
                                  4. I have a real life. It's not the best one possible, but I enjoy it. I have a low tolerance for anyone who does not give the information I request. Fortunately, there are others who are more tolerant.
                                  PlainBill
                                  • Heliotropic
                                    • Oct 2010
                                    • 14
                                    PlainBill
                                    You did not request me to report the resistance readings of each.
                                    I guess the correct reply to the post would have been, "Yes, they match within 3%". But using my "crystal ball" I assumed you wanted a number, in which I replied:
                                    I assumed that you too had a "crystal ball" and would know that both are about 470 ohms.
                                    Now, to be more exact, T801 is 472 and T802 462.
                                    1. I am not an electronics technician, and as I stated in my second post, my knowledge is limited. Therefore, describing exactly what and where to test would save us a lot of time. By "what and where" I mean by board location, I do not know the name of everything on a circuit board.
                                    2. As can be assumed by point #1, I do not have the tools of an tech. I only have a simple cheap multimeter and soldering iron, so please keep in mind that my testing abilities are limited.
                                    3. If I'm in over my head just say so and I'll move along.
                                    4. If this forum is more for advanced people, say so and I'll move along.
                                    5. If you do not have the tolerance to help someone that has with little to no knowlege of the subject at hand, or an understanding of the question you ask, then a help forum is not for you.
                                    Now I understand you are trying to help, and any help is appreciated, but your condescending posts are not helpful at all.
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Lol. Lol. Lol. Lol. Lol. Lol. Lol!!!
                                      Ok everyone cheer up!
                                      • k0i_
                                        • 10
                                        does this monitor got no english service manual to download?
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • RetroComputingGrotto
                                          Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                                          by RetroComputingGrotto
                                          I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                                          I've uploaded a video of it happening on YouTube:
                                          I've taken the monitor...
                                          01-11-2024, 05:37 AM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                        • Rick_1234
                                          LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                          To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                          https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                          Things I tried
                                          - Bought a new AC adapter thinking that was the problem but the problem...
                                          06-22-2024, 04:44 PM
                                          Wise Wing F199 19'' LCD monitor - recapped
                                          by momaka
                                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                          When I saw the Craigslist post, I wasn't...
                                          08-24-2020, 10:58 AM
