Samsung 2233SN no CFL backlight
  • Spoonicks
    • Jun 2023
    • 12
    • Spain
    Have a Samsung 2233SN with no CFL backlight. Testing with a flashlight, I can see the image is displayed, but the backlight fails after some seconds.
    Sometimes, after being off for a while, the backlight will remain on for a couple minutes, but most of the times it fails immediately.
    I tried to follow the guide present in this forum, but so far I haven't de-soldered any components. I need some advice on how to proceed to diagnose this display.
    Following the guide I tested the following:
    The transformer for the CFL: Between primary and secondary windings I get OL. I measure 1.14KΩ across both secondary windings. The weird part is that I measure 0.3 Ω between one of the primary windings, and 3 MΩ in the other primary winding. I added a image, where I marked in blue the pins I used to measure the secondary windings, and the pings I used to measure the primary windings.
    The MOSFET, I noticed a AP4506GEH on the bottow of the board, which I believe is used to drive the transformer for the CFL.
    Across pins 1 and 2 I got: 29.7 KΩ (same, if I invert the multimeter leads)
    Pins 3 and 4: 5.1 KΩ (same, if I invert the multimeter leads)
    Between any of the pins, and the "tab" at the top, I get a reading in the Mega ohms range that keeps changing, increasing slightly.
    It doesn't appear to be shorted.
    The Diodes, I think I will have to remove the diodes to test them.
    D21, D22 and D23 are reading 0,282 V. In the non conductive direction, the reading starts at 0 V and increases until OL.
    D24 and D25 are reading 0,167 V. In the non conductive direction they start at 0 V and goes up to 2.67 V.
    Testing the 12 PIN connection the 16V pins had close to 19V. I am not sure if that could be consider normal, or if that value is miss printed.
    What should be my next step? remove the caps to test them? I can see 7 electrolytic caps in the board, plus the main big filtering cap. I believe only 2 of them are related to the CFL backlight.
    Look at the reading I got, are those readings in the transformer windings normal? I would expect them to be the same, but it was measured in circuit.
  • R_J
    • 9583
    Re: Samsung 2233SN no CFL backlight
    It may be a bad ccfl lamp, the transformer only has one primary winding, pins 6.7 and 8,9 (pins 5&10 are just for mounting) this schematic should be close.
    Sometimes you can try: disconnecting all ccfl lamps and try connecting one ccfl lamp (plug) at a time and note if the ccfl lights the screen for a second or two, each lamp should flash the screen about the same brightness, You can try each ccfl into the same plug example CN72 pins 1,2
    With all lamps connected, you could also try and monitor the voltage on R73, R71, R76, R78 to see if there is a difference, a different voltage could indicate if there is a bad ccfl
    • Spoonicks
      • Jun 2023
      • 12
      • Spain
      Is there a way to test for that? if I don't have any spare lamps?
      If one of the lamps fails, then both of them go out?
      Can you help me understand what pins are for the primary winding? I thought it would basically be 2 separate transformers in a single package. So, 8 pins total.
      • Spoonicks
        • Jun 2023
        • 12
        • Spain
        Can I test this, even if the lamps don't light up?
        EDIT:
        Answering my own question, with the backlight failing to work, I got 0 Volts across those resistors.
        • R_J
          • 9583
          You said the backlights lit up for some seconds
          You need to monitor the voltage as you turn on the monitor to see if there is any voltage before the backlights shut down.
          • Spoonicks
            • Jun 2023
            • 12
            • Spain
            Yes.
            It actually stayed on for 71 seconds atvone time. I measure this:
            R76 1.05 V
            R78 2.8 V
            R71 2.53
            R73 1.5 V
            I tried to go back and read the valies on R78 and R71, and they came down from the 2V range to 1V. The backlight then failed again. I am not sure what isbthe normal value I should get.
            Looking at the schematic I think I measure wrong, I was using DC in my multimeter, and the current is AC.
            I will try to repeat the readings
            • R_J
              • 9583
              The voltages across those resistors are DC volts, R76 and R73 are connected together, same goes for R71 and R78, so I guess it is not really a good test point.
              These are the return points of the ccfl's so the voltages will be different depending on the condition of the lamps.
              Did you try just connecting one lamp at a time? that way each lamp should light for a second and shut down, but if one ccfl is bad (broken) it will not light at all.
              An open ccfl could also trigger the over voltage protection to the ic,
              • Spoonicks
                • Jun 2023
                • 12
                • Spain
                I thought it would be AC since there is no retification after the transformer.
                Havent tested one lamp at a time yet.
                • R_J
                  • 9583
                  After the current flows through the ccfl, it is rectified by D75~D78 before returning to ground via R73/R73 etc There are 3 dc voltages that the ic (pins 4,5 &9) monitors, one feeds via R52, one at R54 and one at R55
                  D71~D74 monitors the A/C from the transformer, rectifies it and feeds the Dc value to voltage divider R52/R53, through R51 to pin 5 (vs)
                  You could also try swapping the ccfl leads around on CN72 from 1,2 to 3,4 and do the same for CN71, and see if that makes any difference. Also check the 4 small blue disc caps (C76 etc.) to make sure they are not cracked or have a black burn mark on them, I have seen them fail before.
                  • Spoonicks
                    • Jun 2023
                    • 12
                    • Spain
                    I tested the ccfls.
                    Connected one at a time, one of them didn't emit any sort of visible light, and the transformer made a high pitch noise.
                    My procedure was to connect one ccfl, power on the display, look for light, power off the display, repeat for all 4 lamps.
                    Assume CCFL is the problem, it didn't work on any of the connectors.
                    Probably not worth it to replace the CCFLs. It was fun to attempt to diagnose it though, not something I usually do.
                    Need to study more about this.
                    Thank you far all the help, R_J
                    • R_J
                      • 9583
                      Looks like one bad ccfl, find a recycler or repair shop that might have the same size monitor with a damaged lcd and get a couple ccfls and replace the bad one.
                      With the bad ccfl, (likely cracked) the high voltage is likely arcing in the tube causing the noise in the transformer.
                      • corrize
                        Where to find a very small fpc connector 0.3mm between 2 pins ?
                        by corrize
                        Hello, I search this connector (oxydated).
                        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                        Do you know how to find this connector please ? What is the exact name for find it ?
                        08-06-2024, 05:25 PM
                      • CapSnap123
                        Fixing a variac with shorted windings
                        by CapSnap123
                        I have an old "Adjust-a-Volt" variac. Shortly after I bought it, it started smoking and now the windings look burned for about 2 inches around the left side. Is it possible to fix this or bypass the shorted windings? I'm not sure how to detect where the bad windings are, except by appearance.
                        10-22-2024, 04:43 PM
                      • SS454
                        vizio e650i-a2 backlight flashes then turns off
                        by SS454
                        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                        panel: au optronics T650HVN05.4
                        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                        https://www.shopjimmy.com/vizio-56-0...-power-supply/
                        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                        08-20-2020, 03:57 PM
                      • DominanceINC
                        MSI Pro Z790-P Wifi 1missing CPU pins
                        by DominanceINC
                        I am a new forum member. I found a broken MSI motherboard with lot of problems. The other problems need schematic. Because, the missing parts what were breaking down with screwdriver and pliers at a standoff.
                        So, its actual problem is a missing Vcore and Gnd pins in the CPU socket. My question is that, can it be used safely without these two pins? Only for testing at first, while the other problems will be solved. I would wish repair them later.
                        The other spots are thermal phaste, because, the under educated installer of the CPU did wipe the contacts of the...
                        07-21-2025, 05:38 AM
                      • b0n3v
                        [Help]Reading EC - T14 G1 AMD with RT809h
                        by b0n3v
                        Hello everyone!
                        I try to read the EC ITE/IT8300FN where the bios password is stored.
                        The laptop is Lenovo T14 G1 AMD Ryzen 4650U, the MB is NM-C801.
                        I can't read the chip with RT809H with ITE board and PFC cable. Might be I need to do something more to enable programing mode(SPI Enable?).
                        I saw the post in another forum for T14s AMD (different MB but same EC configuration and pinouts) and one user successfully read and write the the same chip with SVOD3.
                        Some details what i did:
                        Battery and CMOS battery is unplugged.
                        I click Read and then...
                        05-15-2023, 04:02 AM
