Re: Hanns-G HG281D, LCD Monitor no power
We rarely provide lists of caps as we have no idea what version of any particular board might be in your set. The manufacturers sometimes make amendments to the values they use even on the same board versions.
The best way is to simply list the caps you have on your board and then look up the datasheets and see what is available at digikey. You need the same voltage and uf value and same or better esr. You should also make sure they will physically fit.
If you look a few posts up there is an example of this -
