Very poorly Yusmart 2291p-p
  • Quotidian
    • Sep 2010
    • 6
    • England
    Hello everyone, new forum user so please be gentle. The problem is my faulty monitor. Upon turning on, a grey screen fades to black with red, green and blue vertical pinstripes. Some of the electrolytics on the main board did make me wonder, but I haven't changed or tested them yet. Thought I'd hear from you guys first. Wondering where to begin. Cheers in advance, Lee.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Very poorly Yusmart 2291p-p
    Post clear focused pictures AFTER reading
    https://www.badcaps.net/forum/showthread.php?t=1868
    Please do not post pictures inline.
    Take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focus pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
    Here is an example of the pictures we want.
    https://www.badcaps.net/forum/showpos...94&postcount=1
    --- begin sig file ---
    --- end sig file ---
    • Quotidian
      • Sep 2010
      • 6
      • England
      Sorry, was going to do that Shall crack on with it now.
      • Quotidian
        • Sep 2010
        • 6
        • England
        Hello all, board pictures now uploaded (had to wait for daylight) I've been looking at your badcap list, these boards contain both Hermei & Lelon caps, but they aren't bulging or leaking. Cheers, Lee.
        • jetadm123
          • 2169
          Welcome to the forum! Funny, but there's another member that posted problems with their Yusmart. Although their problems are different from yours, it's worth reading:
          https://www.badcaps.net/forum/showth...hlight=yusmart
          Please post a photo of what the screen looks like with the vertical lines, etc.
          You can probably start by checking for proper voltages at the power supply. Measure the output voltages at the 9 pin connector cable (P802) at the right side of your first photo.
          • jetadm123
            • 2169
            Also check the voltage regulator (I104) outputs located on your logic card (3rd photo). Pin 1 is ground, Pin 2 = 3.3V and Pin 3 = 5V.
            • retiredcaps
              • Apr 2010
              • 9271
              Excellent photos. A+.
              Like jetadm123 suggested, check the voltages first and report back.
              • Quotidian
                • Sep 2010
                • 6
                • England
                Hello again, thanks for the welcome.
                I've been measuring and here are some findings :
                I104 has 3.29 and 4.66V from pins 2 & 3 respectively.
                C805 ( the big one) has +161-3V on the anode & -154-6V at the cathode and also the end cap.
                My P802 (9 pin connector) voltages are pretty much the same as fusionmax in the other thread, however mine are 4.99V compared to his 5.15V on the same pins (2,5 & 6). I get pin 7 reading 1.62V & pin 8 reads 2.83V all other pins read zero (1,3,4,9)
                • jetadm123
                  • 2169
                  Output of I104 looks pretty good.
                  Please note that I'm referencing a schematic from a Viewsonic monitor as provided by fusionmax.
                  5V output vs 4.99V is good.
                  C805 Voltage is good.
                  Pin 7 controls brightness.
                  Pin 8 is on/off
                  24V output is probably good, since the backlights are coming on.
                  Unfortunately, nothing is sticking out at this point.
                  Looking at the photos of the vertical lines: Are the same lines present everytime you turn on the monitor? Or are they random?
                  I suspect you already reseated the cable connecting the logic card to the LCD panel, since you had to piece everything back together to take the photos.
                  With the vertical lines showing, have you tried GENTLY tried pressing on the LCD screen at the top most point of one of those vertical lines to see if it goes away? Just checking to see if there's a loose connection.
                  If there was also a picture with the vertical lines, I would say it was the LCD panel that had failed, but what's got me puzzled is the lack of a picture. Bad logic card?
                  • Rtech
                    • Jul 2010
                    • 1095
                    If you get no respite with jetadm123's suggestion,then there is no other option but to try a replacement Logic board to confirm Logic or LCD Panel,but I'm sure you would have done that,if you had one.Chances are that it is the Panel.
                    • Quotidian
                      • Sep 2010
                      • 6
                      • England
                      I've managed to acquire another logic board, shall have it tomorrow hopefully. Will keep you updated. Cheers, Lee.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        If the replacement logic board does work, then you will have something to compare voltages and hopefully narrow down the problem.
                        • Quotidian
                          • Sep 2010
                          • 6
                          • England
                          Yes, hopefully. I'm also currently looking at building an ESR meter, which should assist in my task. I've been reading some of the threads on here about them. If I had the money I'd just buy one, but needs must & all that.
                          • fusionmax
                            • Sep 2010
                            • 42
                            I have the exact same monitor and have been having problems with it, mine is totally dead though, see post at https://www.badcaps.net/forum/showthread.php?t=11024
                            I was wondering if you could do me a favour and measure the voltage you are getting at the power button?
                            I want to rule it out as an issue on mine and have been unable to find a datasheet to give me any more info.
                            Also, where did you manage to find a replacement logic board?
                            • bonney
                              • Oct 2008
                              • 74
                              Have you cleaned and refitted the screen cable?
                              • bohaboha
                                Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                by bohaboha
                                Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                anyhow i couldn't t read anything else
                                the backlight is on strong and the screen does not get dark or very dark but no pictures
                                the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                01-02-2025, 08:04 PM
                              • valvashon
                                LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                by valvashon
                                The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                11-24-2024, 12:08 PM
                              • 2elw
                                SVOD4 PCB pictures + parts
                                by 2elw
                                Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                GW1N-UV9UG169C6/I5 FPGA - Its a...
                                07-04-2025, 12:23 PM
                              • Techie_hobby1
                                Help with a poorly looking component identification plea
                                by Techie_hobby1
                                A friend of the family has handed me a food warmer that has failed on her.
                                I appreciate that some people will alert me that it is probably cheaply made, but she has extremely limited mobility, and it is perfect for keeping her food nice and warm, once her carers have left.
                                It has 2 power options (either 12V DC cigarette lighter or AC 240v IEC C7 socket).
                                Basically, it powers 2 x PTC elements which are attached to a metal plate.
                                A (removable)metal deep tray is then placed on-top of the small plate which keeps the food nice and warm.
                                I thought at first...
                                03-23-2025, 06:54 PM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
