Hello everyone, new forum user so please be gentle. The problem is my faulty monitor. Upon turning on, a grey screen fades to black with red, green and blue vertical pinstripes. Some of the electrolytics on the main board did make me wonder, but I haven't changed or tested them yet. Thought I'd hear from you guys first. Wondering where to begin. Cheers in advance, Lee.
Very poorly Yusmart 2291p-p
Re: Very poorly Yusmart 2291p-p
Originally posted by Quotidian View PostWondering where to begin.
https://www.badcaps.net/forum/showthread.php?t=1868
Please do not post pictures inline.
Take your boards to a window on a sunny day, turn flash off, and use macro mode. Take a top down view of all your boards (front and back). Make sure the photo is legible so that we can read the PCB printing clearly. A shutter speed of 1/125 or faster will produce nice clear focus pictures. Try to get a photo that is 2000x2000 resolution or as close as possible.
Here is an example of the pictures we want.
https://www.badcaps.net/forum/showpos...94&postcount=1--- begin sig file ---
--- end sig file ---
Welcome to the forum! Funny, but there's another member that posted problems with their Yusmart. Although their problems are different from yours, it's worth reading:
https://www.badcaps.net/forum/showth...hlight=yusmart
Please post a photo of what the screen looks like with the vertical lines, etc.
You can probably start by checking for proper voltages at the power supply. Measure the output voltages at the 9 pin connector cable (P802) at the right side of your first photo.Last edited by jetadm123; 09-13-2010, 07:47 AM.
Originally posted by Quotidian View PostHello all, board pictures now uploaded (had to wait for daylight)
Like jetadm123 suggested, check the voltages first and report back.--- begin sig file ---
Hello again, thanks for the welcome.
I've been measuring and here are some findings :
I104 has 3.29 and 4.66V from pins 2 & 3 respectively.
C805 ( the big one) has +161-3V on the anode & -154-6V at the cathode and also the end cap.
My P802 (9 pin connector) voltages are pretty much the same as fusionmax in the other thread, however mine are 4.99V compared to his 5.15V on the same pins (2,5 & 6). I get pin 7 reading 1.62V & pin 8 reads 2.83V all other pins read zero (1,3,4,9)
Please note that I'm referencing a schematic from a Viewsonic monitor as provided by fusionmax.
5V output vs 4.99V is good.
C805 Voltage is good.
Pin 7 controls brightness.
Pin 8 is on/off
24V output is probably good, since the backlights are coming on.
Unfortunately, nothing is sticking out at this point.
Looking at the photos of the vertical lines: Are the same lines present everytime you turn on the monitor? Or are they random?
I suspect you already reseated the cable connecting the logic card to the LCD panel, since you had to piece everything back together to take the photos.
With the vertical lines showing, have you tried GENTLY tried pressing on the LCD screen at the top most point of one of those vertical lines to see if it goes away? Just checking to see if there's a loose connection.
If there was also a picture with the vertical lines, I would say it was the LCD panel that had failed, but what's got me puzzled is the lack of a picture. Bad logic card?Last edited by jetadm123; 09-13-2010, 08:42 PM.
Originally posted by Quotidian View PostHello,
I've managed to acquire another logic board, shall have it tomorrow hopefully. Will keep you updated. Cheers, Lee.--- begin sig file ---
I have the exact same monitor and have been having problems with it, mine is totally dead though, see post at https://www.badcaps.net/forum/showthread.php?t=11024
I was wondering if you could do me a favour and measure the voltage you are getting at the power button?
I want to rule it out as an issue on mine and have been unable to find a datasheet to give me any more info.
Also, where did you manage to find a replacement logic board?
