Yusmart 229IP-P 22" LCD Monitor Dead
  • retiredcaps
    • Apr 2010
    • 9271
    #81
    Re: Yusmart 229IP-P 22" LCD Monitor Dead
    Originally posted by Whitey
    Thanks retiredcaps for the link unfortunately I dont have a credit card or paypal account.
    If you click on the link I supplied, the document opens right up and I can read the document without any payment at all.
    --- begin sig file ---
    --- end sig file ---
    • Whitey
      • Jan 2011
      • 4
      #82
      ok I'll try again it only showed me blank pages.
      thanks for your help.
      • retiredcaps
        • Apr 2010
        • 9271
        #83
        Try with google chrome or IE 8.
        • Whitey
          • Jan 2011
          • 4
          #84
          Thanks you were right I changed to ie8 and had no problem was able to view it.
          It looks like I should have no problem doing my job now I have both service manuals.
          I'll let you know how it all works out thanks for your help
          • fusionmax
            • Sep 2010
            • 42
            #85
            I have still not managed to make any progress with the monitor
            I think we were looking at the reset controller but with PlainBills comment....
            That shows a simple R/C reset circuit, although the board has provision for a reset controller.
            PlainBill
            I assume the board doesnt look like it has one?
            • fusionmax
              • Sep 2010
              • 42
              #86
              I think this monitor might be destined for the bin! I am not getting anywhere and the thread has gone all quiet.
              Quotidian, did you ever get anywhere with yours?
              • chris67
                #87
                i have the exact same symtoms with my Novita 2205W Type#: L22BW monitor.
                All sec. voltages are ok.
                No power-LED at any time.
                Backlite comes up when shortening the transistor Q901 but no luck with the powerbutton and no picture shown on the panel when a pc is connected.
                Regards
                Chris
                • jetadm123
                  • 2169
                  #88
                  Regards
                  Chris
                  Is the Novita power supply the same as the Yusmart's? Regardless, you should have started a new thread and provided some good focused photos of the top and bottom of the power supply using the "manage attachments" button.
                  • fusionmax
                    • Sep 2010
                    • 42
                    #89
                    That reply has prompted me to dig the monitor back out of the cupboard and give things another go!
                    • andy29
                      • Jun 2018
                      • 3
                      Hello there, I realise that this is a massive bump, I apologise if I'm doing the wrong thing but I have a problem with exactly the same model of monitor and all of the pictures and information posted by fusionmax apply to mine too. The schematic which was being used is here: https://www.manualslib.com/manual/78...x2235wm-3.html
                      My problem is slightly different. When I plug it in to the mains, the LED lights up green (as if it is out of standby) and the backlights come on. The display just shows black, I can't see any image at all. But at that point it completely locks up. Giving it a VGA signal does nothing, the buttons do nothing, and it never goes into standby when there's no signal as it normally would. When I was last using it there were no signs of problems, but the next day after being powered off at the mains overnight, it was doing this.
                      I've checked the voltages on the connector going to the logic board and they are as follows:
                      1 0v
                      2 5.21v
                      3 0v
                      4 0v
                      5 5.21v
                      6 5.21v
                      7 3.31v
                      8 0.02v
                      9 0v
                      so not far off from fusionmax's results except for pin 7. I realise that is the brightness control so I don't know if that could point to anything.
                      I took off a couple of capacitors from the 24v and 5v sections of the power supply board (C823 and C825) and checked them with an ESR meter, but they're fine. The only thing I did see was that one of the small green ones on the logic board did show an ESR of 0.76 ohms. Well it's 100uf 16v and according to my meter it should be 0.7 ohms or less. So it's not far off, would you say it was bad?
                      From here: https://www.badcaps.net/forum/showth...526#post130526 onwards there are mentions of an EEPROM and a reset circuit so I don't know if there's any way of inspecting those.
                      Any help would be much appreciated... I don't expect to make anyone to read through the entire thread, so if there's anything I've missed, which I probably have, please let me know.
                        by momaka
                        03-15-2023, 10:17 PM
                      • ant3202
                        HP 27es - LED monitor - Monitor Flashing On - Off
                        by ant3202
                        Hi Everyone
                        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                        https://www.badcaps.net/forum/troubl...lashing-on-off
                        The monitor is HP 27es LED Monitor
                        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                        The monitor will randomly blackout and display no signal and will recover again.
                        Sometimes need to power and off again to restore the display but...
                        03-20-2025, 07:30 PM
                      • Rick_1234
                        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                        by Rick_1234
                        Good evening, gentlemen.
                        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                        https://drive.google.com/file/d/1L6S...ew?usp=sharing
                        Things I tried
                        - Bought a new AC adapter thinking that was the problem but the problem...
                        06-22-2024, 04:44 PM
                        Wise Wing F199 19'' LCD monitor - recapped
                        by momaka
                        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                        When I saw the Craigslist post, I wasn't...
                        08-24-2020, 10:58 AM
                      • sew333
                        Pc shutdown, monitor flickered with no signal after 10 seconds
                        by sew333
                        My pc:
                        10850K stock 4800mhz stock Kraken X73 good temps
                        2x16 GB DDR4 GSKILL 3000mhz XMP
                        Seasonic Tx-850 Ultra Titanium
                        Gigabyte Rtx 3090 Gaming OC
                        Aorus Z490 Pro Gaming
                        1 TB SSD
                        4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                        Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                        Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                        Power...
                        02-22-2022, 10:27 AM
