need inputs
  • bullwinkle
    • May 2009
    • 107
    need inputs
    May I know what causes these thing as shown.
  • digge
    • Apr 2006
    • 296
    Re: need inputs
    This is a wild guess, probably someone else can tell if im right or not, but i would guess its moisture or similar that have made the top layer of the panel get loose in the corners.
    • bullwinkle
      • May 2009
      • 107
      Re: need inputs
      @ digge: thanks for your input. appreciate it.
      This LCD monitor is working fine except for that screen problem.
      • bullwinkle
        • May 2009
        • 107
        Re: need inputs
        any other inputs?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: need inputs
          I've heard of a situation where light from the back-light 'leaks' around the edges due to ill fitting parts but I've never personally seen the problem so I dunno if it looks like that.
          The solution to that is to adjust the parts and/or use electric or metal tape to block the light leakage.
          Mann-Made Global Warming.
          - Dr Seuss
          • bullwinkle
            • May 2009
            • 107
            Re: need inputs
            Thnx for the input. will try your solution as soon as i can and i will post the result.
            • Toasty
              • Jul 2007
              • 4171
              Re: need inputs
              Which model Dell is that?
              I've heard of the backlight leak problem and saw a site that showed a step by step fix. They used electrical tape to seal the edges of the panel. But that was a while ago. BRB...
              (10 minutes thru browser history later)
              http://www.tftcentral.co.uk/articles...klight_fix.htm
              Going by the picture there and comparing it to yours, I don't think you have the backlight problem. His looks like a fading effect. Yours looks like someone scraped the pixels off. Looks more like the panel edge bond has failed and the layers are separating.
              Hopefully someone has seen this before.
              Toast
              veritas odium parit
              • hoadle
                • Jul 2010
                • 174
                Re: need inputs
                I think you monitor had 1 of 2 problem
                1/ 70% LCD panel bad
                2/ 30% VGA card is go bad soon
                But first open & check all cap
                • bullwinkle
                  • May 2009
                  • 107
                  Re: need inputs
                  Toast
                  thank you for a very interesting link. bookmarked for later action. will post update soon
                  • bullwinkle
                    • May 2009
                    • 107
                    Re: need inputs
                    I think only number 1 is applied here since I used different video cards. caps are all checked using multitester, esr, and cap meter.
                    • bullwinkle
                      • May 2009
                      • 107
                      Re: need inputs
                      DELL E173FPb is the model
                      • bullwinkle
                        • May 2009
                        • 107
                        Re: need inputs
                        update:
                        using this suggestion: http://www.tftcentral.co.uk/articles...klight_fix.htm
                        result is still the same.
                        • bullwinkle
                          • May 2009
                          • 107
                          Re: need inputs
                          any other suggestions?
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Re: need inputs
                            I think maybe some kind of delamination problem.
                            http://www.mcclainsolutions.com/news/LCD_Damage.html
                            - Dr Seuss
                            • bullwinkle
                              • May 2009
                              • 107
                              Re: need inputs
                              thank you for the site. done bookmarking. will read it later.
                              • pfl
                                ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
                                by pfl
                                Hello Everyone.
                                This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
                                It consists in :
                                • a power board were the full H bridge class D amplifier and main power rails are located
                                • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
                                Power rails are ok.
                                human interface is working fine
                                Input levels are...
                                01-23-2024, 10:21 AM
                              • korben_dallas
                                How do I find my "board path" as shown on openboarddata.org ?
                                by korben_dallas
                                Full model: Mid-2012 Macbook Pro 15" Retina A1398 (EMC 2512) MC975LL/A
                                02-14-2024, 12:30 AM
                              • edugimeno
                                Repairing a ENERTRES Biomass BI-650 heater
                                by edugimeno
                                Hi all!
                                A friend asked me to repair his biomass (pellet) heater. This heater has a pellet feeder powered by a relay that's not switching anymore
                                I measured the voltage at the relay coil socket while entering the individual tests procedures and it has 6-7v while the relay is NOT on the socket, and drops to 0v when the relay is plugged in the socket, like the source is providing nearly 0 mA. I measured the relay coil and it is correct and not shorted so the issue is in the board, fed no amps to this output
                                I checked the board at home and this output is driven by an...
                                07-28-2025, 04:32 AM
                              • 90Ninety
                                Zotac RTX 3060 , another learning experience
                                by 90Ninety
                                Disclaimer Firstly I am by no means expert and this is still a learning experience , I buy broken stuff , with the intention to fix or learn something by failing.. I wanna break this into a few sections, please feel free to mention the section if replying , to assist me on getting a better understanding
                                Part 1 , identifying Rails .. So for the record , I understand on NVIDIA cards there are several Rails. Along with their Supposed Voltages ( Voltage depends on age/ generation )
                                Part 2. Blown / Missing component check .. I purchased this from the original...
                                06-09-2024, 09:43 AM
                              • E--Man
                                Samsung LED UHD TV - Bad Main Board or Bad T-Con Board? Pictures inside
                                by E--Man
                                Hi All,
                                Thanks for reading. Based on the interesting fact that the vertical lines issue don't seem to effect the menus whatsoever but rather everything around the menu regardless of video is shown, I'm trying to set mine whether the issue is the main board or the t-con board.
                                Again what's baffling is that the menu is not effected whatsoever. However, any other video displayed regardless of inputs or when no inputs exist exhibits the vertical lines and seem to effect black areas only.
                                The lines are green in color when the tv is in "Game Mode" and...
                                05-12-2024, 10:52 AM
