Kortek KT-2914DF
    Kortek KT-2914DF
    Computer display of sorts (Kortek KT-2914DF)
    It's attached to a 'Fast 'n Furious' video game.
    Took far too long diagnosing the fault - no raster - as I assumed a catastrophic failure of the smokey type.
    Found several high ESR caps including the one I fudged a while ago - these chassis have quite good caps except for C118 on the CRT heater supply - it fails very quickly and gives a dim display - I fudged it by hanging a cap off the neck board rather than take the chassis out as it's not easy to get out.
    Put the chassis back in and now I can barely see a raster - crank up G2 and I can (sort of) see the menu - contrast/brightness at max - I clicked through the menu and noticed that colour temperature was 6500K rather than 9300K - changed it and 'bingo' raster back to normal.
    Checked the other unit and both colour temperatures provide a good picture.
    Anyone got any idea which chip controls colour temperature ???
    I tried setting a user colour temperature but you can only access the green channel.
    I'm asking as I'm a bit snowed under with repairs - got a Sanwa which caught fire !
    Ta.
    Re: Kortek KT-2914DF
    Got into the Factory menu by powering up with 'UP' selected on the remote board and can now access the full Colour Temperature menu where I can set a 'user' CTemp.
    Looks like the CTemp look up table has been corrupted leaving red & blue at zero and green not doing a lot.
    At least if I lose the table for 9300K I can set a user Colour.
