Monitor making weird noise when charging resolution or in standby mode
  • Antony2023
    • Jan 2023
    • 4
    • România
    Hello, guys i need some help, i have an old fujitsu siemens LCD monitor, and is making weird noise when is changing resolution or in standby mode.
    I open it up, to see if it is any hardware damage, but i only see 2 capacitors bulging on the logic board, i'll probably change them. On the power supply circuit board, only one thing caught my attention, the transformer seems to have leaked something out of it and the mess around it. Do you think there may be a problem here?
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Monitor making weird noise when charging resolution or in standby mode
    The transformer looks OK, just the varnish it's been dipped in.
    I'd recap the power supply too.
    And as much of the signal board- those can be difficult to remove, but tinning their leads with good leaded solder can make removal easier.
    Good luck!
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • CapLeaker
      Leaking Member
      • 8226
      Don’t worry about that transformer, it came out of the factory like that.
      • redwire
        • 3910
        When the power supply caps croak, it stresses the ones on the logic board.
        Just recap the PSU and those logic board caps.
        • Antony2023
          • Jan 2023
          • 4
          • România
          Thank you all for the quick response i will recap and see if it fix it.
          • Antony2023
            • Jan 2023
            • 4
            • România
            I managed to change the capacitors from the power supply board and from the logic board, and the weird noise is gone, but it was a pain in the ass, mostly because i have a cheap soldering iron from China, and it won't properly heat to melt the solder.
            • R_J
              • 9561
              Always add some fresh solder when de-soldering the parts, it will transfer the heat a lot better.
                by momaka
                03-15-2023, 10:17 PM
              • Thomasraud
                Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                by Thomasraud
                i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                QUOTED
                -It works on charger (without battery connected-only charger)
                -It works on battery (without charger connected-only battery)
                -& it also works when plugged in battery & charger, but it's not charging the battery
                //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                and..
                QUOTE
                The IC cannot maintain the input current level
                06-28-2022, 06:47 PM
              • Benchaton
                Weird Charging behavior Aspire A517-51G
                by Benchaton
                Ok so, I've got a 17" Aspire 5, when I put it under any sort of medium high load it just stops charging and show blinks the status LEDs which I suppose mean it get's in power safety mode. Only notable things I can see being an issue are my CSME firmware which isn't the one from Acer because the Acer one was a vulnerable version relative to the current firmware I have installed (latest for KabyLake / KabyLake Refresh), the PC being only able to supply 0.05W to the battery on load spikes, and the slightly loose power inlet.
                I mostly suspect the latter but it seamingly started happening...
                07-30-2025, 04:43 PM
              • Scoff
                HP Probook 470 G4 - Power and Charging Problem
                by Scoff
                Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                07-03-2023, 09:28 AM
              • wattage
                AOC AG493UCX 49-inch monitor - Firmware request
                by wattage
                Hello Badcaps Community,
                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                07-13-2025, 04:41 PM
