Monitor making weird noise when charging resolution or in standby mode
  • Antony2023
    • Jan 2023
    • 4
    • România
    Hello, guys i need some help, i have an old fujitsu siemens LCD monitor, and is making weird noise when is changing resolution or in standby mode.
    I open it up, to see if it is any hardware damage, but i only see 2 capacitors bulging on the logic board, i'll probably change them. On the power supply circuit board, only one thing caught my attention, the transformer seems to have leaked something out of it and the mess around it. Do you think there may be a problem here?
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Monitor making weird noise when charging resolution or in standby mode
    The transformer looks OK, just the varnish it's been dipped in.
    I'd recap the power supply too.
    And as much of the signal board- those can be difficult to remove, but tinning their leads with good leaded solder can make removal easier.
    Good luck!
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • CapLeaker
      Leaking Member
      • 8066
      Don’t worry about that transformer, it came out of the factory like that.
      • redwire
        • 3902
        When the power supply caps croak, it stresses the ones on the logic board.
        Just recap the PSU and those logic board caps.
        • Antony2023
          • Jan 2023
          • 4
          • România
          Thank you all for the quick response i will recap and see if it fix it.
          • Antony2023
            • Jan 2023
            • 4
            • România
            I managed to change the capacitors from the power supply board and from the logic board, and the weird noise is gone, but it was a pain in the ass, mostly because i have a cheap soldering iron from China, and it won't properly heat to melt the solder.
            • R_J
              • 9535
              Always add some fresh solder when de-soldering the parts, it will transfer the heat a lot better.
                by momaka
                03-15-2023, 10:17 PM
              • Thomasraud
                Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                by Thomasraud
                i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                QUOTED
                -It works on charger (without battery connected-only charger)
                -It works on battery (without charger connected-only battery)
                -& it also works when plugged in battery & charger, but it's not charging the battery
                //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                and..
                QUOTE
                The IC cannot maintain the input current level
                06-28-2022, 06:47 PM
              • Scoff
                HP Probook 470 G4 - Power and Charging Problem
                by Scoff
                Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                07-03-2023, 09:28 AM
              • Ifixstuff9
                Dell SE2416h monitor power cycles - very weird behavior
                by Ifixstuff9
                Hello all,
                I have a dell SE2416h monitor that power cycles at somewhat random intervals. When the monitor is first powered on after being off for a few hours, it lasts 15-30 mins before the first power cycle. After that, the cycles progressively get more frequent until the monitor cycles every few seconds.
                I'm not sure what is causing this, but maybe something is overheating, causing the monitor to shut off? That would explain why it gets worse with time.
                Now here is where things get weird (at least to me, this might be some some common symptom I've...
                04-20-2019, 07:03 PM
              • SluggerB
                Help with trying to fix phone that is not charging (Pics inside)
                by SluggerB
                I have two TCL A30 phones.
                Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                New Phone: Works fine, bought as a donor board to try and repair Old Phone
                My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                08-12-2024, 08:11 AM
