Need Help - DELL 19 inch wide screen
+ More Options
Posts
  • weasel440
    • Aug 2010
    • 23
    i was wondering if someone could point me in the direction on what to look for (is there something common). it turns on, but has a white screen. i tried resoldering all spots and diddn't see any bad / bulging caps. i was in the middle of playing a game and just went to a white screen, still had audio but no picture.
    it is a SE198WFP
    any help would be greatly appreciated
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Need Help - DELL 19 inch wide screen
    A white screen suggests that there is a problem with your logic card. Also double check/reseat the cables from logic card to the panel.
    Or the board on the LCD panel is bad. Check the fuse on the LCD panel to see if it is open.
    --- begin sig file ---
    --- end sig file ---
    • weasel440
      • Aug 2010
      • 23
      ok can some one chime in what these are circled in red? these (2) have no continuity, the rest of them do. also can some one point out which fuse i should check on this board?
      • retiredcaps
        • Apr 2010
        • 9271
        1) Your pic is too small to see the fine details. In addition, please post pics after reading these instructions.
        https://www.badcaps.net/forum/showthread.php?t=1868
        2) From what I can see, the things that are circled in red are diodes (marked with "D"). To test them, put your multimeter in diode function test. Put black on one side, red on the other. Record measurement. Now reverse the probes and record measurement. One side should read between 0.4 and 0.7V and the other should say "1" or "0L" depending on your multimeter.
        Fuses are normally marked with "F" and are near the incoming connector port (by the cables).
        3) The "panel" is the electronic panel that is usually tacked onto the LCD screen. The picture above is the logic card.
        • lucky13
          • Aug 2007
          • 412
          weasel440,
          The LCD's logic board (T-con board if it is on a separate board mounted at the back of the LCD panel) is where that flat cable on the left side of your pix goes to.
          I am quite surprised the number of white screen LCDs I come across these days. 99% of the time it is the panel (after you verify proper voltages are at the p/s).
          • jetadm123
            • 2169
            Originally posted by lucky13
            weasel440,
            Hello lucky13. Other than a blown fuse on the panel board, do you normally find the cause (like a shorted transistor or diode)? Or, is the panel considered non-repairable?
            • George Ortiz
              • Oct 2009
              • 51
              I have the same monitor. How did you remove the connector the backlights and how did you remove the ribbon cable???
              • HTR-Informatique
                Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                by HTR-Informatique
                YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                I also changed the screen because the PC fell and the screen was broken.
                I changed the battery with a new and original battery.
                I also had corrosion/oxidation on the...
                02-09-2025, 06:51 AM
              • ChristianBr01
                Dell 34 inch U3419W Monitor with thin stripes on partial screen
                by ChristianBr01
                I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                Does someone have seen this before?...
                05-23-2025, 06:06 AM
              • Swedishpower
                Dell G3 15 3500 black screen
                by Swedishpower
                Hello
                I have search everywhere for a solution for my problem, but cant find it anywhere.
                When I was away to trow some garbage i always look in the electronic bin.
                and this time i find a laptop.
                Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                the lamp for charmig is white.
                Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                but no Dell logo.
                I tryed with a hdmi cable to another screen, still black.
                I started to search solution and tryed...
                07-06-2025, 06:18 AM
              • jake-b
                dell e6540 boots to black screen (no dell logo)
                by jake-b
                good morning all,
                i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                01-08-2024, 10:29 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
