Blown cone/membrane on speaker-Logitech Z533
  • paparazzo79
    • Dec 2018
    • 303
    • Bosnia
    Hi guys.
    I purchaesed used Logitech Z533 speakers, but in the process of transportation one of the speakers came with damage (pic below).
    So is this something to worry about, will it progress to worsening and end life of a speaker?
    I am not noticing worse sound on that speaker, sound is just as same as on other speaker.
    Is there maybe a way to repair it or better not mess with it?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8705
    Re: Blown cone/membrane on speaker-Logitech Z533
    That's called a dust cap. It being crushed may or may not affect sound quality but it won't get worse over time, it's just for aesthetics and make sure dust doesn't get under it.
    A vacuum cleaner might be strong enough to pull the dent out but you probably won't notice anything if you just leave it as it is unless you look at it and think it's ugly...
    • paparazzo79
      • Dec 2018
      • 303
      • Bosnia
      Yes I thought to use house dust cleaner but I thought it would be too strong to pull the dust cap from inside in and possibly break it.
      I suppose not worth of an hassle,I thought it would progress over time.
      So should I avoid cranking up volume to much?
      • tibimakai
        • Jan 2012
        • 3680
        That is only a dust cover, to protect the coil from dust. Does not affect anything. You could try using a needle to pull out as much as possible.
        You could even replace it. I'm pretty sure somewhere they sell these.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8705
          Couldn't make it worse. People have used needle hooks, vacuum cleaners, and adhesive tape to grab onto the crushed area and pull it out.
          If you do end up accidentally detaching the cover from the cone, just replace the dust cover. Leaving it partially attached probably would cause buzzing and that indeed would be worse than doing nothing.
          • cmlewis89
            LG 47LB5DF blown power supply board
            by cmlewis89
            Hi folks,
            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
            09-03-2024, 07:50 PM
          • RetroComputingGrotto
            IBM LTO 7 Tape Drive - Dust Sensors??
            by RetroComputingGrotto
            I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
            I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
            09-19-2024, 01:54 AM
          • drscoot
            HP X360 convertible battery blown fuse error, not charging
            by drscoot
            HP Modelnumber: 14-dh0061nb​
            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
            All these 3 batteries are charging...
            12-15-2023, 05:54 AM
          • w00pz
            Identify blown component on HP ENVY X360 13-arxxxxx, Motherboard G1 13 AMD X360 18740-1 448.0GA03.0011
            by w00pz
            I have blown a component on HP Envy x360 with motherboard G1 13 AMD X360 18740-1 448.0GA03.0011.
            Unfortunately there are no schematics available and the component was so blown the marking weren't readable.
            I have marked it with a red circle in the attached photos - sorry for the mediocre quality I was too much in a rush.
            Hope someone will be able to identify the component.
            Many thanks for your help!
            Edit: High-res picture added on a normal board (not mine)...
            Today, 02:48 PM
          • swerg
            Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
            by swerg
            Hey everyone,
            I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
            I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
            I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
            06-06-2024, 03:39 PM
