Alesis IO2 USB audio interface re-capping
  • technicalspecialist
    • Jun 2010
    • 65
    I am repairing a friends Alesis IO2 external USB audio interface cos he damaged the USB socket and bent 1 of the microphone XLRs. Already fixed them.
    I thought I might as well replace the larger value capacitors with better quality ones while i've got it.
    It has 2 purple Su'scon SL series 2200uF 6.3V caps and 3 orange Su'scon SA series 100uF 35V caps.
    I think the 2200uF's are likely to be smoothing caps so I think I can safely replace these with low ESR ones.
    On the Su'scon website the SL's are under standard and are general purpose but the SA series is under special. What should I replace the SA's with?
    Also, there are 4 47uF 63V audio coupling caps in series with the MIC XLRs.
    On channel 1 they've used Su'scon SL's. On channel 2 the manufacturer appears to be DON with the flat side of the "D" thicker than the rest.
    I've never heard of this make before. What should I replace these 4 with?
    I've always thought the lower the ESR, the better but since these are in the audio path, I thought maybe not. What will give the best audio quality?
    New electrolytics or another capacitor type entirely?
    The rest of the caps are all tiny 22uF 16V DON's.
    If it's broken, fix it. If it's not broken, improve it.
  • japlytic
    • Oct 2005
    • 2086
    Re: Alesis IO2 USB audio interface re-capping
    The Su'scon SA series are low electrical leakage units.
    Is this an audophile unit? If so, I recommend audio grade capacitors for the four 47uF 63V units. Otherwise, standard units will do.
    If capacitors are used for smoothing, it is safe to assume that you can use low-ESR units as replacements. They are generally better, especially in high frequency power supplies.
    Do you have a picture of the internals of this audio interface (marked with capacitor values)?
      • Jun 2010
      • 65
      i will take some pics of the internals tomorrow. Since testing it, i've found a more serious problem than just the caps. Basically i get no sound and just digital noise. When i plug the USB in, windows xp detects it properly as io2 so i know the usb interface chip is working properly. Without the schematic / service manual i can't progress further and find where the fault is. There are lots of surface mounted ics.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Digital noise points at a DAC fault. And that is going to be difficult to fix. However do try different USB ports or even a different computer, i once panicked coz the ESI Maya soundcard i borrowed from a friend would sound real bad, like 8-bit or something, then i simply plugged it in another USB port and it worked fine.
        A working TV? How boring!
          • 30917
          digital & analog sections of the chip probably have seperate & decoupled power lines.
          (atleast they should)
          find a datasheet for the chip that has pinouts.
            • Jun 2010
            • 65
            Yes, tried USB different ports on my desktop and laptop, same:
            XP detects IO2 -> USB composite device -> USB Audio Device and
            USB LED lights up and audio level indicator LEDs light up full.
            Digital noise on headphones and main output when turned up full.
            I've finally taken some pictures of the PCBs, see attachments
            I did some research into the IC/chip part numbers and it uses:
            TAS1020B USB controller
            CS8416 SPDIF receiver
            CS4265 104 dB ADDA with SPDIF Transmitter 32pin QFP
            3 ON Semiconductor MC33079DG quad op-amps for analogue inputs/outputs on bottom PCB, 1 on top PCB below CH2 gain potentiometer.
            When I connect the S/PDIF output to my Denon AV reciever, the "Lock" LED on the front lights up so the CS4265 is outputing something, but I don't get any sound.
            The datasheet for the CS4265 says it has reset and mute pins, I'll check them if I can. Link
              • Jun 2010
              • 65
              I emailed Alesis to ask for the service manual but got no reply. I can't see how I can progress much further without a schematic. If the CS4265 IC is broken and I could get a free sample from Cirrus Logic, it would be extremely difficult to solder those tiny contacts by hand.
                • 30917
                qfp is easy,
                you use the flow method.
                  • Jun 2010
                  • 65
                  Just phoned the UK number for Alesis and they're gonna email me the service manual in PDF.
                  • longa
                    • Sep 2010
                    Hi technicalspecialist.I am not technical at all but I noticed that you might have schematics for alesis IO2.My IO2 recently died down with very similar symptoms.Friend of mine can repair it but without schm. it is very tricky.If you have schematics can you please,please,please mail it to me.Thank you very much and have a good day.Longa
                      • Jun 2010
                      • 65
                      Yes I managed to get the service manual emailed to me for free. I've given up trying to repair mine as the problem is likely to be the CS4265 chip, which is pretty much impossible to get just 1 or 2 of.
                      From the pictures, you'll see that the pins are very short and soldering by hand would probably burn it.
                      I uploaded the manual to to eServiceInfo and it's a 3 part .rar achive containing the PDF due to 3MB max file size upload limit. Download all 3 parts to the same folder before extracting.
                      Link: http://www.eserviceinfo.com/download...lesis_io2.html
                      • longa
                        • Sep 2010
                        Thank you 123.000 times...Greetz.. Longa
                        • clemenslime
                          • Aug 2011
                          Dear Technical Specialist,
                          On the one hand, I realize this is a shot into the infinite dark internet space. On the other, I've got nothing to lose and I am not a technical specialist and my USB socket on my Alesis IO2 external USB audio interface is damaged and you seem to fix those in the most nonchalant fashion. How on earth do you do that? Did you replace it? It just seems to be loose, because if i push it up and in (and hold it there), it works.
                          Do you have any special technical technical specialist advice?
                          Spank you,
                          Clementine
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Technical specialist advice? Take the cover off, resolder the USB socket AND the metal shield surrounding it, done.
                            • burnt01
                              • Jan 2012
                              Thought i'd join/post as i found this post quite helpful
                              Ive just fixed 5 of these IO2's (for a studio)
                              All had the problem with the signal clip being lit up as soon as you plug it in.
                              I found on every one, the component U9 had failed! (after 6 hours of probing)
                              thought id post this up as i couldn't find a fix any other place!
                              Checked the service manual, U9 is a:
                              IC VOLTAGE INVERTER CHARGE PUMP UNREG TPS60403 SOT23-5
                              got mine from:
                              http://int.rsdelivers.com/product/te...5/5171208.aspx
                              soldered it in and jobs a good'n
                              Thanks for the help/service manual!
                                • Jun 2010
                                • 65
                                thanks burnt01
                                so did you also get a buzzing digital noise and all audio level meter LEDs light up as soon as you plugged the USB in?
                                i've still got the IO2 in my draw of parts, PCBs and broken stuff. i'll get it out again and have a look at U9.
                                Since my original post i've got a proper o'scope, a digital microscope (connects to composite video input on TV or TV card) and a proper voltage/current adjustable bench PSU.
                                i've got a feeling i might have recycled the aluminium case though thinking it's not fixable. i've also nicked the larger caps, USB connector and 6.3mm jacks/xlrs off it for other projects.
                                • hopper
                                  • Nov 2012
                                  Hi
                                  I have exactly the same problem with a friends' io2. It seems like a very common failure. Some valuable information here on dealing with it though I am wary of soldering surface mount devices without a better soldering iron (and vision!) than I currently have.
                                  Will see if I can get the part U9 and let you know how I get on. BTW, the way they use it in this circuit (particularly the caps around it) is rather different than recommended on the app notes. I wonder if this is contributing to the failures?
                                  • hopper
                                    • Nov 2012
                                    well, I did the replacement of part U9 - along with the caps around it (whilst taking care of the app note that says the flyback cap needs to have low esr) and after destroying one of the SM parts by poor soldering I got it working with the 2nd one! Certainly seems like a reliable fault on this unit.
                                    • joshbb
                                      • Apr 2013
                                      hi, thanks for the information relating to fixing these units.
                                      I am just about to fix one of these. Hopper: do you have any of those TPS60403 spare I could purchase? or anyone in the UK for that matter? cheers. Josh
                                      • markoCS
                                        • Jul 2017
                                        • Serbia
                                        Hi, have anyone measured the negative supply voltage after changing the TPS60403? It should be -4v but I'm getting -3.2v on two Alesis IO2 where I changed this IC.
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • Young_Silent_Made_IT
                                          Steinberg UR44 Audio Interface No Power.
                                          by Young_Silent_Made_IT
                                          I have a Steinberg UR44 audio interface that I had in storage for a few years, and now that I want to use it doesn't power on. I want to take this opportunity to learn electronics repair so I am trying to repair it for learning experience.
                                          I am looking for guidance on how to proceed with troubleshooting the problem.
                                          I have checked the original power supply with a multi meter and it works.
                                          I visually inspected the PCB board and don't see any issues, except what looks like a possible broken fuse but not sure. I checked it for continuity it reads 97 ohms, but...
                                          12-08-2023, 12:27 PM
                                        • snpulse3344
                                          USB Audio Interface - Steinberg UR 12 or similar schematics
                                          by snpulse3344
                                          I need to find out schematics diagram of Steinberg UR 12., pcb printed these numbers YAMAHA YF989 ZM60700, I searched everywhere but I didn't find the schematics of this USB audio interface, If anyone has it please let me know and if anyone has similar schematics diagram please let me know as well.
                                          03-01-2024, 01:07 PM
                                        • burntonnerings
                                          Behringer U-phoria UMC1820 Audio Interface
                                          by burntonnerings
                                          Need a schematic, service manual, and parts list if possbile
                                          11-08-2024, 11:10 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
