USB Audio Interface - Steinberg UR 12 or similar schematics
  • snpulse3344
    • 9
    • Sri Lanka
    I need to find out schematics diagram of Steinberg UR 12., pcb printed these numbers YAMAHA YF989 ZM60700, I searched everywhere but I didn't find the schematics of this USB audio interface, If anyone has it please let me know and if anyone has similar schematics diagram please let me know as well.
    • 31288
    what's wrong and what chip does it use?
    most usb audio devices use similar chips and the datasheets have schematics in them.
    • snpulse3344
      • 9
      • Sri Lanka
      yes, it turned on but it never connected to the computer through USB, I tried every way but it was not connected, It has nxp lpc1820fet100 Microcontroller based on Arm® Cortex®-M3(40pin), W BAND 250800VS16(IG) (8pin) IC and smsc usb2422 24 pin microchip. and I thank you reply me on this topic and for your kind attention.​
      • прямо
        • Sep 2022
        • 261
        • Indonesia
        Replace that SMSC USB2422 chip.
        • samson7point1@yahoo.com
          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
          by samson7point1@yahoo.com
          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
          The player processes the audio signal using two different reference frequencies. The "R"...
          04-30-2024, 11:22 AM
        • Shredder11
          BoardViewer Files Needed For M-Audio Ozonic Firewire Keyboard Audio Interface + Any Repair Tips
          by Shredder11
          As per title and also any tips on what to test first would be welcome on fixing this keyboard, which worked 100% and then upon the next power on, no display or response from keys, buttons, sliders, dials etc. However the Firewire audio interface section still works.
          Thanks.
          10-14-2025, 01:42 PM
        • Young_Silent_Made_IT
          Steinberg UR44 Audio Interface No Power.
          by Young_Silent_Made_IT
          I have a Steinberg UR44 audio interface that I had in storage for a few years, and now that I want to use it doesn't power on. I want to take this opportunity to learn electronics repair so I am trying to repair it for learning experience.
          I am looking for guidance on how to proceed with troubleshooting the problem.
          I have checked the original power supply with a multi meter and it works.
          I visually inspected the PCB board and don't see any issues, except what looks like a possible broken fuse but not sure. I checked it for continuity it reads 97 ohms, but...
          12-08-2023, 12:27 PM
        • Bonzadam
          iPad Air 4 a2324 Schematics diagram
          by Bonzadam
          Hello all Friend,
          I have a mainboard iPad Air 4 for repair the customer want to change his battery but broke some component near the battery connector. Boardview exist but no schematics for component specifications.
          Thanks for you help...
          12-13-2024, 03:05 PM
        • acata
          ASUS ROG Phone 5 ZS673KS schematics and diagram
          by acata
          Hi all..
          One of my costumer bring in an ASUS ROG Phone 5 ZS673KS liquid damage.
          After cleaning all of the components from water corrosion the device turn on with some crash capacitor.
          Unfortunately, the touchscreen not responding. While the display are fine without any glitch.
          I already searching here for any topic. But can't find any..
          Please help me to find the schematics & diagram.
          Thank you guys..
          12-30-2023, 04:54 AM
