Yamaha RX-A2A WN9711 Update
  • Plurxtc1
    • Oct 2014
    • 136
    I have a RX-A2A that doesn't do anything besides stuck with WN9711 Update. Any ideas I can get pass this screen?
  • CapLeaker
    Leaking Member
    • 8352
    Re: Yamaha RX-A2A WN9711 Update
    Looks like there is a TTL port on the lower left. Hook up to it and see what’s going on in there. I suppose you can’t do the reset procedure? You also could put the latest firmware on a USB stick and try to update it. Maybe someone tried to do an update, but then pulled the stick out or turned the unit off.
    • R_J
      • 9624
      The error would suggest the wireless lan had a problem, Try putting the firmware on a usb stick as suggested, or try connecting a network cable?
      See if this procedure works with this model:
      • Plurxtc1
        • Oct 2014
        • 136
        Repair is completed. There was a port on the board where I jumper the pins that allowed me to access the settings to complete to the update.
        • JakeShaw
          • Mar 2023
          • 8
          Excuse the necro but what pins did you end up jumping?
          Listening to Drab Majesty, Chime, Deftones, and other Rushdown Label artists. Professional tech.
          • milkybar1983
            • Mar 2023
            I have the exact same issue with an RX-V4A that I have replaced the HDMI board on
            Do you remember what pins it was please?
            • JakeShaw
              • Mar 2023
              • 8
              Here are the instructions. Took me a while to hunt it down. Should help for RX-V4A, TSR-400, RX-V6A, TSR-700, and RX-A2A showing a WN9711 update. Gotta program the EEPROM.
              • R0BBCC
                • May 2023
                will this work with yamaha rxa4a reading internal error? trying to locate the land but the guts look way different than the posted pics
                everytime i try to update firmware via usb the end result is error 100000 (one attempt yielded error 400000), and then internal error (once was wn9711)
                thx
                • rafaelmotaquintana
                  Rafael Mota Q
                  • Aug 2023
                  Thank you very much for this useful document.
                  I have a TSR-700 with internal error. Made the jumper and the message 'modeldesterror' appears.
                  When I press scene 1 or 2, I get only this
                  No model name to select.
                  The serial number is there and works, but not the models.
                  What do you sugest?
                  • R_J
                    • 9624
                    Did you do what it suggests on page 3? Press SCENE1 or SCENE2 key several times until the error message disappears.
                    • Angel13Azrael
                      • Nov 2023
                      • Puerto Rico
                      I have a Tsr-700 and even though I do the steps it only lets me input the serial number, for some reason it doesn’t let me change the model it just says _______________J
                      • sanalelevenstar
                        • Jul 2024
                        • 12
                        • INDIA
                        same issue my rx-v485 i cant find that soldering point
                        • m2d@mail.ru
                          • Jun 2023
                          • Россия
                          same issue my rx-v685 i cant find that soldering point
                          • kristophe03
                            • Mar 2025
                            • france
                            Hello did you find the location for soldering point?
                            • sanalelevenstar
                              • Jul 2024
                              • 12
                              • INDIA
                              yes its J260
                              • sanalelevenstar
                                Yamaha RX-V485 Wn9711 Update
                                by sanalelevenstar
                                Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                                I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                                I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                                12-04-2024, 04:32 AM
                              • akwky
                                by akwky
                                Hi!
                                04-14-2025, 01:56 PM
                              • ezenia
                                PS4 controller left stick potentiometer replacement issue
                                by ezenia
                                Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                                So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                                I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                                09-30-2023, 02:19 PM
                              • TheUser
                                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                by TheUser
                                Hello to everyone ,
                                This is my first post here, and i would like to share with you a small story in case you can help me.
                                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                02-10-2024, 02:07 PM
                              • traxformania
                                TONGFANG "GM7TG7P" Bios Password Problem?
                                by traxformania
                                I tried :
                                -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                11-15-2023, 07:32 AM
