Re: Help with blowing transistor NAD T752 receiver
yes that sucks when you try to repair something and then cause more damage...
when you say XXX volts on a 2-pinned device, it's assumed it's XXX volts across the device, but you're giving conflicting numbers and it's hard to tell what is what. When you give voltage numbers, need to be clear whether it's with respect to ground or across device.
Where is the full schematics to this, clicking on the ones near the top of the thread is only left/front channel...
Damn, while taking measurements on Q518 my probe slipped and I must have created a short, because I saw R544 get glowing hot, so I stopped everything and dissassembled now to find out that Q518 was fine, R544 had a burn mark but is still measuring 218ohms, however Q521 and Q522 were both shorted. Removed them and measurements seemed fine, so reinstalled without Q521 and Q522.
Lo and behold, now I get 55V on R5146. So the transistors need to be in to get an accurate reading of R5143 (left channel) or R5146 (right channel). Guess I might as well wait for them to get here (fortunately I bought 4 pairs) and retest when everything is in place. What do you think?Last edited by rddube; 09-13-2022, 08:26 AM.Leave a comment:
might be missing negative supply somewhere sending positive high .. open resistor or bad solder joint .Leave a comment:
use diode test to check transistors .Leave a comment:
I don't think Q506 is shorted as I measured it before resoldering a brand new one and it looked fine.
Really confusedhelp!!
" As for C and E of Q506 To GND, they both give 51.4V."
looks shorted to me .Leave a comment:
Yeah R5143 at 52V would explain roasting R520 and blowing the finals. They should be much closer together (i.e., voltage across closer to 0v) just like the right channel.
Since the voltage across Q506 is reasonable now I'd end up having to once again blame Q562, Q563, Q508 or Q507 badly leaking or shorted. What is the voltage of the two pins of R5143 with respect to GND? What are the voltages of C and E of Q506 WRT to GND (though doesn't quite make sense why it would cause R5143 to "roast" at 52V, even if it were way off.)Last edited by rddube; 09-12-2022, 07:56 PM.Leave a comment:
Since the voltage across Q506 is reasonable now I'd end up having to once again blame Q562, Q563, Q508 or Q507 badly leaking or shorted. What is the voltage of the two pins of R5143 with respect to GND? What are the voltages of C and E of Q506 WRT to GND (though doesn't quite make sense why it would cause R5143 to "roast" at 52V, even if it were way off.)Last edited by eccerr0r; 09-12-2022, 05:41 PM.Leave a comment:
Ok, so I finally got it to start but just a few seconds because now it stops and displays overheat, but I was able to take voltage measurements.
Between the collector and emitter of Q506 the voltage is .637V so I measure between the collector and emitter of Q518 (which is the right channel) and got .639V.
As for voltage at R5143, I read 52V ! So I took a reading at R5146 (right channel) and I don't get an immediate reading, it seems to be switching from but after a half second I get -6.08V?? What a difference!
So what do you think??Leave a comment:
those resistors will keep the feedback intact and hopefully zero the offset .
do not have any speaker loads connected and keep vol to minium ..if it comes out of protect you can try headphones at low level if it has a socket for thatLast edited by petehall347; 09-11-2022, 05:20 PM.Leave a comment:
Ok, so I'll do as Petehall347 suggests, i.e. 1k resistors from E to B on Q509 and Q510. Have to take it apart, so while I at it, can you confirm where you want me to take voltage measures i.e. voltage between the collector and emitter of Q506 and voltage across R5143? Is that it? I'll have to run some wires because with all boards installed I can't reach down there to take the measurements. Let me know and tks.!Leave a comment:
Ground the input (i.e. silent input) not output. The worry about the output is if the speakers are shorted or supplying enough load that it affects measurements, probably better to leave them off for now, or at least use higher impedance speakers.Leave a comment:
put 1k resistors from where base and emitters q509 q510 connect to on the board .Leave a comment:
So I spent a few hours trying to get it to start without the boards, endend up having to replace all boards and even then, it goes into protection mode because I suspect of Q509 and Q510 being absent. So I guess I'll have to wait for the replacements to come to be able to do further tests.
In a previous post, you mention that I might have to ground the ouput, do you mean the speaker outputs to ground? Tks!Leave a comment:
do whatever it takes to run without the case, but of course the heatsink needs to be attached.Leave a comment:
Oh and it's not my own iPhone, it's the Company's whom I work for...Leave a comment:
iphone... mmm...rich folks phone... not that I'd want one, signing away soul to use one...
but you should be checking voltages between the two channels, not just component values. Want to rule out broken traces too.Leave a comment:
Ok, so am waiting for the transistors to come in and when they do, will reinstall and take temperature and voltage measurements. At the places you asked me - I will solder thin insulated wires to be able to do so.
I changed the 220ohm resistor and been comparing all components of the left channel with the right channel, and haven't found anything to be wrong. Will report back when I get the transistors, but it should be within a few weeks!
BTW, the thermal camera I have is a Seek thermal camera that you plug into your iphone..works pretty well, but is not as precise as a dedicated thermal camera like the one Northbridgefix uses in his videos on Youtube.Leave a comment:
Well in the business, you do what you can do with what you have. If the 220Ω resistor is burned, leave it in and assume that stage is bad and keep going upstream to see what else is bad.
Note that the way this is designed, protection doesn't seem to protect the semiconductors, it only protects your speakers and your house from going on fire. Also if one of Q509 and Q510 burns and shorts out, the other one will burn shortly (pun not intended) too. Your audio will sound really distorted when one burns, and will go silent then protection shutdown when the other burns.
Keep comparing with the other channel. Voltages across the transistors between channels should be very similar when given the same input, and yes test with inputs grounded/silence to ensure there's nothing getting hot when quiescent.
Don't worry about overtightening the screw. I think if you have one of those thin handle screwdrivers like a tweaker screwdriver, if you tighten it as much as you can, it is tight enough. You can overtighten if you use one of those "construction" screwdrivers like what they use to screw wood together when building houses - don't use that for transistor heatsinks, only for tightening screw terminals.
damn... i'm so poor. can't believe i don't have a thermal camera yet...debugging would be so much easier with one of these...Last edited by eccerr0r; 09-09-2022, 08:33 AM.Leave a comment:
I also have to admit that Q509, the hole in the heatsink is worn so the screw holding it is not as tight as the others. Now that I have the right insulator pads with non conductive thermal grease, do you have any tricks on how I can get that screw to hold tighter? I've been using a wooden toothpick and not tightening too tight so as not to lose the grip. Maybe it's Q509 that trips Q510 and not the other way around?Leave a comment:
by CdDvdFlashFor this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
by magnehHello
Got this speaker from a friend , defective. Power led comes on and off , in a loop.
Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
Still, I need to replace this transistor.... -
by JayPoorJayHello All... Grateful for this site!
I just repaired a 70inch Sharp flat screen I found on the curb in NYC (there are 1000s) thanks to the good folks on this site
I have a question about an audio signal from a TV that only has a headphone jack as a audio output source. I have it hooked up now with a headphone style adapter that converts the headphone plug to an RCA. I plug this into my PHONO input on the receiver. To play it this way I need to turn volume waaaay down on TV and volume up higher than I think I should on the receiver. I get undertone hissy sound, blunt...-
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the āEā stops and one switching power (24 volt) supply and a transformer... -
by r2digitalHello, i had this amp sitting in the closet knowing that none of the channels were working. After taking it all apart i found 4 bulging main filter caps so i went ahead and replaced those with low ESR kmet caps. However after doing this it only restored sound to Surround L, Surround R, and Center channel. The main speaker fuse on the transformer F905/F906 keeps blowing so i decided to remove all of the transistor's on those 4 channels and measure them. All transistors appear to be in good working order(turned receiver on with none of them installed and fuse still blows). Checked dual emitter resistors...
- Loading...
