Help with blowing transistor NAD T752 receiver
  • rddube
    replied
    Re: Help with blowing transistor NAD T752 receiver
    While I remove the board, I'll remove R518 and check it out of circuit just to make sure.
  • rddube
    replied
    My test meter is a Fluke 87V, so I think it is ok. Tried it with another one I have a Uni-T and it does the same thing - as soon as I connect both probes from the meter, it goes into protection mode. R518 measures 3.275K so I think it is ok.
    The hole near C572 is the hole to insert the screw that holds the transistors to the heat sink, it is a pass throught hole.
    So the only thing left, is a flaky Q506 because I didn't short my probes again. When I do the same type of reading on Q518 it doesn't do this - it gives a reading and stays on green light.
    So I guess I'll replace Q506 and try it again. Will report back later.
  • eccerr0r
    replied
    A good test meter should not cause going into protection mode. Maybe you have a flaky Q506 or shorted your probes to something again?
    Perhaps a broken R518 would also cause the device to go into protection.
    BTW that hole near C572/R528 looks very suspicious, if there is a screw there, is it shorting C572 with that jumper J48?
  • rddube
    replied
    How weird can you get, as soon as I attach my probes across Q506 and try and start it, it gives me no voltage reading and goes immediately into protection mode (red light). If I detach my probes, it starts up with green light ??? I tried to take a reading across Q518 and got -3.35V and the amp started normally (green light)...what's going on?
  • rddube
    replied
    Originally posted by eccerr0r
    As in previous messages still would like to know the voltage at Q504-E (or voltage at R513) and what happens to the voltage across Q506 as you change R522. Yes the spread is wrong compared to the other channels, but I'm at a loss as why all the transistors are good except that it burns the finals. Again the closer the voltages are together on Q506, the safer for the downstream transistors, but it produces odd-order harmonics in your music when playing which may be unacceptable to your ears.
    Sorry Eccerr0r, had missed your question about this. So the voltage at R513 is -61.25 and at Q504-E it is -60.86V.
    Will do measurements across Q506 as I change R522 and report back in a few minutes
  • eccerr0r
    replied
  • rddube
    replied
    Eccer0r and Petehall347, do these readings look ok to you? The only one that is close to 600mv is the left channel (Q506), in fact it is below, but it is positive on C and on E, and also on each side of the resistor, whereas the other two channels have positive and negative on each side but are more in the 1.7V area. Not sure how to interpret this, is there something wrong with the negative side of the left channel? Many thanks for your input!
  • rddube
    replied
    So here are my latest measurements with the .22 ohm resistor changed and after having removed and checked Q506, Q507, Q508, Q562 and Q563 to be good:
    Q506 C to gnd +0.465V
    E to gnd +0.389V
    Q518 C to gnd +1.7V
    E to gnd -1.57V
    Q530 C to gnd +1.785V
    E to gnd -1.63V
    Looking at board such as the photo I uploaded:
    R5143 from left to gnd +0.365V
    from right to gnd +0.386V
    R5146 from left to gnd -1.04V
    from right to gnd -1.05V
    R5149 from left to gnd -1.052V
    from right to gnd -1.053V
    Q504 B to gnd -62.7V
  • rddube
    replied
    Whenever you measure a resistor, it needs to be measured out of circuit. Too many side paths will affect your measurement. I kind of expected that emitter resistor to affect your reading and there was never a "short" on the right channel.
    So it looks like the fried transistors fried the resistor too.
    and yes, the skewed in-circuit measurement of the resistors with that hack added would affect reading, my calculation resulted in around 198Ω which matches up quite well within about 1% of 196Ω.
    Ok, thank you for the explanation, I'm learning a lot while doing this thanks to you! So I think we are in business, will take measures again and report back - just got notice that the finals have arrived in Canada, so probably next week will be here. Thanks again!
  • rddube
    replied
    just so you know those double resistors also known as emitter resistors in this case are 0.22 ohms . the k is tolerance .
    Oh sorry, my bad, you are right they are 0.22 ohms, and that is what I installed!
  • petehall347
    replied
  • eccerr0r
    replied
  • rddube
    replied
    Ok, so I think I finally found the problem in that the .5K measured on the 1K resistors seems to be ok - explanation: right channel was giving .5K on those resistors while the left channel was giving me 1K...searched everywhere only to find out that the .22K double resistor on the left channel R527 was open! Fortunately I had a spare one and replaced it and now both the right and left channel read .5K on the 1K resistors when installed.
    Everything seems to balance well, but now R520 and R544 measure 196 ohms, while R573 (the center and good channel) measures 217 ohms, not too sure why but is this normal with 1K resistors instead of finals?
  • rddube
    replied
    Hold on gentlemen, I removed the board and checked some components only to find that on the right channel, I have a partial short as the 1K resistors I installed measure .5K instead of 1K. I have to trace it down now.
    Don't spend too much time analyzing the left channel (Q510/Q509) as I have to get rid of this short.
    Will be back with new measurements once I find it. Sorry for the inconvenience.
  • rddube
    replied
    Check your component designators and signs again, you have R5143 listed twice and you have +-4.41V for Q518-C. Assuming you meant -4.41V, the C-E drops all look reasonable now though the "second" R5143 spread looks too close. Again something doesn't look right, when the spread is close the transistors should be safe from destruction.
    Now Q504-B is way too high, it should be -65+1.4 = about -63V, but the voltages downstream do not seem to correspond to Q504 being turned on...
    Hello Eccerr0r,
    Sorry was trying to go too fast, here are the corrections to my voltages that I checked again:
    Q506 C to gnd +1.51V
    E to gnd -1.451V
    Q518 C to gnd -4.41V
    E to gnd -7.92V
    Q530 C to gnd -3.97V
    E to gnd -7.44V
    R5143 from left to gnd -6.5V
    from right to gnd -5.82V
    R5146 from left to gnd -4.4V
    from right to gnd -3.2V
    R5149 from left to gnd -3.2V
    from right to gnd -3.1V
    Q504 B to gnd -6.2V
    Q504B is -6.2V not -62V.
  • eccerr0r
    replied
  • rddube
    replied
    Ok, so here are my measurements with 1K resistors from Base to Emitter on Q509 Q510 and Q521 and Q522:
    E to gnd -1.451V
    Q518 C to gnd +-4.41V
    E to gnd -7.92V
    E to gnd -7.44V
    R5143 from left to gnd -3.2V
    Q504 B to gnd -6.2V
    I double checked again every measurement.
  • eccerr0r
    replied
    Okay that is a clue that something's still wrong with the R522 channel unlike the R545 channel. Spread is too low.
    Next I'd be curious what the voltages are on R513, hopefully both are way negative... If they are, Q504 is probably bad. If they aren't, R513 is bad.
    ... but still not quite sure why this would cause final roasting... more data needed...
  • rddube
    replied
    H Is the relative position of the R522 potentiometer close to the position of the R545 potentiometer (don't touch either for now, just look at position). Perhaps R522 is turned all the way down for 1KΩ and hence the voltages are so close.
    Forgot to answer this question...yes the position of the the potentiometers is close as seen in the photo (the one on the right is R522).
  • petehall347
    replied
    yes base to emitter. don't adjust anything yet .
  • wolf1976
    wireless receiver for 6 speeds fan control with remote control
    by wolf1976
    hi i have a receiver that is destroyed from the overvoltage i guess
    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
    the motor fan has not label
    i have an other receiver operational
    In your opinion can i measure the voltage at the output ?
    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
    thanks in advance...
    07-23-2025, 03:12 PM
  • CdDvdFlash
    DSE GE6878 possible TV receiver dying remote not working well
    by CdDvdFlash
    For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
    07-03-2024, 03:55 AM
  • magneh
    Behringer Eurolive B205D repair - help identifying transistor
    by magneh
    Hello
    Got this speaker from a friend , defective. Power led comes on and off , in a loop.
    Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
    After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
    I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
    Still, I need to replace this transistor....
    06-18-2025, 02:34 AM
  • JayPoorJay
    TV that only has headphone out to receiver/amp
    by JayPoorJay
    Hello All... Grateful for this site!
    I just repaired a 70inch Sharp flat screen I found on the curb in NYC (there are 1000s) thanks to the good folks on this site
    I have a question about an audio signal from a TV that only has a headphone jack as a audio output source. I have it hooked up now with a headphone style adapter that converts the headphone plug to an RCA. I plug this into my PHONO input on the receiver. To play it this way I need to turn volume waaaay down on TV and volume up higher than I think I should on the receiver. I get undertone hissy sound, blunt...
    02-20-2022, 09:03 AM
    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
    by sam_sam_sam
    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
