TV that only has headphone out to receiver/amp
  • JayPoorJay
    • Jan 2022
    • 149
    Hello All... Grateful for this site!
    I just repaired a 70inch Sharp flat screen I found on the curb in NYC (there are 1000s) thanks to the good folks on this site
    I have a question about an audio signal from a TV that only has a headphone jack as a audio output source. I have it hooked up now with a headphone style adapter that converts the headphone plug to an RCA. I plug this into my PHONO input on the receiver. To play it this way I need to turn volume waaaay down on TV and volume up higher than I think I should on the receiver. I get undertone hissy sound, blunt sounds from speakers when I turn the thing off and on,,, it's not good - I'm afraid of damage to the receiver due to too much power from the headphone output to an input that is supposed to be minimally amped, all that.
    QUESTION: Is there a simple device I can purchase that can be put between the headphone jack and the receiver that will reduce the signal strength going into the receiver?
  • budwich
    • Jul 2015
    • 3097
    Re: TV that only has headphone out to receiver/amp
    what model of tv is it? Why are you using a phono input and not a regular "aux type" input. Depending on the receiver, the phono input has certain impedance requirements and resulting preamp gains before heading towards the main amp section.
    • JayPoorJay
      • Jan 2022
      • 149
      Hey Man. Thanks.
      When I use the AUX ports on the back of the Sony receiver I get NO sound. It's strange. I thought that would be my inlet... It's a "INSIGNA" TV. Cheap, but it's working for me...
      • petehall347
        • Jan 2015
        • 4451
        do not plug into phono as that's low level input for playing records . plug into aux or whatever other input it has .
        • budwich
          • Jul 2015
          • 3097
          Originally posted by JayPoorJay
          Hey Man. Thanks.
          you likely turned down the tv volume too low for the "aux" rca inputs to provide proper signal. try turning the tv volume back up to near max. It should work albeit would be not the greatest sound because there will still be a mismatch of expected impedance but should be usable. As posted, the phono input for most amps will usually not be a good input for any other signal type than a record player due to design intent (impedance, equalization and gain).
          without the actual model number of the set, it hard to give any other possible solution.
          • JayPoorJay
            • Jan 2022
            • 149
            Thank you! You nailed it, and I feel dumb...
            I swapped around the wires, turned the tv volume up to near max,,, low and behold - there was sound! A much much better (no more hiss - or clunk when I turn the TV off with eceiver on) than what it was, tho it still ain't right...as you say, for the reasons you say. Thanks much.
            Jason
            • nams2590
              Numark Party Mix Headphone Issue
              by nams2590
              I recently bought a Numark Party Mix Controller, but I don't have any headphone working.
              I've already replaced the headphone connector and the headphone flex cable, but this is still not working.
              Do you have any idea about what to check or does someone has the schematic?
              Thanks a lot for your help.
              Fabien
              09-04-2025, 01:38 PM
            • CDNBrewer
              Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
              by CDNBrewer
              Hello Everyone,
              I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
              Symptoms:
              • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
              • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
              • I swapped the Left and Right surround
              08-05-2025, 09:29 PM
            • wolf1976
              wireless receiver for 6 speeds fan control with remote control
              by wolf1976
              hi i have a receiver that is destroyed from the overvoltage i guess
              my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
              the motor fan has not label
              i have an other receiver operational
              In your opinion can i measure the voltage at the output ?
              what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
              thanks in advance...
              07-23-2025, 03:12 PM
            • Tom_x
              Rotel RSDX-02E headphone mode
              by Tom_x
              Hi!
              I need help to disable headphone mode on this unit!
              Someone played buttons on front panel and now no sound on speakers. When i push the Surround button, only HEADPHONE MODE appear
              Amplifier does not have headphone connector in front, only 3-pin on main board and factory grounded the hpsw line
              i tried all combination on front panel, but no success....
              In sevice manual no info about full reset, only reset speakers settings to default.
              Anyone have info?
              regards
              Tom
              12-22-2024, 11:33 PM
            • CdDvdFlash
              DSE GE6878 possible TV receiver dying remote not working well
              by CdDvdFlash
              For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
              07-03-2024, 03:55 AM
