Help with blowing transistor NAD T752 receiver
  • rddube
    Aspiring Expert
    • Jun 2013
    • 950
    Re: Help with blowing transistor NAD T752 receiver
    Originally posted by eccerr0r
    Can't believe this amp is so much bad news... Likewise other channels, R573 is also a symptom of frying finals, and I'm beginning to think reassembly/disassembly is putting a toll on the boards causing opens and then destruction..
    I think you're right Eccerr0r, so do you think I should just install 1K resistors and use the surround channels? Everytime I dissassemble, I have to push tos 5W resistors down then up when I have screwed in the finals to the heatsink and I did discover a transistor Q528 that had been "ripped" out of the board that I rebuilt the connections.
    So what do you think, we've played enough with this guy? Thanks again for your advice.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      A removed Q528 would simply cause silence on the center channel.
      BTW are you testing with the speaker attached or not? The protection system doesn't necessarily protect against all DC conditions.
      What are the specs of the speakers you're using, anyway (impedance and max wattage)?
      It's still up to you but I can't protect you from destroying stuff by disassembly and reassembly. It makes it that much harder to troubleshoot when you're causing more problems as now they too need to be fixed. Ideally you set it up such that you can run the guts without the case and never reassemble until you're confident it's working 100%...
      • rddube
        Aspiring Expert
        • Jun 2013
        • 950
        At first I was testing without speakers attached, but when the incident happened I had 2 speakers attached to the left and right channel, 4 ohms 100W speakers.
        Unfortunately I don't think I can set it up outside the case, so I'll have to pass on that idea but it would have been ideal.
        So I'll simply remove the shorted transistors reassemble and will use the surround channels - anyhow I wasn't intending to use this amp for all the channels, but I think I can use the left and right channels pretty much like the front right and left channels. I'll see what it gives and if not acceptable, I'll keep it for parts. Thanks Eccerr0r!
        • petehall347
          • Jan 2015
          • 4440
          #144
          its rated for 8 ohms so your 4 ohm speakers are likely the culprit . am sure i asked about speakers earlier on .
          • rddube
            Aspiring Expert
            • Jun 2013
            • 950
            From the NAD website:
            All NAD amplifiers/receivers are rated for a minimum speaker impedance of 4 Ohms.
            Mine are Rock Solid B&W speakers and measure exactly 4.8 ohms, so I don't think they are the culprit but I may be wrong? I did use the same speakers on the surround channels (Right and Left) with quite a bit of output and they are still working (the channels and the speakers), so I think the problem is elswhere and probably what Eccer0r mentionned about stress on the board because I have had to retrace a number of broken traces created from removing finals, transistors, burnt resistors, etc.
            • petehall347
              • Jan 2015
              • 4440
              #146
              some speakers are hard to drive . the static ohms isnt the same as impedance .some can drop to very low impedance whilst being driven ,
              hard to say really .
              maybe go back to the point of it being blown up in the first place to look for clues .
              • rddube
                Aspiring Expert
                • Jun 2013
                • 950
                Hey Petehall347, I think you might be on to something, as I remeasured mys Rock Solid speakers and they were below 4 ohms, down to 3.2 ohms. I know you mentionned there is a difference between resistance and impedance, but that is below 4 ohms which is not recommended by the manufacturer. Well gess what, I had them on the surround L and R channels, and both channels blew leaving only the subwoofer working now. Fudge..........
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  It depends on how many watts you're trying to pump into the speakers. At lower volumes, low impedance speakers won't do much more harm than running higher impedance speakers at higher volume. Ultimately you need to balance designs of the amp and the speaker.
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 950
                    I actually used them at very low volume every time I tested, and also tested with Tannoy C6 speakers. So I guess there's no purpose in fixing this amp, it seems to be all over the map...first it's the left channel that goes, then replace everything, then it's the right channel not working..then the center channel burns finals and now the surround L & R that stopped working. Ouf, maybe there's something wrong with the 60V rail?
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      No, I'm pretty sure it's simply disassembly-reassembly sloppiness.
                      • petehall347
                        • Jan 2015
                        • 4440
                        #151
                        reading your first post again things looked to go wrong pretty soon after you adjusted the idle currents ..maybe your meter isnt good enough . or you read it wrong .
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Probably not -- they designed it such that it's impossible to fry finals by setting the idle current wrong. Normally shorting or turning all the way down of the idle current pot - R522 - would result in final frying. However they put in R519 to ensure they survive even if you turned it down all the way.
                          I can't think of any possible way of destroying the finals by setting the idle current wrong, so only thing I can think of are things like (for the left channel, of course the other channels have their own corresponding devices):
                          - breaking or disconnecting R518
                          - breaking (disconnecting) of Q506 collector or base or otherwise shutting it off completely
                          - breaking R5143
                          - breaking R520 (but it was burned, so something upstream, i.e. one of the above has occurred).
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 950
                            Ok, you might say he's nuts but what the heck I decided to give this thing another shot. Turns out the surround channels are not blown at all, since they weren't playing I assumed they were shot, but it was a setting and they are fine, they play very well.
                            On the Front Center board (which is my problem board) the left channel seems to be so so ok, as it plays but very distorted - this may be caused by the right channel which is not playing but finals are ok or the center channel for which both finals are blown and one side of R574 is also blown. I'm going to attempt another repair and then check what Eccerr0r said in the previous post on each channel:
                            - breaking R5143
                            - breaking R520 (but it was burned, so something upstream, i.e. one of the above has occurred)."
                            Will report back.
                            • rddube
                              Aspiring Expert
                              • Jun 2013
                              • 950
                              After a few weeks of trying pretty much everything, I was unsuccessful in bringing this receiver back alive, so throwing in the towel and will use it for parts recycling. Thanks again to those who have tried to help me! Regards!
                              • petehall347
                                • Jan 2015
                                • 4440
                                #155
                                • rddube
                                  Aspiring Expert
                                  • Jun 2013
                                  • 950
                                  Question for you Petehall347: your idea of putting in 1K resistors instead of finals, is that to make the amp think there are finals so that it won't go into protection mode?
                                  I could probably do this, and just use the surround L + R channels? Right now, I took out the finals that went short on the Front/Center amp out, and when I try to start the amp, it goes into protection mode after a few seconds.
                                  • petehall347
                                    • Jan 2015
                                    • 4440
                                    #157
                                    the resistors keep the feedback intact so then the dc offset can stabilise along with other voltages .
                                    without the resistors and outputs the protect shouldn't see any dc offset so not needed .
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 950
                                      Well, in the end got the amp working again on the surround R + L channels, so am using it as a stereo system with 2 speakers and sub woofer. Sounds pretty good. Not completely lost
                                      Tks guys!
                                      • petehall347
                                        • Jan 2015
                                        • 4440
                                        #159
                                        well done
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                        • wolf1976
                                          wireless receiver for 6 speeds fan control with remote control
                                          by wolf1976
                                          hi i have a receiver that is destroyed from the overvoltage i guess
                                          my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                          the motor fan has not label
                                          i have an other receiver operational
                                          In your opinion can i measure the voltage at the output ?
                                          what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                          thanks in advance...
                                          07-23-2025, 03:12 PM
                                        • CdDvdFlash
                                          DSE GE6878 possible TV receiver dying remote not working well
                                          by CdDvdFlash
                                          For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                          07-03-2024, 03:55 AM
                                        • sanalelevenstar
                                          Yamaha RX-V485 receiver. After encountering a "version error"
                                          by sanalelevenstar
                                          I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                                          After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                                          I managed to find the service...
                                          09-10-2025, 01:54 AM
