Help with blowing transistor NAD T752 receiver
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Help with blowing transistor NAD T752 receiver
    Yeah I typoed that, good to always doublecheck any lies spewed on the internet
    • rddube
      Aspiring Expert
      • Jun 2013
      • 950
      Eureka, with everything soldered right I get between E and C of Q506 +2.1V when R522 is at the 1.2K level (fully clockwise), +2.5V when at +- 0.800K level (about mid turn) and +2.75V when set like the other 2 channels...I didn't go over that just in case.
      What do you think Eccerr0r ?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Well, worst case is you fry R520 but you should be able to go the full gamut like the other channels, but it shouldn't be able to get so high to do that if it were designed properly and no bad components. Well, if it matches the other channels now approximately it should be ok, just check the voltages at Q507/Q508 bases and the two ends of R520 to ensure the spread is less than what you see at Q506, then you're probably good to try reinserting finals.
        • rddube
          Aspiring Expert
          • Jun 2013
          • 950
          Ok, so Q507 gives me +2.78V and Q508 (good channel - center) +2.972V. Each side of R520, I get -0.244V and -0.156V.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            I think we're back to square 1, and still have more unknown issues unless you can properly adjust the spread via R522. Q506 C-E spread should be around 4.2V and adjustable by R522. The voltage drop across R5143 should be around 2.8V and finally the voltage drop across R520 should be around 1.4V, both of these should be likewise adjusted with R522. Just ensure that you can adjust these voltages, and then turn it down as low as possible before putting the new finals in. You should be able to hear that the audio sounds awful with harmonics and then as you increase the voltage it should start sounding less harsh and raspy, making it sound good once more. Of course you should ultimately follow the service manual's R522 adjustment by using P501.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 950
              Sorry again Eccerr0r, I just realised you asked for Q507 and Q508, and I wrongly assumed you meant the same as Q506 on the other channels, so I measured C-E of Q518 and C-E of Q530 and reported them as Q507 and Q508. I can't measure Q507 and Q508 because they are deep down under.
              So what I just did is compare what I get on Q506 C-E when I change R522 to Q518 when I change R545 and get exactly the same readings i.e. 2.1V when turned completely clockwise which gives a resistance on R522 and R545 of 1.3K, and 2.75V when R522 and R545 are set like the good channel R571. When I measure C to E on the good channel, I get +2.9V.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                very well, if both right and left match, reduce both to the lowest voltage and then put in the new transistors, and carefully monitor their temperatures as you power up. If they still get hot fast, shut off right away. If they don't get hot, go through the bias tuning in the service manual.
                • rddube
                  Aspiring Expert
                  • Jun 2013
                  • 950
                  ok, got it. Will report back in a few days when the finals get here. Thanks again for all you help Eccerr0r!!
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 950
                    Question for you Eccerr0r - when I put the finals in place (should get here tomorrow), do I leave the test wires I had put on Q506, Q518 and Q530? Also, should I replace all boards or test it with minimal boards?
                    I guess I should, but that means I will have to dissassemble it again if everything is ok, but I'd like to have your advice on this. Thanks!
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Probably okay to remove them but best to keep them in... in case things haven't been totally solved yet. If you're confident the L + R channels match in behavior now which is close to C channel, then you probably can remove the test wires.
                      One thing that you might want to do is put a meter on each of the bias resistors, i.e. P501/P502 test pins, and ensure it doesn't go up to a few volts when you power up for the first time after installing the finals...if it does you need to shutdown right away and look for the problem... Do not use autoranging.
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 950
                        Ok, so did everything by the book, kept the connectors in to test voltages and so on comparing to the good center channel, and all seemed fine. Proceeded to adjust bias, and was able to adjust bias just like in the manual. Checked temperatures, everything looked cool.
                        Removed the board to take out the connectors, reassembled everything nice and neat, rechecked bias before connecting speakers, everything seemed perfect. Connected speakers, powered it up and only the left channel was giving sound and not perfect sound.
                        Redid the bias adjustment being careful to follow the instructions exactly, same result.
                        So I am getting discouraged, not too sure what's wrong this time. If it wasn't for you Eccerr0r, I would probably send this damn thing to recycling. Is there any hope? Tks again!
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Now for debugging stuff like this you need all those jumpers again so you can measure voltages...
                          And the right tool for this is probably an oscilloscope (and a sine wave signal generator) so you can see where the signal distorts or disappears...
                          But posting voltages at different points of each transistor in the path is what's needed to see where the voltages seem out of whack?
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 950
                            I do have an osciloscope and a sine wave signal generator. Can i do this with the board out as there is not much room to go measure on the board itself when it's installed deeply into the receiver?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Nope, have to do it in situ, powered up...
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 950
                                After a few more tests, trying to adjust bias while monitoring temperatures which were ok, the finals on the left channel popped and now they are shorted again - both. So I give up, will use the surround amplifier instead to listen to music.
                                Thank you very much to Eccerr0r for all your time and to Pethall347. It has been a long journey which doesn't end like a fairy tale, but what the heck you can't win'em all! Thanks again!
                                • petehall347
                                  • Jan 2015
                                  • 4440
                                  #136
                                  the new transistors could be fakes ..
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Something still doesn't seem right, if you were monitoring the voltage across the resistor and shut down immediately if you saw anything but a few millivolts, should have been able to save it. Having R520 burn out also will kill the finals so that should have been your clue... did you ever fix that problem? Should have been able to run the amplifier without the finals and R520 should not have been burning hot.
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 950
                                      Sorry guys, got confused and didn't realize that it's not the left channel that went berzerk, it's the center channel Q533 and Q534 that are short.
                                      R520 wasn't heating up, and the left channel was working, the right channel was not (no sound) and it's while adjusting the bias on the right channel and monitoring heat and voltage, that the center channel popped. This was the good channel up until now.
                                      So I am really confused. No heating, but I think I saw a glow somewhere in the middle of the card when it happened, but can't find any trace of heat or burnt mark????
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 950
                                        Also R574 is open on the side that connects to Q533. The other side is ok....
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8701
                                          Can't believe this amp is so much bad news... Likewise other channels, R573 is also a symptom of frying finals, and I'm beginning to think reassembly/disassembly is putting a toll on the boards causing opens and then destruction..
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
                                          • wolf1976
                                            wireless receiver for 6 speeds fan control with remote control
                                            by wolf1976
                                            hi i have a receiver that is destroyed from the overvoltage i guess
                                            my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                            the motor fan has not label
                                            i have an other receiver operational
                                            In your opinion can i measure the voltage at the output ?
                                            what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                            thanks in advance...
                                            07-23-2025, 03:12 PM
                                          • CdDvdFlash
                                            DSE GE6878 possible TV receiver dying remote not working well
                                            by CdDvdFlash
                                            For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                            07-03-2024, 03:55 AM
                                          • sanalelevenstar
                                            Yamaha RX-V485 receiver. After encountering a "version error"
                                            by sanalelevenstar
                                            I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                                            After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                                            I managed to find the service...
                                            09-10-2025, 01:54 AM
