Help with blowing transistor NAD T752 receiver
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Help with blowing transistor NAD T752 receiver
    Well in the business, you do what you can do with what you have. If the 220Ω resistor is burned, leave it in and assume that stage is bad and keep going upstream to see what else is bad.
    Note that the way this is designed, protection doesn't seem to protect the semiconductors, it only protects your speakers and your house from going on fire. Also if one of Q509 and Q510 burns and shorts out, the other one will burn shortly (pun not intended) too. Your audio will sound really distorted when one burns, and will go silent then protection shutdown when the other burns.
    Keep comparing with the other channel. Voltages across the transistors between channels should be very similar when given the same input, and yes test with inputs grounded/silence to ensure there's nothing getting hot when quiescent.
    Don't worry about overtightening the screw. I think if you have one of those thin handle screwdrivers like a tweaker screwdriver, if you tighten it as much as you can, it is tight enough. You can overtighten if you use one of those "construction" screwdrivers like what they use to screw wood together when building houses - don't use that for transistor heatsinks, only for tightening screw terminals.
    damn... i'm so poor. can't believe i don't have a thermal camera yet...debugging would be so much easier with one of these...
    • rddube
      Aspiring Expert
      • Jun 2013
      • 950
      Ok, so am waiting for the transistors to come in and when they do, will reinstall and take temperature and voltage measurements. At the places you asked me - I will solder thin insulated wires to be able to do so.
      I changed the 220ohm resistor and been comparing all components of the left channel with the right channel, and haven't found anything to be wrong. Will report back when I get the transistors, but it should be within a few weeks!
      BTW, the thermal camera I have is a Seek thermal camera that you plug into your iphone..works pretty well, but is not as precise as a dedicated thermal camera like the one Northbridgefix uses in his videos on Youtube.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        iphone... mmm...rich folks phone... not that I'd want one, signing away soul to use one...
        but you should be checking voltages between the two channels, not just component values. Want to rule out broken traces too.
        • rddube
          Aspiring Expert
          • Jun 2013
          • 950
          Ok, so do you think I can plug it back in without all the otherboards (just the main board) and without q509 and q510 to take measurements? That would leave me with a lot of space to take those measurements.
          Oh and it's not my own iPhone, it's the Company's whom I work for...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            do whatever it takes to run without the case, but of course the heatsink needs to be attached.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 950
              So I spent a few hours trying to get it to start without the boards, endend up having to replace all boards and even then, it goes into protection mode because I suspect of Q509 and Q510 being absent. So I guess I'll have to wait for the replacements to come to be able to do further tests.
              In a previous post, you mention that I might have to ground the ouput, do you mean the speaker outputs to ground? Tks!
              • petehall347
                • Jan 2015
                • 4440
                #47
                put 1k resistors from where base and emitters q509 q510 connect to on the board .
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Ground the input (i.e. silent input) not output. The worry about the output is if the speakers are shorted or supplying enough load that it affects measurements, probably better to leave them off for now, or at least use higher impedance speakers.
                  • rddube
                    Aspiring Expert
                    • Jun 2013
                    • 950
                    Ok, so I'll do as Petehall347 suggests, i.e. 1k resistors from E to B on Q509 and Q510. Have to take it apart, so while I at it, can you confirm where you want me to take voltage measures i.e. voltage between the collector and emitter of Q506 and voltage across R5143? Is that it? I'll have to run some wires because with all boards installed I can't reach down there to take the measurements. Let me know and tks.!
                    • petehall347
                      • Jan 2015
                      • 4440
                      #50
                      those resistors will keep the feedback intact and hopefully zero the offset .
                      do not have any speaker loads connected and keep vol to minium ..if it comes out of protect you can try headphones at low level if it has a socket for that
                      • rddube
                        Aspiring Expert
                        • Jun 2013
                        • 950
                        Ok, so I finally got it to start but just a few seconds because now it stops and displays overheat, but I was able to take voltage measurements.
                        Between the collector and emitter of Q506 the voltage is .637V so I measure between the collector and emitter of Q518 (which is the right channel) and got .639V.
                        As for voltage at R5143, I read 52V ! So I took a reading at R5146 (right channel) and I don't get an immediate reading, it seems to be switching from but after a half second I get -6.08V?? What a difference!
                        So what do you think??
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Yeah R5143 at 52V would explain roasting R520 and blowing the finals. They should be much closer together (i.e., voltage across closer to 0v) just like the right channel.
                          Since the voltage across Q506 is reasonable now I'd end up having to once again blame Q562, Q563, Q508 or Q507 badly leaking or shorted. What is the voltage of the two pins of R5143 with respect to GND? What are the voltages of C and E of Q506 WRT to GND (though doesn't quite make sense why it would cause R5143 to "roast" at 52V, even if it were way off.)
                          • rddube
                            Aspiring Expert
                            • Jun 2013
                            • 950
                            Ok so the two pins of r5143, one side is 51V and the other side is 55V. As for C and E of Q506 To GND, they both give 51.4V. And I had removed Q562 and Q563 and Q508 and Q507 and installed brand new ones even though they had tested good. I had to redo some traces as the pads lifted on Q508 and q509, maybe I fumbled something there however I had taken all resistance measurements (without Q509 and Q510 however) and everything seemed ok. What could it be?
                            • petehall347
                              • Jan 2015
                              • 4440
                              #54
                              " As for C and E of Q506 To GND, they both give 51.4V."
                              looks shorted to me .
                              • rddube
                                Aspiring Expert
                                • Jun 2013
                                • 950
                                Q506 measures from C to E .825K and Q518 from C to E measures .821K. Please note that I do not have 1K resistors on Q509 and Q510 as I was able to start it without them, except that it goes into overheat.
                                I don't think Q506 is shorted as I measured it before resoldering a brand new one and it looked fine.
                                Really confused help!!
                                • petehall347
                                  • Jan 2015
                                  • 4440
                                  #56
                                  use diode test to check transistors .
                                  • petehall347
                                    • Jan 2015
                                    • 4440
                                    #57
                                    might be missing negative supply somewhere sending positive high .. open resistor or bad solder joint .
                                    • rddube
                                      Aspiring Expert
                                      • Jun 2013
                                      • 950
                                      Damn, while taking measurements on Q518 my probe slipped and I must have created a short, because I saw R544 get glowing hot, so I stopped everything and dissassembled now to find out that Q518 was fine, R544 had a burn mark but is still measuring 218ohms, however Q521 and Q522 were both shorted. Removed them and measurements seemed fine, so reinstalled without Q521 and Q522.
                                      Lo and behold, now I get 55V on R5146. So the transistors need to be in to get an accurate reading of R5143 (left channel) or R5146 (right channel). Guess I might as well wait for them to get here (fortunately I bought 4 pairs) and retest when everything is in place. What do you think?
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        yes that sucks when you try to repair something and then cause more damage...
                                        when you say XXX volts on a 2-pinned device, it's assumed it's XXX volts across the device, but you're giving conflicting numbers and it's hard to tell what is what. When you give voltage numbers, need to be clear whether it's with respect to ground or across device.
                                        Where is the full schematics to this, clicking on the ones near the top of the thread is only left/front channel...
                                        • rddube
                                          Aspiring Expert
                                          • Jun 2013
                                          • 950
                                          Voltages on R5143 and R5146 is relative to ground on one end of the resistor (I can't see the point of measuring across a resistor, but maybe I'm mistaking?). Attached is the full service manual with all schematics. Tks.
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
                                          • wolf1976
                                            wireless receiver for 6 speeds fan control with remote control
                                            by wolf1976
                                            hi i have a receiver that is destroyed from the overvoltage i guess
                                            my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                            the motor fan has not label
                                            i have an other receiver operational
                                            In your opinion can i measure the voltage at the output ?
                                            what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                            thanks in advance...
                                            07-23-2025, 03:12 PM
                                          • CdDvdFlash
                                            DSE GE6878 possible TV receiver dying remote not working well
                                            by CdDvdFlash
                                            For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
                                            07-03-2024, 03:55 AM
                                          • sanalelevenstar
                                            Yamaha RX-V485 receiver. After encountering a "version error"
                                            by sanalelevenstar
                                            I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                                            After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                                            I managed to find the service...
                                            09-10-2025, 01:54 AM
