Seeburg Symphonola 147
  • Cid
    • Mar 2010
    • 5
    Not sure if you guys will be able to help, but I figured its worth a shot. I'm currently in the procces of trying to recap the MA1-L6 Master Amp in my Dad's old jukebox. Its had a crackling noise for years that the previous owner had attributed to a blown cap, but I only recently got around to taking it appart. One of the big problems I've been running into is outdated markings on the caps (it IS over 60 years old after all!) I've only recapped motherboards and a couple of monitor power supplies so I was a little unprepared for the ratings I was seeing on them:
    .10 M.F.D.
    400 V.D.C.
    and
    CAP. D.C.W.V.
    .01 1000
    were a couple of the ones I saw inside. ( sorry for the lack of pix, my phone died while taking them)
    I can only assume that "M.F.D." means "uF" but I'm not even sure what types of caps would be best to use. the origional caps were paper with wax covering them and I'd rather not accidentally "brick" something this old and valuable. Any advice would be apreciated!
    • 31017
    Re: Seeburg Symphonola 147
    .1uf 400v
    10nf 1kv
    i suspect the second is ceramic
    got foto's - i used to do jukeboxes.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      M.F.D. -> microfarad -> uF
      • Cid
        • Mar 2010
        • 5
        Ok here's a couple of pix of the caps and the amp itself...
          • 31017
          start with the electrolytic screwed to the side of the chassis in the last foto.
            • 31017
            and clean or replace the rotary wafer-switch i can see in the upper-right.
            • Cid
              • Mar 2010
              • 5
              Well I cleaned the switch (heres hoping I dont have to replace it!) As for the electrolytic attached to the chassis I was actually hoping to replace all the caps since most seem to be in poor condition though, only two seem to have burst open... I'm currently having an issue finding caps to match the requirements of the existing ones. I'm aware that the voltage can be slightly higher than the ones in there, but what about the capacitance? is there some sort of "margin of error"?
              .01uF 1000v
              .1uF 600v
              .1uF 400v
              .1uF 100v
              .02uF 400v
              20uF 25v
              .5uF 100v
              .001uF 600v
              I usually only do business with Digikey, is there a more comprehensive source I should try instead? Also any brands I should try for (or stay away from)?
                • 31017
                the very high voltage stuff can be replaced by ceramics,
                the others can use polyester or polypropylene.
                the 20uf i'd use a 22uf electrolytic.
                use something good like a panasonic FK series if pos.
                atleast make sure it's 105' capable - those trays get pretty hot.
                • Cid
                  • Mar 2010
                  • 5
                  Thanks for all your help! I post my results when the parts arrive. Hopefully the worst of the electrical problems are behind me now!
                    • 31017
                    if you like pain, meter all the resistors.
                    • Cid
                      • Mar 2010
                      • 5
                      Holy crap... I totally didnt think of that... this thing is mostly made out of resistors and they are probably all in need of replacement...
                        • 31017
                        probably not a problem with most, but ones that handle over 100v may have changed value.
                        • bentonbobcat
                          • Feb 2011
                          Did you ever finish capping this amp? I am trying to do one now.
                          • Hemingray
                            KABOOM!
                            • Jul 2010
                            • 143
                            You can meter the resistors in this, but unless they're way out of whack, they're good to use.
                            Someplace in here there's gotta be a filter capacitor. May be a big silver can on top of the chassis. Usually found near the power transformer and rectifier tube. This cap is a MUST to replace in these, even if there's no hum.
                            As for the rest of the caps, You can always use Sprague Orange drops. They're quite decent in tube gear. (Having used these to recap antique/vintage tube radios myself).
                            Once recapped, this should sound excellent.
                            • survivalbloke
                              HP ENVY 360 - no power, taking no current
                              by survivalbloke
                              HP ENVY x360
                              15-dr1072ms
                              SN 8CG0215FQ6
                              Prod 13Q17UA#ABA
                              Board# 448.0GB12.0011
                              This device came in as no power. It is taking 0a current. I noticed a little liquid damage to the LCD connector and cleaned that off. I have 19v at the input mosfets, and on the opposite side of the board, there are several (diodes?) which all have 19v. There is a cap there which has 19v on one side, but 6.5v on the other - how?
                              The only other live power rail I have found on the board, is 16V on one of the coils. There doesn't seem to be a 5V or 3.3V present. A couple...
                              12-11-2024, 08:26 AM
                            • slimmy182
                              MacBook Air M1 A2337 820-02016 not booting, taking 5V 0.42A and 2.173W
                              by slimmy182
                              Hello, a friend give me this M1 Mac Air, he said that it simply stop working. Apple preventive is replacing motherboard.
                              Model is MacBook Air M1 A2337, logic 820-02016, not booting, and taking 5V 0.42A and consuming 2.173W.
                              Once disassembled is very clean, no water damage at all. Visual ispection reveal no visible problem. Flir camera point to two hot point:
                              C81DC PP3V8_AON_VDDMAIN
                              And
                              Q5800
                              What should I test as next step?
                              Thank you very much!
                              02-01-2024, 01:08 PM
                            • gurj1979
                              Xbox one 1540 not taking disc
                              by gurj1979
                              My Xbox one has stopped taking discs. Sometimes it will trip the power supply and no orange light neither.
                              If I'm lucky it will randomly take it after about 10 power reboots.
                              I got a new drive, swapped over the board but same thing.
                              So I swapped over the motor driver IC, but still same problem.
                              Is this turning into a motherboard problem rather than the drive or PCB itself ?
                              Help please.
                              08-11-2023, 03:31 PM
                            • Maksioja
                              MSI Katana GF66 - no power on, taking 20v, 0,055A.
                              by Maksioja
                              Hi guys,
                              It's my first post, because till now I found everything on this forum, but I'm little bit stuck now, so I'm asking you for help. It's my first gaming laptop, so I need some advice .
                              I bought defect MSI GF66 Katana with GTX3060 GPU.
                              First when I open it - you can easily notice - somebody open it before, but I didn't found any tech working for it, just maybe somebody open it for cleaning.
                              What I did so far:
                              Replaced parts:
                              • ALC233 - was exploded
                              • APL5934C - was exploded
                              • 2x FDPC5018SG - went shorted when I took out UP1666Q.
                              • UP9512Q
                              09-30-2024, 08:26 AM
                            • caspian
                              Asus K555U taking extra current
                              by caspian
                              Dear Members,
                              This laptop used to work with a 19v 3.4A adapter.
                              After 4 years of using it, now, the adapter's output voltage drops to 17v when windows loads up. Then the laptop suddenly turns off.
                              Today, I have connected a 19.8v 4.5A adapter to this laptop. Then the adapter's output voltage dropped to 19.4v but the laptop worked fine.
                              In addition, I noticed that the cpu power coils get warm to about 50'C but the mosfets are cool.
                              All the voltage rails on the mainboard are fine without any reduction except for the 19v rail. All the ICs and coils on the mainboard are...
                              05-31-2024, 01:36 AM
