Onkyo tx-nr414 shutting off after few seconds
  • Tamo Neko
    • May 2019
    • 48
    • Serbia
    #61
    Re: Onkyo tx-nr414 shutting off after few seconds
    There is -0.5v output offset on one channel only (SL) going to speaker relay out - that is for sure too much, and by mine opinion would trigger protection as it is connected directly to vprotect line...
    -0.5v is at P6083, NPLG-2P29 (page 9 (2IJ location on this page)) or in short NFSL line to ground.
    60v is because mine mains voltage *is at 250vac, as I have already mentioned at this thread but would not consider it significant.
    Now that you mentioned it again I have double checked that by lowering mains to 230vac as specified and for sure output on my 60v line drops to nr414 regular 56.2 volts.
    They maybe should not wrote that voltage fixed in service manual not to confuse service personnel, 52-60v should be written and that would make it easier.
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Did you ohm out the line NFSl? From Part 6 to Part 5 Also, if you do a search for NPLG-2P29. Look on how the part 5 transistors are connected. It is different then all the rest. It is the 2 search out of 12.
      • Tamo Neko
        • May 2019
        • 48
        • Serbia
        #63
        If by ohm-ing out you mean ohm-ing out for idling current adjustment, then answer is yes, at least at the time I checked for that, and that was good.
        I have problem with output offset on SL.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          SL is an output of Q4001 part 4 game IC
          If you are talking about SPSL then have you tried setting your meter on that spot while adjusting the idle screw for that section? That would be R6043 to see if you can lower the voltage?
          Page 1 of the service manual for 414 has the model types and voltages. Perhaps raising the voltage above a certain amount affects that adjustment. Depending on the model you voltage would be either 230 vac or 240 vac.
          • Tamo Neko
            • May 2019
            • 48
            • Serbia
            #65
            [QUOTE=keeney123;1138145]SL is an output of Q4001 part 4 game IC
            Tried that too with SPSL, not any significant change.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              [QUOTE=Tamo Neko;1138163]
              In that case I would check J6703 on part 9 to make sure it is closed normally. Then see if it is open when power is applied by taking voltage measurements on either side of J6703. Using the amp ground as reference for one lead. I would also check out SLE to make sure it goes to Amp Ground. and check all components in line. We are trying to see is the SL on part 9 is causing the problem or if it is the components.
              If the above seems to check out then I would trace the SL out from Q4001 part 4 to Sl in part 5 and the components on that line to see what is causing this. You can also compare one of the good amp outputs to the bad amp output and all associate components
              If that all seems fine then we need to determine by comparison what is causing Q4001 not to work like all the other outputs. Which would most likely be and input to Q4001
              • dariolana
                ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
                by dariolana
                Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
                Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations...
                02-26-2024, 07:47 PM
              • Bard_the_Bowman
                PS5 Disk Edition shutting down 5-30 seconds after boot, can't find any shorts
                by Bard_the_Bowman
                I have a PS5 that will turn off after anywhere from about 5 to 30 seconds after power-on. It will sometimes make it to Safe Mode, but won't last long there. The following are steps I have taken:
                1 - Tested on multiple sources of 12v power including 2 separate bench power supplies. Doesn't fix the issue, which at least to my mind, rules out the power supply as the problem.
                2 - Visual inspection of board. Absolutely no signs whatsoever of burns or failed components.
                3- Checked for standby voltages. All seem normal.
                4 - Added liquid metal and re-spread...
                04-24-2023, 12:15 PM
              • zklgfs
                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                by zklgfs
                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                08-11-2025, 02:14 PM
              • twonk9098
                Lenovo Legion 5 high fan spin turns off after 34 seconds
                by twonk9098
                I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                I have tried a few new bios but exactly...
                07-14-2024, 11:19 AM
              • Rolin
                Lenovo Legion 5 15IMH05H No Display
                by Rolin
                I have a Lenovo Legion 5 15IMH05H 81y6003yUS that someone asked me to help them with a failing SSD. I installed a new SSD, fresh Win11 installation, updates, etc. Very standard stuff and everything was completed. He said he'll pick it up in a few days so I shut it down and set it aside.
                A few days later came and now it won't POST an image, keyboard lights up, fans spin then shuts itself off after about 40 seconds. I've already tried the typical draining capacitance and removed CMOS battery,etc. No display on an external HDMI monitor as well.. No idea what happened. Suspected a BIOS...
                06-21-2025, 11:32 PM
