Lenovo Legion 5 15IMH05H No Display
  • Rolin
    • Apr 2007
    • 174
    I have a Lenovo Legion 5 15IMH05H 81y6003yUS that someone asked me to help them with a failing SSD. I installed a new SSD, fresh Win11 installation, updates, etc. Very standard stuff and everything was completed. He said he'll pick it up in a few days so I shut it down and set it aside.
    A few days later came and now it won't POST an image, keyboard lights up, fans spin then shuts itself off after about 40 seconds. I've already tried the typical draining capacitance and removed CMOS battery,etc. No display on an external HDMI monitor as well.. No idea what happened. Suspected a BIOS corruption since I did run updates and sometimes a bad BIOS update will come through. So I reprogrammed the chip (thanks for help in the BIOS request forums - very fast response over there!). But the problem persists. I noticed the caps lock key is responsive, but wasn't sure what that means since the computer would keep shutting down after 40 seconds and no display on the external HDMI monitor. But I decided to disconnect the LCD cable from the motherboard and try an external HDMI monitor again - it POSTed this time on the external monitor and I was able to enter the BIOS. And it didn't shut down after 40 seconds either. I reconnected the LCD cable to the motherboard again, confirmed no LCD display and started shutting down again after 40 seconds (but now it will display on the external HDMI monitor, but it also shuts down after 40 seconds like before). Appears to be some kind of issue when connecting the LCD cable to the motherboard. When the cable is disconnected, it stays running on an external monitor, but when reconnected it'll shut down after 40 seconds. Either the LCD, cable or motherboard is shutting down the computer in 40 seconds when the cable is connected. .
    Normally would disassemble the lid and check the LCD screen. But I don't have a screen like this to test and there's a good amount of adhesive to remove the screen from the lid/bezel. I will do it if I felt certain the problem was there. But I can't help but think this could be motherboard related. Specifically the GPU. I don't have the schematics or boardview files. I'm not a component level tech, but have been successful with these repairs with assistance (as a novice). Since the laptop failed in my possession, I feel responsible. Getting prepared this could be a very expensive motherboard I'll have to pay for. So any help would be appreciated...
    BTW: I will pull the motherboard and post pictures if apparent the motherboard could be causing this. Hoping for some advice.
  • Rolin
    • Apr 2007
    • 174
    I disassembled the lid and removed the LCD screen. FYI for anyone disassembling this model, it uses the removable adhesive strips to attach the screen. I pullled the removal tab located on the bottom and it appeared to break short. Then noticed another tab at the top & pulled to remove completely. Appears this unit has removal tabs at the top and the bottom of the screen for both sides because it uses 1/2 strips instead of full strips.... haven't seen that before. Disconnected the LCD cable from the screen, tested and still shutting off after about 40 seconds. Then I disconnected the cable to the webcam and it no longer shuts off after 40 seconds, so some progress? But with the webcam disconnected and the screen connected, still no display on laptop (but no longer shuts off after 40 seconds). Works OK on external HDMI monitor. Suspect the cable has a short. I ordered a new LCD cable and will report back with an update. Maybe it'll help others experiencing the same problem.
    • Rick_1234
      LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
      by Rick_1234
      Good evening, gentlemen.
      I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
      To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
      https://drive.google.com/file/d/1L6S...ew?usp=sharing
      Things I tried
      - Bought a new AC adapter thinking that was the problem but the problem...
      06-22-2024, 04:44 PM
    • sew333
      Pc shutdown, monitor flickered with no signal after 10 seconds
      by sew333
      My pc:
      10850K stock 4800mhz stock Kraken X73 good temps
      2x16 GB DDR4 GSKILL 3000mhz XMP
      Seasonic Tx-850 Ultra Titanium
      Gigabyte Rtx 3090 Gaming OC
      Aorus Z490 Pro Gaming
      1 TB SSD
      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
      Power...
      02-22-2022, 10:27 AM
    • ArchangelGabriel
      Aorus 17G YD laptop, broken display, could not switch to external monitor
      by ArchangelGabriel
      Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
      11-23-2023, 03:55 AM
    • maralexbar
      How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
      by maralexbar
      I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
      It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
      If anyone knows how to force the external monitor as primary for Notebooks of those models
      11-02-2024, 09:18 AM
    • twonk9098
      Lenovo Legion 5 high fan spin turns off after 34 seconds
      by twonk9098
      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
      I have tried a few new bios but exactly...
      07-14-2024, 11:19 AM
