Onkyo tx-nr414 shutting off after few seconds
  • Tamo Neko
    • May 2019
    • 47
    • Serbia
    Hello good day to all!
    Recently I managed to get some time to troubleshoot this Onkyo av receiver which would not turn on display and was shutting off before there is any info on screen.
    I accidentally found fuse (4A 250V) f201 blown and replaced it with what I had in hand (6A 250v same package)
    I thought that replacing that would solve everything but never the less that was not whole story...
    All I have resolved is that I have a few more seconds (2-4) with now working LCD display...
    I am not sure though if replacing optocouplers was necessary (might be that my DMM was low on battery).
    I am getting a 11.5ish volts on HDMI board where there should be a 9v on JL901a HDMI board 9v output
    I managed to update firmware to latest by eliminating unit shut off (by unplugging the p8001 flat cable which connects a HDMI board and vertical side board U0033 leading to U0010).
    I checked amplifier transistors multiple times.
    Any help will be appreciated!
  • Tamo Neko
    • May 2019
    • 47
    • Serbia
    Re: Onkyo tx-nr414 shutting off after few seconds
    And there are about 10volts at vprotect line after that unit imediatly shuts off...
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      The rating of amps on fuses are very important to not cause further harm.
      When a fuse blows it usually indicates that some type of short happen or if one is luck a transient power surge happened. In your case I believe a component was taken out. If you do not have the block diagram and schematics I have attached them.
      • Tamo Neko
        • May 2019
        • 47
        • Serbia
        In service menu it shows vprotect fault...
        Only place where I could find a new soldering points were at first mains relay...
        I double checked almost everything for shorts before replacing that fuse...
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          If a chip says short out, the short in the chip may draw enough current to damage the chip before the fuse blows. After the chip is damaged then the short is no longer there.
          One would have to know how the Programmer/Engineer set up the Voltage protect fault error on the Onkyo to understand what they included in that error.
          The Programmer/Engineer could say in his program if some system in the Audio Video Receiver does not turn on I will detect this as a fault. This could be any section of the AVR.
          With all that said one. Searching on the PDF I provided, F201 is on page 11. Thats a good starting point.
          On page 11 the F201 fuses is connected to BAETC-1074 part 5. A search of BAETC-1074 is listed on page 14. Which is Transformer T901.
          Because the fuses in the primary winding did not blow, I would look out in the secondary windings.
          • Tamo Neko
            • May 2019
            • 47
            • Serbia
            Just checked secondary windings on t901 and they are all good...
            • Tamo Neko
              • May 2019
              • 47
              • Serbia
              Latest update, q6053 and q6063 are overheating in test mode 01-1...
              That is surround left channel *SL*
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                Good for You!
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  Question do you know where the 56.2 Volt DC is being generated from?
                  The Q6053 and the Q6063 seem to be power transistors with a heat sink.
                  From what I understand the power transistors usually are the one that go bad.
                  • Tamo Neko
                    • May 2019
                    • 47
                    • Serbia
                    Yes those are output transistors.
                    On page 9 down left ( D6401 TS10B06G-07 ) you can find generated voltages...
                    They do go bad, but in my case I was lucky as I had thermal camera at the moment when heat wave stroke my forehead... Immediately I turned off the unit and used thermal camera...
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Smart You are.
                      I saw the TS10B05G-07 but why to they not specify the actual voltage like the do for the output transistors?
                      • Tamo Neko
                        • May 2019
                        • 47
                        • Serbia
                        Smart You are.
                        Might be because this bridge rectifier has its input from mains transformer whose output voltage depends on mains input. I think they can not be precise about that. Someone may correct me if I am wrong...
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          My thinking is if they can be precise on the 56.2V +/- powering the output transistor why would they not be able to list 56.2V from where it comes from?
                          I mean the 56.2 V just does not show up on the output transistors?
                          • Tamo Neko
                            • May 2019
                            • 47
                            • Serbia
                            89,90,91
                            Dont mind, that is me counting disasembly and asembly of this unit...
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              89,90,91
                              Practice makes perfect.
                              • Tamo Neko
                                • May 2019
                                • 47
                                • Serbia
                                Can you help me with c6402. When measuring across legs there is continuity. Should that be like that or there is a short somewhere? About 0.6 ohms to be exact...
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  You would have to measure the capacitor out of the circuit by lifting on leg of the cap. You maybe are measuring through a diode of the rectifier if you are using a analog meter. Or you can be measuring where ever minus BH1 B goes to ground. A capacitor should show an open on a resistance reading. With a analog meter it might first show continuity and then be opened.
                                  • Tamo Neko
                                    • May 2019
                                    • 47
                                    • Serbia
                                    Sorry I have not explained well. Checking without capacitor onboard shows that values...
                                    I do think I have checked every capacitor in that rail...But still there is continuity...
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      What type of meter are you using?
                                      I know with a Fluke Meter one can get about with-in 7.62cm of where a short may be. How this is done is to hold one resistance probe stationary while moving the other resistance probe. Of course you will be measuring on the lowest resistance setting. As the 0.6 ohms starts to drop you would be getting closer to the short. When you narrow down an area then you move the stationary probe to that area and do the same procedure again until you are with-in 7.62cm or 3" of the short. One then starts to eliminate that area by cutting through the trace to find out which side the short is on which side of the line until you actually find the short. After you repair the short you can scrape the traces where you have cut through and then solder a resistor lead across the cut. Finally take lacquer fingernail polish and coat over the bare repair.
                                      This short may not be a cap it may be a transistor or any other device attached between the rail to ground.
                                      • Tamo Neko
                                        • May 2019
                                        • 47
                                        • Serbia
                                        Brymen 525 with fluke probes...It has resolution in ten miliohms...
                                        I have never tried that as I read that you need at least 10 times more resolution if not 100 times. For doing like that..
                                        I have made a diy micro ohm meter but that is long story for telling why I dont have it anymore.
                                        • dariolana
                                          ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
                                          by dariolana
                                          Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
                                          Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations...
                                          02-26-2024, 07:47 PM
                                        • Bard_the_Bowman
                                          PS5 Disk Edition shutting down 5-30 seconds after boot, can't find any shorts
                                          by Bard_the_Bowman
                                          I have a PS5 that will turn off after anywhere from about 5 to 30 seconds after power-on. It will sometimes make it to Safe Mode, but won't last long there. The following are steps I have taken:
                                          1 - Tested on multiple sources of 12v power including 2 separate bench power supplies. Doesn't fix the issue, which at least to my mind, rules out the power supply as the problem.
                                          2 - Visual inspection of board. Absolutely no signs whatsoever of burns or failed components.
                                          3- Checked for standby voltages. All seem normal.
                                          4 - Added liquid metal and re-spread...
                                          04-24-2023, 12:15 PM
                                        • zklgfs
                                          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                          by zklgfs
                                          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                          08-11-2025, 02:14 PM
                                        • twonk9098
                                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                                          by twonk9098
                                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                          I have tried a few new bios but exactly...
                                          07-14-2024, 11:19 AM
                                        • Rolin
                                          Lenovo Legion 5 15IMH05H No Display
                                          by Rolin
                                          I have a Lenovo Legion 5 15IMH05H 81y6003yUS that someone asked me to help them with a failing SSD. I installed a new SSD, fresh Win11 installation, updates, etc. Very standard stuff and everything was completed. He said he'll pick it up in a few days so I shut it down and set it aside.
                                          A few days later came and now it won't POST an image, keyboard lights up, fans spin then shuts itself off after about 40 seconds. I've already tried the typical draining capacitance and removed CMOS battery,etc. No display on an external HDMI monitor as well.. No idea what happened. Suspected a BIOS...
                                          06-21-2025, 11:32 PM
