AKG N-SOLIDTUBE tube condenser microphone
  • MartinConnolly
    • Feb 2022
    • 11
    • United Kingdom
    I have found nothing on the net about this little doozie. A power supply and interface box for a studio microphone that uses a valve and condenser in the body to produce a 'warm' sound. Yeah right!
    Any way, the box just keeps blowing its fuse. Replaced the MOVs and it made no difference. There's a high voltage and low voltage side coming out of the transformer. Its all conventional design, with no switching. Disconnected the high voltage side and the fuse doesn't blow, so.......
    There's only five capacitors on the board, so I just replaced them all as it would be so cheap to do so. The box then powered up fine. I'm not sure at this stage which one was causing the problem, but I suspect the small 63v 47uF one sitting right next to four diodes that judging by the scorching on the PCB, run really hot.
    Anyway has anyone seen any similar boxes like this? There appears to be very little on the net about these, and no standards fir pinouts/voltages etc
    • 31055
    Re: AKG N-SOLIDTUBE tube condenser microphone
    there was a trend for "valve scams" a few years back,
    there was even a guy who profiled the frequency response of a valve pre-amp and then wrote a "simulator" for the mac!!!!
    • redwire
      • 3910
      Every microphone has colouration as far as freq. response and distortion.
      But you can't measure a microphone's distortion, and in condensor mics tubes beat JFETs for gain, linearity and input capacitance. But not for microphonics, cost, reliability.
      Tube condensor mics do have a place. Just do an A-B comparison with a good vocalist or instrument and you will see in general all microphones are terrible at capturing sound lol and a tube mic can sound really good. You have to have heard the difference to comment about it.
      Usually these mic/psu box combos get zapped by hot-connecting or wrongly connecting i.e. phantom power on or connecrtor flipped etc. It's usually just a pentode and few transistors in the mic.
      One AKG N_Solidtube repair showed a shorted MOV in the power supply. Another had a bad power transformer.
      It looks like it has a couple discrete voltage regs on the board.
      • MartinConnolly
        • Feb 2022
        • 11
        • United Kingdom
        Thanks for the replies. There are some good photos there. You can see the two high voltage 22uF 450V smoothing caps wired I think in parallel, the low voltage 1000uF 63V smoothing cap and the two 63V 47uF caps which I'm not sure of their purpose. There appears to be one voltage regulator on the low voltage side attached to a heatsink with a variable resistor to set it, which then controls the high voltage side with a pair of high voltage transistors wired in parallel. The one I repaired had already had the transformer replaced and the links to the bridge rectifiers had been patched in on the underside of the PCB. I don't know what the four diodes near one of the small caps are for, but as I said, they looked scorched on my PCB.
        • redwire
          • 3910
          There a HV regulator for the ECC83 tube, LV for the filaments (big heatsink).
          23VAC (~30VDC raw) and 270VAC (~380VDC raw) secondary windings. The 22uF's 450V one is at the output of the bridge rectifier, the other at HV Vreg output.
          The four glass diodes look like zeners in series, and back to back pairs. Part of the HV regulator, I can't see all the traces but it might be an AC protective clamp against overvoltage. Did this thing get wired for 120VAC and get 240VAC?
          All I can see is marking "Z3" on one diode.
          • MartinConnolly
            • Feb 2022
            • 11
            • United Kingdom
            I hope I've worked our how to attach photos.
            Here's the PCB after being removed and the MOVs removed. You can see the patching and scorching around the diodes.
            • R_J
              • 9551
              The 4 diodes in series are BZY97-C62 zener diodes
              • redwire
                • 3910
                That would make a 250VDC shunt-regulator. If the new transformer is a bit higher in voltage, it could stress the zeners but where's the dropping resistor. Yet you have around 380VDC raw.
                I can't see what the little transistor is doing. It might be a capacitance multiplier or
                the 12AX7 needs only a few mA but still a bit wee for a HV pass transistor.
                I think a person would have to trace out and sketch part of the circuit around the cooked zener diodes. OP has a Rev.3 board and the link I gave is pics of a Rev. 4 board, maybe AKG lowered the zener current.
                • R_J
                  • 9551
                  This will help him:
                  • redwire
                    • 3910
                    Thanks for the service manual find.
                    The four zeners make up a 250VDC shunt regulator. They are fed by a constant-current of 10mA coming from two small transistors giving 5mA each.
                    If one of them shorted it would burn up the zener diodes, so check both. Zetex ZTX757 is only rated 300V 1W. If 10V zener D4 went open that would also cause things to cook.
                    The four 62V zeners normally dissipate at most (no mic connected) 2.5W total or 0.625W each and the transistors 0.65W each so everyone runs toasty.
                    • DCJack
                      B&K 707 tube tester. I need help.
                      by DCJack
                      Hi everyone!
                      I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                      Initially I noticed that I was not getting the red on-light to turn on, but it...
                      03-05-2024, 05:05 PM
                      20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                      by sam_sam_sam
                      I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                      At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                      Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                      04-09-2023, 08:04 PM
                    • Schoenradt
                      ECH81/6AJ8 Vacuum Tube Question
                      by Schoenradt
                      Recently I acquired an Eico HFT 92 AM/FM radio made back in 1958. The unit has had some decent modifications done such as replacing the rectifier tube with silicon diodes and replacing the main filter capacitor with electrolytic capacitors. When I powered it up FM wouldn't tune past 105Mhz. I checked the FM tuner front end assembly and found a capacitor not soldered to the coil from the Plate B+ to and ground on the other side of the coil. Some calibration was needed on the trimmer capacitor on the tuner. My question is AM is extremely weak. When I tap on the tube I get all kinds of snapping and...
                      06-10-2021, 05:49 PM
                    • classicandy
                      MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
                      by classicandy
                      Hi Everyone,
                      Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
                      UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a...
                      04-14-2024, 12:00 PM
                    • Jalopy
                      BoardView for MSI MS-7B39, All Revisions - 1.0, 1.1, 0A, 0B, 0C (.CAD and .PCB formats) "Valve Steambox Motherboard"
                      by Jalopy
                      BoardView files for MSI MS-7B39.
                      All Revisions
                      Both (.CAD) and (.PCB) files included.
                      This is the BoardView for the "Valve Steambox Motherboard"...
                      04-09-2025, 02:53 AM
