MacBook Pro A2338 [820-02773] No Audio (Speakers and Microphone)
  • classicandy
    • Apr 2018
    • 309
    • Nigeria
    Hi Everyone,
    Please, I have a MacBook Pro A2338 M2, board number : 820-02773. The speakers and the microphone of the Mac are not working and I need assistance in fixing.
    UR730 got damaged and short-circuited the motherboard. After removing the shortened IC; before and after putting the new one I ordered, the speakers [specifically the other one not affected by this IC] and the microphone are still not working. I do have sound through a Bluetooth speaker device or when I connect a headphone with microphone to the jack 3.5mm input. Also, media files do not play unless ​a bluetooth speaker or headphones are connected.
    schematics and boardview; https://www.badcaps.net/forum/troubl...62#post1560562
    I would be glad if I can get any clues to where to lookout for. Big Thanks in advance
  • classicandy
    • Apr 2018
    • 309
    • Nigeria
    Originally posted by classicandy
    Hi Everyone,
    Any help on this please ???
    • mon2
      • 14664
      Issue could be with the headphone connector. Also inspect UR500 area which is the audio codec.
      • mon2
        • 14664
        Also,
        audio - Why are my Macbook's internal speakers not available? - Ask Different (stackexchange.com)
        • classicandy
          • Apr 2018
          • 309
          • Nigeria
          Thanks for your reply and suggestions.
          I've tried the steps listed there however, there is no boot chime at startup, audio output shows as MacBook Pro Speakers [Built-in], volume slider works as it suppose to, there is no red light coming from the 3.5mm jack indicating Digital Out and it doesn't indicate Digital out as well in the audio output too.
          The Mic Input Level also detects sound input but Voice Memos is not able to record any sound. The record counter stays at zero.
          • classicandy
            • Apr 2018
            • 309
            • Nigeria
            I seem to think now that UR500 must have been damaged too and would need to be replaced. I would place an order for the IC and install it when it arrives and come back here to relate my findings. Thanks for your help so far, much appreciated.
            • Snazzysmith
              • Aug 2017
              • 8
              So did replacing the UR500 solve the problem?
              • mon2
                • 14664
                Silence is golden Have seen the audio codec being a fault on at least a few cases. Worth a replacement.
                • noz_1974
                  MacBook Pro A1990 No Audio ( Speakers and Microphone)
                  by noz_1974
                  Hello ,
                  I have a MacBook Pro A1990 , year 2018 board number : 820-01041A.
                  The speakers and the microphone of the Mac are not working for some reason.
                  I do have sound through a Bluetooth device or when I connect a headphone plus microphone to the jack 3.5mm input.
                  Can anyone give me some direction on how to debug it on board?
                  thanks
                  03-24-2023, 11:05 AM
                • Orux
                  Macbook Pro M1 A2338 13"
                  by Orux
                  I’m new to the forum and could use a bit of help. My name is Tom and I have a problem 😅
                  I bought a MacBook Pro M1 and also got a second one for spare parts. The seller told me it had a small water spill. After opening it, I found four spots with corrosion on the board.
                  One of those spots has damaged components — I’m not sure if they’re capacitors or other SMD parts. I’ve already cleaned the whole board with isopropanol, which made the other areas look fine. But could those damaged caps be the reason why the MacBook won’t power on?...
                  09-22-2025, 12:54 PM
                • sdogs
                  macbook pro M1 a2338 no video on internal display PP3V3_S2 short
                  by sdogs
                  Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
                  First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
                  I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
                  06-27-2025, 01:58 PM
                • sdogs
                  by sdogs
                  06-27-2025, 11:26 AM
                • User555111
                  A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
                  by User555111
                  Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
                  02-05-2024, 08:16 AM
