Kanto YU6 active speaker power board schematic please
  • zen
    • 511
    No power , with F1 ( F5A ) O/C
    There's a S/C reading from 8V rail to GND .
    R14 & R17 ( see picture ) are cooked . Need to identify them so that i can continue with repair .
    Connected in parallel , therefore most probably same value , which i suspect is going to be low .
    No info coming up on a Google search.
    Power board number PCB 160926G1
  • zen
    • 511
    Re: Kanto YU6 active speaker power board schematic please
    Top view of power board
      • 20898
      Same problem here https://forum.hifiguides.com/t/my-ex...s-broken/20554
      Found an FCC document but its too blurry when you zoom in https://fccid.io/QKH-KANTOYU6/Intern...Photos-3185198
      Edit: https://www.reddit.com/r/audiophile/...eakers_broken/
      • zen
        • 511
        Thanks very much & i see what you mean regarding blurry picture .
        I make them both out to be 2R2 .
        Would be most grateful if anyone could confirm this .
        • R_J
          • 9535
          That is what they look like (2R2) they seem to be the source resistors for the mosfet, if this is what they are, R25 connects the mosfet source to the CS pin of the ic5 and many times when the source resistors open, full supply voltage is applied to the CS pin, which usually has a max of around 2 volts.
          So replacing the mosfet and resistors may not repair it. and the ic5 needs to be replaced as well.
          What are the numbers on IC5?
          • zen
            • 511
            Thanks RJ
            Will check part number of IC5
            • zen
              • 511
              Here you go RJ
              Any idea of type & where i could source one from ?
              • zen
                • 511
                T8 ( CS1N60 ) S/C . It's an N-CH MOSFET , manufactured by CR Micro . Found a seller on Ebay.
                • zen
                  • 511
                  Probably not worth continuing till i can identify & source IC5 ( 32J01d )
                  Pins 5 & 6 measuring S/C
                  I believe it's package type is SOT23-6
                  Can anyone help ?
                  • R_J
                    • 9535
                    It might be the On-Bright OB2532, Check the datasheet to see if the pinout matches
                    • zens electronics
                      • Jan 2021
                      • 31
                      Thanks RJ
                      Will cross reference datasheet info with PCB when i get back to the workshop on Monday .
                      • zen
                        • 511
                        Thanks so much for your help RJ
                        Followed pads on PCB from device & they do seem to correspond with datasheet .
                        Will update once parts arrive .
                        • zen
                          • 511
                          Parts arrived from China , therefore continuing with this repair .
                          Also discovered Schottky Barrier diode D10 ( SB360 ) S/C . Replaced with the more powerful SB5100.
                          • zen
                            • 511
                            R25 ( 100r) o/c
                            • zen
                              • 511
                              D6 , MARKED A4t , measuring leaky .
                              Replaced with a more powerful SMAJ5.0
                              • zen
                                • 511
                                Yet another sticking point .
                                I'm back to values of R14 & R17 .
                                Removed & cleaned them & fairly certain that they are not , as i had previously suspected 2R2 .
                                If you look at picture , The first number does look like a 2 .
                                The third has a flat top and is potentially a 3
                                It's all on the second number . Can't make out if it's an R , or 0 .
                                Could really do with some clarity on this one .
                                • zen
                                  • 511
                                  Regards R14 & R17 , went with my initial thoughts of using 2R2
                                  Happy to report that all the effort seems to have paid off .
                                  Speaker now working & on test .
                                  • R_J
                                    • 9535
                                    Good to here it is working. It may be that the values are 2R7
                                    Check if the mosfet is running warm and not too hot. Usually small smd resistors like this and used in the source of a mosfet are under a few ohms in value so it is likely an `R' not a `0' The R represents a decimal
                                    2R3 is not a standard value but 2R7 is
                                    • zen
                                      • 511
                                      Will do RJ & once again thanks for the help .
                                      • Roland68
                                        • Mar 2022
                                        Unfortunately I have the same problem with my power supply in the Kanto YU6.
                                        In my case, the resistors R14 and R17 and the fuse are blown.
                                        Can someone tell what voltage CN3 (V+ / GND) should have? This is the main supply for the power amplifier.
                                        According to the label, CN2 should have +8V / GND / STB (what is STB? control voltage for standby?)
                                        Thanks in advance for any help.
