Thorens TTA-2000 DC offset
  • zoldi211
    • Feb 2016
    • 26
    • Slovakia
    Re: Thorens TTA-2000 DC offset
    I have an another problem. On RCA terminals I measured high DC voltage - 15-18 V on both R/L RCA inputs !!! What is this? This is normal on this type of power amplifier?
    • zoldi211
      • Feb 2016
      • 26
      • Slovakia
      Hi, I replaced Q1 Darlington transistor TP147, but DC raising with 2-3V on RCA terminals. Zener diode? Resistors are ok. Please help !!!
      • R_J
        • 9551
        The input is isolated by a capacitor, the capacitor does not pass DC it is just a phantom voltage your meter is picking up. Once you connect a source the voltage should disappear. or add a resistor across the input, try a 100k. Some amps have a 1Meg across the input and then a 330Ω in series before the input cap
        • zoldi211
          • Feb 2016
          • 26
          • Slovakia
          Thanks for your answer. My Yamaha RX-V1800 have preout output and protection turned it off with DC overload, if Thorens are connected.
          • budwich
            • Jul 2015
            • 3097
            what "rail" voltage are you reading in the circuit as shown. what is the impedance reading for the inputs (unpowered)? check the cap on the input?
            • zoldi211
              • Feb 2016
              • 26
              • Slovakia
              #26
              The voltage is set to 50V. If I increase the voltage, the DC voltage on the RCAs is also grows. How can I measure the impedance? All of the caps are replaced.
              • budwich
                • Jul 2015
                • 3097
                just use a DMM on resistance measurement... watch what happens during the measurement.
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  #28
                  check the grounds
                  • zoldi211
                    • Feb 2016
                    • 26
                    • Slovakia
                    #29
                    The impedance beginning on 20k and raising up to 1M within seconds. There is a 33pF capacitor across RCA terminal.
                    • zoldi211
                      • Feb 2016
                      • 26
                      • Slovakia
                      #30
                      check the grounds
                      The grounds looks fine....
                      • budwich
                        • Jul 2015
                        • 3097
                        the circuit diagram that you posted doesn't show that.... it shows it as a "dc block" on the input. The impedance seems as expected. check the cap.
                        • zoldi211
                          • Feb 2016
                          • 26
                          • Slovakia
                          #32
                          All caps are ok, I replaced them all.
                          • budwich
                            • Jul 2015
                            • 3097
                            check the polarity
                            • zoldi211
                              • Feb 2016
                              • 26
                              • Slovakia
                              #34
                              The polarity is ok too. I did not find any problem.
                              • budwich
                                • Jul 2015
                                • 3097
                                confirm the cap across the input.... where is that in the circuit diagram?
                                • zoldi211
                                  • Feb 2016
                                  • 26
                                  • Slovakia
                                  #36
                                  There is not, I know. I dont have full circuit diagram or service manual.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    you might consider disconnecting the cap on the input and do your impedance check again. Then with no input, do your voltage checks. Go from the result. My limited experience with a DC300A... there is no cap across the input. Is the cap circuit board mounted or soldered across the terminals?
                                    • zoldi211
                                      • Feb 2016
                                      • 26
                                      • Slovakia
                                      #38
                                      Ok, I disconnect this 33pF caps and measured some impedance 18k-1M.
                                      New detections:
                                      - if I measuring impedance in one channel (R or L), then no voltage on that channel RCA, only 0,1V, what is raising slowly. On second channel (no measuring) 15-18V every time. After turning off and on again, voltage are present on both channels.
                                      - if amplifier is turned off, without power cable - I measured negative voltage on RCA (-15V and slowly descendig). That voltage are present on the top of the input caps, on others are measuring about -1V.
                                      • Niekv
                                        • Feb 2023
                                        • Belgium
                                        #39
                                        Link to the service manual:
                                        https://www.audioservicemanuals.com/...service-manual
                                        • dicky96
                                          What 'class' is this Hill Audio DX3000 Amplifier?
                                          by dicky96
                                          Hi guys, this is general query really
                                          So I have a Hill DX3000 3KW audio amplifier here.
                                          It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
                                          I was wondering what class this is. It doesn't fit the description of class A.
                                          It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
                                          I looked for 'class A push pull' but that didn't tell me anything either
                                          05-04-2022, 04:20 AM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • MrCommunistGen
                                          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                          by MrCommunistGen
                                          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                          07-12-2021, 05:11 PM
                                        • jinu_j
                                          How to test Subwoofer Amplifier with only a multimeter
                                          by jinu_j
                                          Hi Folks
                                          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                          Problem
                                          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                          Any advice would be appreciated...
                                          08-29-2024, 02:05 AM
                                        • UserXP
                                          Mackie CR4 amplifier no sound
                                          by UserXP
                                          Hi, people.
                                          I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                                          Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                                          10-17-2020, 05:06 PM
