how to repair sony str k850 won't memorize radio stations no more
  • ivtec
    • Dec 2008
    • 1967
    Hi guys, i have an old Sony receiver str k850 that won't memorize preset radio stations no more, i have to manually put in frequency in order to tune in station ,but if i try to set up another frequency it looses the first one and so on, this might be old caps, what you guys experts on radios think i should look for, thanks
    • 31214
    Re: how to repair sony str k850 won't memorize radio stations no more
    open it - see whats inside.
    it probably has a (leaked) battery or capacitor to maintain the memory
    • ivtec
      • Dec 2008
      • 1967
      Thanks stj,i' try to open it and check, i'm getting to old for this though, if i had a clue where to go in the circuit would be best.
      • R_J
        • 9594
        I looked at the service manual and could not see any memory backup (ie large cap) I suspect the data is stored in eeprom, make sure you are saving the station according to the manual, or you could also try a reset to clear any data that is already stored (procedure is in the owners manual)
        • ivtec
          • Dec 2008
          • 1967
          I did the factory reset some time ago and it did not set the tuner to preset stations, i think i'll not tough this thing and will input station manually if needed every time i need it which is rarely ,i only tune in one station anyway,as long it doesn't affect other receiver functions it's fine, besides i have another Str DE335 older but still works fine,thanks
            • 31214
            link the service manual
            • UserXP
              Vintage SONY Digital Clock Radio ICF-C12W no audio
              by UserXP
              Dear all,
              I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
              i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
              My question is, do you know of this brand of capacitors and how bad are...
              07-21-2025, 08:35 AM
            • mikey5791
              Sony CFS-5000S radio cassette player no FM reception
              by mikey5791
              Hi forum members,
              In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
              Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
              I opened the casing inside and checked for any dry solder, burned component or loose wires...
              02-24-2023, 03:48 AM
            • shelby5041
              clock radio / radio lifespan?
              by shelby5041
              hi
              ive got a modern digital clock radio approx 15yrs old
              my question is how long can a clock radio or a simple radio last ss farcas operating hours?
              since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
              the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
              it uses very little power just a few watts i would imagine that may have something...
              09-14-2024, 03:30 AM
            • diggitt
              Radio, no stations, quiet static sound
              by diggitt
              I am repairing a DeWalt DC011 radio. I found that the secondary coil of the transformer had gone open circuit and the amplifier ic had shorted. I have replaced both but I can’t tune it in to a station and the static is very quiet. Any help is greatly appreciated. Thank you
              04-14-2025, 05:06 AM
            • praveenramavath
              Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
              by praveenramavath
              Hello All,
              I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
              https://www.hifivision.com/threads/m...-screen.98243/
              Troubleshooting Summary: Majority Internet Radio - Flash Chip
              04-26-2025, 09:08 AM
