Re: Help me understand this schematic Harman&Kardon tape deck (TD470)
well done .
Yes I realized that it's not that all those voltages are power supply voltages, but derived voltages from the whole function
Ok, end of this project. I fixed it!!
I started by removing the zenner, tested out of the board and showing no shortcut. Shortcut still present at board. Removed the capacitor. Measured 5 ohm on each direction, shortcut not present anymore on the board. Swapped that capacitor with just one that I had handy with higher specs, zenner back to board, wires back in place and tadaaaaaa the tape is back to life.
I truly truly appreciate all you guys helping me on this project. I make no money with this, just helping a friend who insisted in keeping this "almost oldie" tape deck, he is an enthusiast of old school music, he still plays vynil records and tapes, so I wanted to do my best for him and his "challenge", which I did thanks to you all who provided help here.
THANK YOU ALL!!Leave a comment:
With the -6v Vee ALL the other voltages on ic503 will be off, that is to be expected. Check the Zener diode in diode mode on you meter. If you have 0 volts on the base of Q118, either the zener diode is shorted or R145 is open circuit. C139 could be shorted but it is unlikely. Maybe it is just a poor connection around Q118 or it's components. (it was intermittent)Ok I just tested all voltages to IC503 (playback chip) taking advantage that the schematic lists all the expected voltages, and 95% of the voltages, not only -6v, are missing or completly off.
Even some expected 0v are not even 0v
See atached file where I wrote down measured, in red, voltages on my unit while it was playing
Still checked that main voltages on PS board are still present and ok so I don't know what makes all secondary supply voltages (-5v, 6.5v, -5.1, etc) to be bad
Thanks!Last edited by R_J; 10-01-2021, 05:07 PM.Leave a comment:
check zener firstLeave a comment:
Also I just checked the main voltage regulators, Q506 for +8.3v and Q507 for -8.5v on their emitter lead
Also checked lm7805 regulator IC501 and getting 5.0v
Then checked again Q118, which drives -8.5v into -6.1volts but this one reads 0v on both base and emitter, while his counterpart Q117 for +6.1 reads correct values.
This truly seems to narrow down to this stage. Either Q118 itself, the zenner diode (reading now 0v across, but expected if Q is shorted) and maybe capacitors C139&C141, right?Leave a comment:
Thanks!Leave a comment:
Q118 supplies -6v to ic503 Vee pin, if it is missing, you will likely not have any audio, Check Q118, and R145, DZ102 may be shorted causing 0 volts on the base and emitter.Yes sorry I found those numbers on the schematic after sending last question, I realized my voltages match those, yes, ty
+9 and -9 are present (+8.5 & -8.5 specifically)
Mmmm we might have something here...:
Q117 has voltages around -6 on all 3 pins
BUT Q118 only has voltage (close to +6) on collector. Nothing on base or emitter....
Could this lead to all this lack of sound?Last edited by R_J; 09-30-2021, 04:54 PM.Leave a comment:
:-( sorry, I should have picked that up too... so use to see "one model does all versions" type schematics. forget what I was saying... you are likely on the right track going after the +-6v. good luck.Leave a comment:
Oh oh.. I see now what's going on with the "discrepancies".
I linked to a model 450 instead of 470, which is 80% alike but not same, but on my computer I was checking the right PDF.
SORRY!!
This is the correct link: LINK
The "main" signal lines are most the same, but some IC names change.
Im going to measure all correct voltages on IC503 ("playback") as I suspect from what I checked before that I may be missing some +6 or -6 line
Thanks again!Leave a comment:
totally weird... I took the file from the link posted in the thread.... and I can't find what you are referring to. ????? not sure what to say. the title on my document says "harmon-kardon-td-450-service-manual.pdf" maybe I am looking at a north american schematic??? does your page 10 (physical page not the PDF viewer page ref) show a block diagram of the system flow?Last edited by budwich; 09-30-2021, 02:07 PM.Leave a comment:
Ok, i understand most of what you are saying but I find some differences to what I found on the schematicbased on what page 10 describes and "kind of following" the "schematic diagram 1", you should see your input signal at cn701 at pins 1 and 3. These are fed to ic701 (2,29). The output of ic701(6,25) heads toward a relay ry1( I think there is a schematic "error" associated with the relay for R & L signals). That relay appears to be not operated in the schematic (I read page 10 as ic701 is always in playback mode) so the signals DON'T go towards ic702, they go out cn702 (pins 1,3). This takes the signal to the "output stage".... basically traveling thru nothing but "wire" and a resistor. Hence, you should see your input show up there on a scope or otherwise. IF it doesn't, you can do some continuity measurement (unpowered) to check the paths. IF continuity is good, then you can look at potentially why IC701 is "unhappy".
The signal seems to enter pins 2&27 of IC503 (you said 2&29 of IC701, which I cant find)
Then it outputs at pins 8&22 (but 7 & 21 seem candidate for ...something I don't see), and then they go into that relay ry101 which I do see it driven by signal "MONITOR" at cn801 (to control board), and in side this relay drives these 2 signals (weird as it looks like left channel is driven at the opposite time when right channel is) to the op amps in IC504A, and then to LINE-OUT
Do we see the same? I can't find some of the references you mentioned
based on what page 10 describes and "kind of following" the "schematic diagram 1", you should see your input signal at cn701 at pins 1 and 3. These are fed to ic701 (2,29). The output of ic701(6,25) heads toward a relay ry1( I think there is a schematic "error" associated with the relay for R & L signals). That relay appears to be not operated in the schematic (I read page 10 as ic701 is always in playback mode) so the signals DON'T go towards ic702, they go out cn702 (pins 1,3). This takes the signal to the "output stage".... basically traveling thru nothing but "wire" and a resistor. Hence, you should see your input show up there on a scope or otherwise. IF it doesn't, you can do some continuity measurement (unpowered) to check the paths. IF continuity is good, then you can look at potentially why IC701 is "unhappy".Last edited by budwich; 09-29-2021, 04:58 PM.Leave a comment:
Ok, I kind of understand this part. It looks like the MONITOR signal (if traced correctly this line) toggles this relay to forward the out signal from the IC503 out to the op amps in IC504A, which basically are the end stages before LINE OUT sockets. I will have to test for audio signal at the relay pins, and at the in and out of the op-amps in IC504A. There's also a transistor right before the LINEOUT connector that may have to be checked.if you look at the block diagram on page 10 of posted manual. Do you have a way input a signal to the input jack... something like a 1khz tone from a computer file or test cd or test tones from an audio receiver? You should see that signal coming out of the ic702 (dolby stuff) and going directly into the tape monitor relay which provides a "selected control" of whether you get the tape output signal OR the input signal coming out to the output jack. You should be able to scope for that signal somewhere near that relay. IF you get nothing there, then you can move back towards the ic702 to see what conditions it needs to pass the signal directly to the monitor relay.
This may at least check the basic source audio path without any involvement of the tape.
Do this sound correct?
Thank you!Leave a comment:
Could this lead to all this lack of sound?Leave a comment:
if you look at the block diagram on page 10 of posted manual. Do you have a way input a signal to the input jack... something like a 1khz tone from a computer file or test cd or test tones from an audio receiver? You should see that signal coming out of the ic702 (dolby stuff) and going directly into the tape monitor relay which provides a "selected control" of whether you get the tape output signal OR the input signal coming out to the output jack. You should be able to scope for that signal somewhere near that relay. IF you get nothing there, then you can move back towards the ic702 to see what conditions it needs to pass the signal directly to the monitor relay.Yes, it looks like it works for the very first time after a long time unplugged. Or it was just coincidence.
What is missing is only the audio output (it's only PRE-amplified, it's a LINE OUT signal).
Motors are running perfectly, display counting back and forth, search function works, all buttons under the LCD work and toggle their action on the screen (dolby, mpx, counter reset...).
So basically all works (logic, controls, motors) but audio output
If I understood the mute function (does it mute when 12v is present? When absent?) I would probably be more able to diagnose it.
For now I don't know where to start....
Thanks!
This may at least check the basic source audio path without any involvement of the tape.Leave a comment:
I've tried wiggling all the conectors and pushing everywhere on all the boards while the tape was playing and no change, no crack/noise/anything on the speakersLeave a comment:
if you have +/- 12v on the output then power-on is active, and the relay/transistor are fine.
and probably p-mute is good.
check all the connectors for cracked solder joints.Leave a comment:
Your voltages are normal, See page 62 of the manual, WA501 +12v (17.4v) -12v (-19.3v) -24v (-23.3v).
There are two separate +12v. I would also check if your +9 and -9 volts are there. (Q612 & Q613) Can be checked on WA519 pins 1+ & pin3- Also check the + & - 6 volt regulator voltages (Q117 & Q118)Last edited by R_J; 09-28-2021, 06:49 PM.Leave a comment:
This narrows down the search space a bit as now we know it's not the tape side path.
When absent. Check the voltage at pin 10 of the 30-pin CN801, if it's 5V then P.Mute isn't the problem.Leave a comment:
I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by IamPriteshCan you anyone explain what should be the ideal voltage for PROCHOT according to this schematic.
I have no voltage on AD_IINP.
On U8801 I have 5V on pin 5 and 0.537 volt on pin 3. No output voltage.
Currently board is not triggering at all.... -
by pecmanI was given an Aiwa Z-R700 from the 1990s era to look at by someone who said the twin tape deck did not work. The whole unit unit powered up ok but there was nothing from the tape deck. I had a look and found all the belts broken, I replaced the belts and then put the tape deck back into place and it still does not work. Also when I now power up the unit all the lighting on the front is very dim and the cd player and the tuner as well as the tape deck do not work. I have checked all the connections and ribbon cables again, there are no burnt or swollen capacitors. Maybe there are capacitors on...
by triplefourI've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...07-17-2023, 10:22 PM - Loading...
