Sansui AU9500, capacitor blows
  • Fripacks
    • Jun 2021
    • 59
    I have Sansui amplifier AU9500,, no sound, I found fuse 2 amperes, 7 amperes burns, I found too 3.3 uf 100 volts completly bulging under driver board, 1 transistor output 2SA679 shorted,and I found too the 4 capacitors 4700UF 63 volts they have not good value, I changed all these components and one of 2 capacitors 3.3 uf 100 volts is going very hot after 30 seconds, do I have power supply problem?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Sansui AU9500, capacitor blows
    A 7 ampere fuse burns out, too, when rated for only 2 amperes? Sounds like a bad transistor to me! (besides the bad caps, of course!)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Fripacks
      • Jun 2021
      • 59
      Yes, I change too 2 transistors audio output on the left channel, and same problem the 3.3 uf 100 volts under the driver board become very hot and blowing up
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        you put the cap in backwards or the power supply needs work
        • Fripacks
          • Jun 2021
          • 59
          The capacitor was completly bulging before I work on the amplifier, I put the cap with good polarity and I put a 160 volts capacitor( original was 100 volts), I think problem is in the Power Supply
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            did this amp ever work for you ? a little will be a big help ..
            the only caps i see with 33 is 33pf .
            • R_J
              • 9540
              What are the LOCATION NUMBERS of the componemts that you changed ? Which capacitor is getting hot? C???? For a capacitor to get hot it is either in backwards or has way too much voltage across it.
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                hold on a bit .. no way too much voltage got the 100v cap hot . 3.3uf isnt a value in that amp as far as i can see .. if you cant work out board designator id tell us what it connects to . and if there are holes in the board for it . it is possibly a late addition from factory .
                some nice pictures will help .
                • CapLeaker
                  Leaking Member
                  • 8176
                  Either something is drawing power like a SOB, or that cap is backwards or wrong value or high ESR.
                  • Fripacks
                    • Jun 2021
                    • 59
                    Check on this photo the 2 new capacitors I put, one is blue and the other is black, I check on schematic and is not listed
                    • petehall347
                      • Jan 2015
                      • 4426
                      • United Kingdom
                      trace where the wires go to what the caps connect to .and tell us ..
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        think i have found the problem .i found an original pic .. look where the blown up one connects to .
                        • R_J
                          • 9540
                          In one version the caps were .01µf disc caps, and electrolytics in a different version.
                          • petehall347
                            • Jan 2015
                            • 4426
                            • United Kingdom
                            so did it get fixed or not ?
                            • Fripacks
                              • Jun 2021
                              • 59
                              My version is with electrolitic cap and when I change it I verify twice if it's polarity is ok
                              • petehall347
                                • Jan 2015
                                • 4426
                                • United Kingdom
                                fit it as seen in the pictures .
                                • Fripacks
                                  • Jun 2021
                                  • 59
                                  I check voltage on the 2 electrolytics and it seems normal one gray wire have -49 volts and the other with yellow wire have +49 volts , they connect directly on bridge rectifier, I try to switch on amplifier and I remark distortion on one channel and after 1 minute the capacitor goes very hot
                                  • petehall347
                                    • Jan 2015
                                    • 4426
                                    • United Kingdom
                                    the connections are wrong .. try looking at the pictures we spent time looking for and posting for you .
                                    • Prolog
                                      RTX 3080 FE Identifying capacitor
                                      by Prolog
                                      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                                      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                                      I hope these photos make it clear which component I am referring to:
                                      (yes, the soldering is a bit botched from removing the blown one, I know)
                                      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                                      12-01-2024, 08:27 PM
                                    • chth96
                                      If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                      by chth96
                                      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                      I know that these capacitor will not last as long as nichicon capacitor...
                                      12-22-2023, 04:34 AM
                                    • chth96
                                      How can I test non-polarized capacitor?
                                      by chth96
                                      I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                                      I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                                      And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                                      I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                                      06-02-2024, 07:31 PM
                                    • chth96
                                      Is it no harm to replace with capacitor without ripple current rating?
                                      by chth96
                                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                      Rubycon YK DataSheet (b...
                                      04-19-2024, 05:19 AM
                                    • chth96
                                      Should I replace polymer capacitor?
                                      by chth96
                                      a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                      I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                      Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                      Is this ESR value of polymer capacitor correct?...
                                      11-18-2022, 04:22 AM
