Denon DR-M10HX Cassette Deck Servicing Help
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Hi All,
    I have an old Denon DR-M10HX cassette deck and want to service it.
    I have aquired some test tapes and I have a scope. When I connect the scope to the L&R line level outputs I see a great deal of high frequency noise. Equally when I play a 3.5KHz test tape it's hard to see the test frequency through the noise.
    Any advise would be welcome.
  • redwire
    • 3910
    Re: Denon DR-M10HX Cassette Deck Servicing Help
    A dirty, oxidized Record-Play switch is a very common problem with cassette decks.
    Spray some DeOxit or other PPE cleaner into the switch and move it back and forth a hundred times. Don't get spray on the belts! Check the other switches and potentiometers are not dirty.
    Then, you bring out the scope if need be.
    • budwich
      • Jul 2015
      • 3097
      probably no schematic for this, right? you are going to have to break into it and look for any labeling of voltages in and around some of the connectors / between the boards. Check those to see if they are correct.... and since you have a scope, check what those voltages look like (ie. how clean is the DC). Might give clues where a probably might be.
      Next, once open, prehaps you might be able to get close to the outputs from the heads to look at what they are seeing at or near the pre-amp section. Go from the result.
      One other question, does selecting / unselecting the dolby options change the signals that you see?
      • Nevillet
        • Sep 2019
        • 272
        • United Kingdom
        OK as a first off I've made some recordings from the line level outputs of the deck feeding a USB sound card directly and recorded in Audacity.
        The 'Not Playing Noise - Raw' recording is just the background noise with no tape playing.
        https://drive.google.com/file/d/14K3...ew?usp=sharing
        The 'Not Playing Noise - Normalised' is the same recording but normalised in Audacity.
        https://drive.google.com/file/d/1shd...ew?usp=sharing
        The 'Blank Tape Playing - Raw' is a blank tape playing (not normalised)
        https://drive.google.com/file/d/1vVC...ew?usp=sharing
        What are your thoughts?
        • Nevillet
          • Sep 2019
          • 272
          • United Kingdom
          And here's the service manual:
          https://drive.google.com/file/d/1o5o...ew?usp=sharing
          • R_J
            • 9549
            Originally posted by Nevillet
            I was going to upload that manual but after looking at pictures of the deck's board and the manual's board layout, they were quite different. The schematic could be close enough to work with. I would start by scoping the output of the power supply DC voltages, (+- 12v?) they could be discrete components like the schematic or regulator ic's ie 78xx and 79xx
            If the noise is on both channels it is usually something that is common to both like the supply voltages.
            • Nevillet
              • Sep 2019
              • 272
              • United Kingdom
              The circuit board does not match the service manual. There is a discrete bridge rectifier followed by two 1000uF/25V caps. The image below is the trace acoss each of them:
              Using a Peak ESR70 meter they each measure (in circuit) ≈ 994uF & 0.12Ω
              I've recorded some music (MP3 so no HF above 16KHz) and here is a link:
              https://drive.google.com/file/d/1Emi...ew?usp=sharing
              • R_J
                • 9549
                That service manual is for the DR-M10, not the DR-10MX, The wave form across the caps is the raw dc, it should then go into positive and negative regulator circuits. This is the place to check if the regulator and filter circuits are working.
                Using the DR-M10 manual, you need to check the outputs (emitters) of TR353 & TR351, in this case + & - 9vdc
                • Nevillet
                  • Sep 2019
                  • 272
                  • United Kingdom
                  There are two TO220 transistors close to the bridge rectifier and smoothing caps. One is a D985 and the other is a B794. The trace below is from the emitter pins.
                  I have made a new recording of audio this time connecting a HiFi CD player directly to the inputs of the cassette deck. I have recorded some 'silence' before the music starts so you can hear the baseline noise.
                  https://drive.google.com/file/d/1Uf9...ew?usp=sharing
                  • R_J
                    • 9549
                    That noise is likely not from the power supply, but could be coming from the motor. I suspect the noise is there even if you hit play without any tape? if it is, use your finger to slow down the motor and see if the pitch of the noise changes, it could be coming from the motor.
                    • Nevillet
                      • Sep 2019
                      • 272
                      • United Kingdom
                      Slowing the motor does not seem to alter the noise. Even if I unplug the power cables to deck motors the noise remains.
                      • budwich
                        • Jul 2015
                        • 3097
                        get a small hair dyer or equivalent. try carefully heating some areas up to see if there is any impact on your traces / output results.
                        • redwire
                          • 3910
                          No way this cassette deck is getting fixed with random scope traces and sound clips.
                          You have to use formal troubleshooting technique, a bit of science, otherwise it's like walking into a casino.
                          Don't get lost listening to soundcard noise lol. The deck is all analog and sometimes SIGLENT adds it's own noise, unless your grounding is wrong.
                          Use a test tape with a 1kHz signal or music to troubleshoot the playback function. Recording a tape then playing it back requires everything to work and will not help narrow down what is going on, which section is dead.
                          Without a service manual, you'll have to pop the lid and post pics of the main board.
                          • Nevillet
                            • Sep 2019
                            • 272
                            • United Kingdom
                            Sorry, busy life has got in the way of this for the moment.
                            I'll be back.
                            • dustfilledhobo
                              Kenwood KX-56CW Duel Cassette Deck Repair
                              by dustfilledhobo
                              Hello!
                              I'm trying to fix my Kenwood KX-56CW dual cassette deck (seen in the picture below).
                              Everything functions as it should except that the motor for tape deck B plays back extremely fast (tape deck A functions properly). I've located the two trim pots on the board that control the speed of deck B and they were only able to bring the speed down a little bit. I was able to find a schematic online (attached) with suggested voltages, so I measured the board while playing a tape in deck B (as per the instructions on the schematic). Some voltages were...
                              04-11-2021, 11:52 AM
                            • repair-it
                              Need advice testing a samsung power supply board with scope
                              by repair-it
                              I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                              07-12-2025, 11:00 AM
                            • JimBanville
                              Both right channels dead on dual deck JVC KD-W110 cassette player
                              by JimBanville
                              It's not the cables. Lol. The audio and LED meter for the right channel from both decks shows no signal. Can someone please tell me what to check first? I went ahead an reflowed the solder on most of the IC's. No change. Thanks!!!!...
                              02-28-2021, 12:39 PM
                            • digitalscorpion
                              marantz MCD 810 cassette deck
                              by digitalscorpion
                              MCD810. Good condition.
                              When I press play, the VU meters max out, with or without cassette loaded. The play head or pickup looks like it could have some gunk on it but not sure. I took some isopropyl to it and the meters are still maxed out. Can't seem to locate a service manual. Any thoughts?
                              04-25-2020, 12:39 PM
                            • Jim Farid
                              Steam Deck: how to solder 3 pin POWER BUTTON with one missing (ripped-off) solder pad?
                              by Jim Farid
                              The middle pad (B) on my steam deck's power button got ripped off. I want to bridge the middle pin to a via or another pad but don't know which one. Do you guys know any?
                              The pads with the stars are all ground.
                              In case there's no pad I can bridge to, do you know how to turn my deck on without using the power button? Thanks a lot 🙏....
                              06-09-2024, 02:38 PM
