Repairing Alesis M1 MK2 Monitor Speakers
  • MisterD
    • Oct 2012
    • 668
    I have a pair of these Speakers given to me that seem to work fine and I haven't used anything like these before and my only way of testing them was to use a standard 1/4" guitar cord and I also used a 3 pin XLR cord, My Acoustic Guitar has both and it has a built in preamp. the jacks on the speaker cabinets have exposed contacts and it appears that the plastic dust covers are broken and gone..I have found these on ebay...https://www.ebay.com/itm/2-Pack-Neut...s/330915900629
    but I'm not sure if these are the correct replacements, they show that the 1/4" connector portion of these jacks are "Stereo" my guitar cords are mono. does anyone know if the replacement jacks ( Ebay Item) I have posted the link here) are the correct replacement jacks? Thanks
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Repairing Alesis M1 MK2 Monitor Speakers
    stereo can also be used for balanced which xlr generally is
      • 31015
      interesting connectors.
      10x the price of a 6.3mm jack - but i like them!
      • MisterD
        • Oct 2012
        • 668
        https://www.neutrik.com/en/neutrik/p...combo-i-series There are many variations of these, I haven't pulled mine out of the speaker cabinet to look at them yet. they could be pc board mounted instead of hard wired. I also wonder if they have a part number on them, they could be made by Nutrik, I'm not sure.
        • Khron
          • Sep 2006
          • 1350
          • Finland
          The connector is indeed PCB-mount (not solder-cup terminated), and is an NCJ6FI-V (Neutrik Cannon Jack, 6 pins, Female, I series, vertical mount).
          It may or may not be some "custom" version with a couple more mechanical-support pins though, but i can't be 10000% sure. The one i have here has the connector covered in some heatshrink and glued at both ends (where it meets the rear panel as well as the PCB), in order to minimize air leakage and potential air noise when playing loud bass notes.
          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          • MisterD
            • Oct 2012
            • 668
            When you say the connector is covered with some heatshrink are you referring to the very front of the jack connectors where the XLR or 1/4" plug goes into the jack? One of these speakers had something like that and the other one didn't, but my Nephew took these to Guitar Center to try to sell them and they somehow pulled off one of the heatshrink covers and then said it wasn't there to begin with and then didn't want to purchase the Speakers because of exposed metal contacts but these brand new replacment connectors here on ebay have the same exposed metal contacts that can be seen here...https://www.ebay.com/itm/10-Neutrik-...k/262764276052
            • Khron
              • Sep 2006
              • 1350
              • Finland
              No, I meant between the metal rear panel (where everything else is bolted to), and the surface of the small PCB the input combo-connector and the volume potentiometer are soldered onto. I'll snap a couple photos when I get home tonight.
              • Khron
                • Sep 2006
                • 1350
                • Finland
                Full disclosure - might've slightly mis-spoke there. At least on my pair, the connectors are actually "New Tide" branded (have fun finding out / figuring out the part number), but they are regardless PCB-mount and vertical (not solder-cup terminated as in the earlier eBay link).
                As mentioned though, as opposed to the Neutrik options, these do seem to have two extra mechanical-reinforcement pins that are connected to ground.
                See attached photos regarding the heatshrink+glue treatment.
                  by momaka
                  03-15-2023, 10:17 PM
                • wattage
                  AOC AG493UCX 49-inch monitor - Firmware request
                  by wattage
                  Hello Badcaps Community,
                  The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                  07-13-2025, 04:41 PM
                • ant3202
                  HP 27es - LED monitor - Monitor Flashing On - Off
                  by ant3202
                  Hi Everyone
                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                  https://www.badcaps.net/forum/troubl...lashing-on-off
                  The monitor is HP 27es LED Monitor
                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                  The monitor will randomly blackout and display no signal and will recover again.
                  Sometimes need to power and off again to restore the display but...
                  03-20-2025, 07:30 PM
                • Rick_1234
                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                  by Rick_1234
                  Good evening, gentlemen.
                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                  Things I tried
                  - Bought a new AC adapter thinking that was the problem but the problem...
                  06-22-2024, 04:44 PM
                  Wise Wing F199 19'' LCD monitor - recapped
                  by momaka
                  Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                  I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                  When I saw the Craigslist post, I wasn't...
                  08-24-2020, 10:58 AM
