need help to know what is the ohm of this switch
  • tonytiger
    • Jan 2010
    • 163
    • canada
    hi,guys.
    this is a volume pot inside of a tc-helicon voicelive touch 2....'ve been trying to find a diagram but did not have any luck....and nobody can tell me what switch i need to replace the original one....so far i tryed a P110KV1-1F15BR100K(100 ohm)
    from digi-key and i need to put it at 3/4 before starting to have volume.... there is no other numbers on this switch other that the one you see on top...can someone tell me what im missing or what other switch i could try.thank you.
  • Offscreen6
    • Jan 2021
    • 22
    Re: need help to know what is the ohm of this switch
    You can probably find the ohms by using a multimeter.
    Other than that, you could find a new switch by looking up the specific device the volume pot goes to on a replacement parts site.
    • R_J
      • 9594
      Check the resistance across the two outside connections, then measure the size of the control and shaft, It looks like a 8mm or 10mm pot. If the pot directly controls the audio signal you will need a audio taper pot.
      The pot P110KV1-1F15BR100K is a 100KΩ not 100Ω
      • Khron
        • Sep 2006
        • 1350
        • Finland
        Those markings look a lot like "SHC2K". "SH" might have something to do with the series or brand, but "C2K" would indicate a C-taper (reverse-logarithmic, anti-logarithmic) 2Kohm potentiometer.
        C-taper pots are often used in the gain adjust of mic preamps.
        Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
        • dentheman2
          • Mar 2021
          • 7
          • Netherlands
          hi Tony,
          find out anything?
          Mine is busted as well (girl I bought it from did not mention it, thought I had a software glitch), year later aI opened it up, completely busted...
          • dentheman2
            • Mar 2021
            • 7
            • Netherlands
            I put in a request at Music Tribe to see if they have a spare.
            • Khron
              • Sep 2006
              • 1350
              • Finland
              Good luck with that
              In the mean time...
              https://www.mouser.fi/ProductDetail/...FQw94NWw%3D%3D
              • dentheman2
                • Mar 2021
                • 7
                • Netherlands
                That is the one that works?!
                As in you got it working?
                Cause I wil order it right now!
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  Also, see if the pinout matches the one in the datasheet for the potentiometer i linked. I can't see in the photos you posted, if yours has 3 or 4 pins, even.
                  The one i linked is a 2Kohm reverse-audio / reverse-logarithmic / anti-logarithmic taper / C-taper potentiometer, which should(?) match the one that seems to be faulty in your unit. So it should work, as long as you can confirm the end-to-end resistance in yours is indeed 2Kohm, and compare the dimensions with the drawings in the datasheet.
                  I never "got it working", because i don't think i've ever touched or even seen with my own eyes a VoiceLive Touch 2.
                  • dentheman2
                    • Mar 2021
                    • 7
                    • Netherlands
                    it has 4 pins.
                    it is hard to test since the pot is broken through though.
                    • dentheman2
                      • Mar 2021
                      • 7
                      • Netherlands
                      @Khron,
                      I thought you were the original poster so I mistakenly thought you fixed your machine, sorry for that
                      In the specs on mouser I see that the pot is 10K, is that a problem?
                      • Khron
                        • Sep 2006
                        • 1350
                        • Finland
                        I'm going to guess the potentiometer (if you can look at the bottom of the board) has two of the active pins connected together, so in essence, wired as a variable resistor. The big fat electrolytic next to it would be indicative of this being the analog gain adjustment of the mic preamp.
                        In that context, you could very well use a 10K pot, and solder in a resistor (say, 3.3k or so) in parallel with it.
                        • dentheman2
                          • Mar 2021
                          • 7
                          • Netherlands
                          thanks, made some new pics that confirm your suspicions.
                          btw left two pins are not connected, think it was some dust in the pic.
                          pin 3,4 are connected.
                          the 3.3K resistor to which pins do i solder that?
                          • Khron
                            • Sep 2006
                            • 1350
                            • Finland
                            https://cdn.badcaps-static.com/pdfs/...106059987c.pdf
                            "Electrical diagrams", first one, PTV111. As you can see, pin 4 (as seen from the front) is "dummy". Your "pin 3,4" are pins 1 and 2 in the datasheet.
                            • dentheman2
                              • Mar 2021
                              • 7
                              • Netherlands
                              ok thanks!
                              • Khron
                                • Sep 2006
                                • 1350
                                • Finland
                                No problem, good luck with the repair!
                                  Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                  This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  09-06-2024, 05:30 AM
                                • Natob82
                                  Micro Momentary Push Switch?
                                  by Natob82
                                  Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                  12-21-2022, 05:22 AM
                                • grimacelord
                                  NEC TurboExpress On/Off Power Switch Replacement Help
                                  by grimacelord
                                  I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                  I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                  I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                  11-09-2023, 09:49 AM
                                • SluggerB
                                  Help making a switch work the opposite way with a relay
                                  by SluggerB
                                  I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                  I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                  It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                  02-07-2025, 07:57 PM
                                • karthur
                                  Vizio D65x-G4 Volume changes on its own
                                  by karthur
                                  On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                  It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                  06-05-2025, 08:13 AM
