Db Technologies Cromo 12 amplifier no audio
  • falcontech
    • Oct 2013
    • 484
    • italy
    Re: Db Technologies Cromo 12 amplifier no audio
    woofer and tweeter
      So right now either one of them are working?
      That shorted out filter cap should not affect the operation of the unit once it is removed.
      • falcontech
        • Oct 2013
        • 484
        • italy
        tomorrow I will try to solder the capacitors to understand what happens, I keep you updated, I preferred to do the tests you asked me to avoid burning the power amp as I ordered it from china and I had to wait 2 weeks before receiving it, let me know also how should I behave with the inductors if you think they are okay or I have to replace them
          At this point those inductor for the outputs will not stop the unit from working.
          • falcontech
            • Oct 2013
            • 484
            • italy
            ok I'll update you tomorrow
            • falcontech
              • Oct 2013
              • 484
              • italy
              #26
              I mounted the capacitors but still no sound output from the woofer or the tweeter
              • falcontech
                • Oct 2013
                • 484
                • italy
                #27
                how can i proceed now?
                • falcontech
                  • Oct 2013
                  • 484
                  • italy
                  #28
                  I also noticed that the final of the tweeter (the innermost one) warms up much more than that of the woofer (the outer one)
                    Since you are not getting the sound form Tweeter or the Woofer, then it is probably something that is common to both amplifiers, such as that both of them are in Mute mode, or the audio signal form input is not getting all the way to the amplifiers.
                    This is not going to be easy fix. Do you have working board to do Voltage comparison testing?
                    Do you have audio signal tracer or scope to trace out the audio path from input all the way to the output sections?
                    • falcontech
                      • Oct 2013
                      • 484
                      • italy
                      #30
                      unfortunately I don't have an oscilloscope but I have the same amplifier so I could do some tests if you tell me what to do
                        https://cdn.badcaps-static.com/pdfs/...6bfeac6d82.pdf
                        Look at page 22 then check the Voltage at the Mode pin 23 of the working unit and the not-working unit.
                        • falcontech
                          • Oct 2013
                          • 484
                          • italy
                          #32
                          in the TDA8950TH the pin mode controll is number 6 but I didn't understand what I need to test, if you could explain me in practice thanks
                          • falcontech
                            • Oct 2013
                            • 484
                            • italy
                            #33
                            what voltage should i have?
                              Sorry, my typo, it is pin #6.
                              Just put Black probe on ground, red probe on pin 6 of the working unit and non-working unit and see if they are about the same Voltage.
                              Page 6 and 7 of the spec sheet shows you what the Voltage of each mode should be.
                              • falcontech
                                • Oct 2013
                                • 484
                                • italy
                                #35
                                ok tomorrow I'll do this test, now it's night here, the unit is equipped with an analog / digital converter, could that have some problem? or the operational amplifiers? however we take it one step at a time
                                • falcontech
                                  • Oct 2013
                                  • 484
                                  • italy
                                  #36
                                  I checked the voltages of pin N ° 6 and both on the non-working amplifier and on the working one I have a voltage of 49.5 +/- volts
                                    Are you sue you are using the correct circuit ground? Are you sure you are on the right pin?
                                    I also do not understand 49.5 +/- Volts? +49.5V? -49.5V?
                                    Pin 6 Mode pin works on 5V level.
                                    • falcontech
                                      • Oct 2013
                                      • 484
                                      • italy
                                      #38
                                      for +/- I meant more or less because the value ranged from 49.3 to 49.5 il pinera undoubtedly the number 6
                                      • falcontech
                                        • Oct 2013
                                        • 484
                                        • italy
                                        #39
                                        I used ground circled in red
                                        • falcontech
                                          • Oct 2013
                                          • 484
                                          • italy
                                          #40
                                          tomorrow I will do the test again, I would not like that I have set the tester wrong
                                          • samson7point1@yahoo.com
                                            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                            by samson7point1@yahoo.com
                                            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                            The player processes the audio signal using two different reference frequencies. The "R"...
                                            04-30-2024, 11:22 AM
                                          • silver60618
                                            Macbook M3 A2991 Speaker Audio Amplifier IC
                                            by silver60618
                                            Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
                                            I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
                                            09-26-2025, 12:25 PM
                                          • eccerr0r
                                            Frying amplifier finals... audio, not rf...
                                            by eccerr0r
                                            Well for RF transmitters, transmitting without an impedance matched antenna and if the transmitter doesn't have automatic limiting... kiss the final transistor goodbye and chalk one up to something you killed.
                                            But that's not the same way with audio amps for the most part, well, at least the wavelength of audio on copper is so long that you get all of it back anyway but the transistor is fine with it...
                                            So how are people destroying finals in their audio amplifiers then? Heh.
                                            Are people shorting their outputs or something, overdriving output to a too big speaker?...
                                            11-27-2021, 12:30 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                          • MrCommunistGen
                                            Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                            by MrCommunistGen
                                            My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                            I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                            07-12-2021, 05:11 PM
