Sony STR-DE697 - Bad Transformer. Replacement? Unknown Value!
  • JDC
    • May 2015
    • 273
    Got a Sony STR-DE697 with a bad power transformer (1-435-281-11). This will be my second receiver with a bad transformer; the first I was able to find a direct replacement off ebay. With this one, nothing has been found except for an old ebay listing for the sub board itself.
    Tried to find a service manual to determine the transformer's specs but to no avail. Tried similar models with the same model transformer but no go.
    So....
    1) How does one determine a transformer's specs (input, output) if there is no information about it available? Are there clues on the board itself?
    2) Is this one of those "Don't waste your time, kid." moments?
    I appreciate any and all responses.
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Sony STR-DE697 - Bad Transformer. Replacement? Unknown Value!
    standby transfor is it ?
    9v after rectification ... i am not very good at working out the AC. will be less than 9v is all i know .
    • R_J
      • 9550
      2 seconds on google & I have the service manual, A transformer with 6.3vac will give you the 9vdc you need. It is likely there is a primary thermal fuse that is open.
      • JDC
        • May 2015
        • 273
        I must have mixed up this model with another one I'm fooling around with. No wonder I couldn't find the manual. Thanks.
        Can you (or anyone else) recommend a replacement transformer? Would this be appropriate?
        https://www.ebay.com/itm/PHILMORE-TR...MAAOSwjrFb-Yzg
        • Khron
          • Sep 2006
          • 1350
          • Finland
          How did you determine the transformer is bad, though?
          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
          • JDC
            • May 2015
            • 273
            No relay click or standby light was my first clue. Relay tested fine.
            Primary side of transformer has 3 poles, measured OL on all of them. I know this isn't the best way to test these things but it's good enough for me.
            Even if I'm wrong, I'd like to learn how to tell what is needed for a replacement if a direct replacement isn't available. I'm missing something simple, I just know it.
            For those of you following along at home, attached is the schematic for this stereo.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Well, given that it is used for standby function, it probably doesn't have to output a whole lot of power. So likely you'll just have to find a 6.5V VAC transformer (since you want to get 9V DC) capable of probably at least 200-300 mA to be on the safe side. If space allows, maybe get one capable of at least 500 mA to be safer. Actually, on that note, the output current on the new transformer may not always be mentioned. Instead, you may just see a voltage and VA (Volt-Amps) rating. For the volts, make sure to get one that also matches your primary-side requirements - i.e. 115V if you're in North America or any place with 115V AC lines, and 230V if you're in Europe and most of Asia and Africa. As for the VA rating: that's basically a power rating. In simple terms, it's similar to Watts, but basically a bit more "inflated". So if the transformer is rated for let's say 6V output and 9 VA, the expected maximum output current possible should be somewhat less than 9 VA / 6V = 1.5 Amps (it can vary, based on how inductive or capacitative the load is.)
              All that aside, before you even go looking for a replacement original transformer, try seeing if you can fix the old one. Sometimes, these line AC transformers will have a thermal fuse inside. If you remove/break away some of the plastic tape and cover over the blue side, you may find a square box fuse in there. If you do, check it. If it's open, try replacing it with same or slightly lower-rated fuse and see if traffo works again.
                • 31051
                also look where the windings are wrapped and soldered to the pins - they can break there because it's a weakpoint.
                • JDC
                  • May 2015
                  • 273
                  Thank you for this info. It helps.
                  I ended up buying this: https://www.ebay.com/itm/PHILMORE-TR...72.m2749.l2649
                  Attached is a picture of it. Used the two black for the primary, one red and one green for the secondary. Did I do that right? Tested by itself, output is around 8VAC. Too high? I can see why this should have worked but it didn't!
                  On a related note, I'm willing pay someone what I can to help me with this. I realize this is a public forum and posts are for everyone's benefit, but if I have to sweeten to pot (so to speak) to increase motivation, I'm willing to. I don't care to sell this thing nor keep it. I just want to learn. If interested, PM me.
                  I'm thankful for everyone's help so far.
                  • R_J
                    • 9550
                    Yes you did it right, the a/c voltage may read a bit higher without any load, once installed it should be ok and the dc voltage should be close to the 9v required.
                    • JDC
                      • May 2015
                      • 273
                      I'm still not getting 9V standby though. Obviously I missed something. I'll keep digging. Thanks for the confirmation, RJ!
                      • Khron
                        • Sep 2006
                        • 1350
                        • Finland
                        Is C950 (3300u / 16v) ok? Still no 9V standby even with the digital board disconnected?
                        • R_J
                          • 9550
                          Like khron said, disconnect CNP903 going to the digital board, If C950 is bad as in open, you should still get some standby voltage, check that there is not a short across C950.
                          • JDC
                            • May 2015
                            • 273
                            SUCCESS! The cap was fine. Apparently a ribbon cable worked itself loose from the a board (digital board?). I started at the power button and worked my way back and there it was. She turns on now. Man, that was fun! Thank you all for the help!
                            But i'm still in the dark about how 9VDC can come from 6.3VAC. If there is a link I can read, please post it. I realize I don't know everything I should but I learned a lot about transformers with this one.
                              • 31051
                              6.3v is the average of the sinewave,
                              when you convert it to dc and use a capacitor to hold the voltage up during the low points in the wave, you get peak voltage.
                              peak voltage is roughly the ac voltage x1.4
                              keep that in mind if you work on rectified mains!!
                                • 31051
                                https://www.youtube.com/watch?v=n2iPFZWe7uk
                                the Iranian master will explain
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  Congrats on the repair!
                                  • the_rem
                                    Unknown transformer : how to find a good replacement part ?
                                    by the_rem
                                    Hello guys,
                                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                    04-23-2025, 01:48 AM
                                  • unimatrix93
                                    Replacement transformer for Samsung fridge
                                    by unimatrix93
                                    Dear forum
                                    My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                    No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                    The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                    My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                    07-14-2025, 02:16 AM
                                  • lti
                                    Sony MDR-IF245R transmitter LED replacement
                                    by lti
                                    I'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
                                    06-28-2024, 01:47 PM
                                  • double_DD
                                    Transformer replacement for a dead coffee machine
                                    by double_DD
                                    Hi guys,
                                    I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
                                    Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
                                    If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
                                    My other ideas:
                                    - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
                                    - to buy...
                                    06-23-2025, 05:43 AM
                                  • timonix20
                                    Looking for eMMC Replacement for Sony LG 60la620s EAX64797004 (1.1) with Boot Issue
                                    by timonix20
                                    hello everyone I am looking for a solution for my tv, I think corruption of the eemc,
                                    the TV starts, LG logo, then nothing (rear backlight)
                                    no reaction to rear command or infrared
                                    the usb procedure that I tried on the LG site is a procedure with the screen and the remote control so I can't.
                                    I have a chance with a usb procedure or other if you have .bin
                                    if any people have this main board
                                    thank you...
                                    04-23-2024, 01:52 PM
