Help diagnosing JBL Live 400BT headphones that do not power on
  • SluggerB
    • Aug 2020
    • 747
    • US
    After the successful receiver fix, my friend asked if I could look at his headphones. They are JBL LIVE 400BT headphones. They appear to have no power. I took them apart, here are the photos.
    The charging board where the micro USB charger plugs into
    Main board where the power switch and other buttons are
    The other side of that board
    First I plugged it in, and I was getting 4.2V from the USB connector. I checked the battery terminals and they were getting 4.2V as well. After some time I unplugged the USB connector, and the batter was still reading 4.2 volts, so the battery looks to be charging and good. During this charging time, none of the LED's lit up and the device does not turn on.
    I checked the wires connecting the smaller charging board with the main board for continuity. All the wires checked out, so it's not a break in a wire anywhere.
    I checked for voltage on the main board between VBAT and GND, and was getting 4.17 volts. I checked VBAT to the far side of that row of components and all but one of them showed around 4 volts, one was around 2 volts, I can't recall which one.
    I checked voltage to the pads that were near the power switch, all showed 4.17 volts. Throughout all the testing the headphones showed no life whatsoever.
    Any tips on what components to check? I wouldn't think I could be reading power all over the place yet the device would be absolutely dead. I'm not seeing traces where I would usually suspect so it's hard to "follow the voltage" and see whats going where
  • petehall347
    • Jan 2015
    • 4440
    Re: Help diagnosing JBL Live 400BT headphones that do not power on
    bit of history might help here ..like did they suddenly die . or what happened between them working and not working . as far as i remember usb is 5.3v .
    • SluggerB
      • Aug 2020
      • 747
      • US
      They were his sons, and he said one day the headsets came up in conversation and his son said they had just stopped working a while back. So unfortunately no real history.
      I checked the battery label and it says it outputs 4.2V so I think the voltage is good.
      One thing I also noticed was that when I put my multi meter on diode test and touched the ends of the LEDs, none of them lit up. I don't know what that would indicate.
        How about:
        VIO
        VCHG
        CHRGB
        VANA
        • SluggerB
          • Aug 2020
          • 747
          • US
          Originally posted by budm
          How about:
          VIO
          VCHG
          CHRGB
          VANA
          VBAT to:
          VIO: 4.08V
          VCHG: 4.12
          CHRGB: 3.8
          VANA: 4.12
          The little component right below VBAT isn't giving me any reading. No voltage to it, no resistance, dioide check shows nothing. I removed it from the board and checked it out of circuit, same think, just OL everything I check. I don't know what it is.
          The chip on the daughter board reads
          D5508
          8NF1
          The chip with the legs on the motherboard reads
          Chipstar
          CS4420C
          B131
          The BGA chip in the mother board reads
          BES
          HES2000
          18450015
          CF844510
          M102 001
          Those are the best I could get the writing is very small
          I am guessing it is a chip since everything seems to be getting power. I am still confused why the LEDs are not lighting up on diode test though
            Originally posted by SluggerB
            VBAT to:
            VIO: 4.08V
            VCHG: 4.12
            CHRGB: 3.8
            VANA: 4.12
            D5508
            8NF1
            Chipstar
            CS4420C
            B131
            BES
            HES2000
            18450015
            CF844510
            M102 001
            Are you saying you use VBAT as ground ref. for your measurement?
            You need to use Ground as ground ref. for the meter.
            • SluggerB
              • Aug 2020
              • 747
              • US
              Red probe on VBAT, black probe on those various points
              It looks like the daughter board chip is a wireless chip, the motherboard chip with the legs is an amplifier chip, and the BGA motherboard chip is some sort of audio system on chip
                You need to use Ground point for ref for making Voltage measurement since circuit is ref. to Ground, same way as you test the Voltage on the amplifier that we just fixed.
                • SluggerB
                  • Aug 2020
                  • 747
                  • US
                  Wow I feel stupid. I'll go back and recheck all those
                  • SluggerB
                    • Aug 2020
                    • 747
                    • US
                    Black Probe on GND, Red Probe on:
                    Touch - 9.6 mV
                    VIO - 10 mV and fell quickly to about 0.5mV
                    CHGCB - 5.1v
                    VBAT - 4.7v
                    LED+ - 60 mV
                    Mic3+, Mic3-, SpkL- & SpkL+ were all 0 but I have them all desoldered from the board, I had to remove them to flip the board around
                    DM - 0V
                    DP - 0V
                    • SluggerB
                      • Aug 2020
                      • 747
                      • US
                      I think I'm going to abandon this one. I"m following the voltage and I keep getting to components that aren't identified. They look like SMD capacitors, but they test OL for resistance, OL for diode test, and no voltage goes through them. The board doesn't have visible traces and nothing is marked it has anything written to tell that these components are so I have no idea what to replace them with. JBL will not provide a schematic.
                      Oh well at least I got some more soldering and hot air experience in.
                        Where is the power switch?
                        • SluggerB
                          • Aug 2020
                          • 747
                          • US
                          See the picture with the bottom of the motherboard, with the "400" and "500" on it? The bottom of the board shows the switch
                          There are several areas on the board with 2 solder pads, and a white square drawn around them, but no component in place. Is that normal, or should there be components there? Maybe the headphones were dropped and some of the components broke off? I looked around in the housing but didn't see anything loose, but they are tiny and could have fallen out earlier.
                            So the 'Blue' and 'White' LEDs are right next to the power switch, correct?
                            How many pins are there on the switch? 2, 3?
                            • SluggerB
                              • Aug 2020
                              • 747
                              • US
                              Correct.
                              The switch has 3 pins. I confirmed with a continuity check on those three pins that the switch is working correctly. When the switch is off pin 1 & 2 have continuity with each other and pin 3 does not have continuity with anything. When the switch is on pin 2 & 3 have continuity with each other and pin 3 does not have continuity with anything.
                                Correct.
                                So check the Voltage between GND and each pin of the power switch when it is set to off and when it is set to on.
                                • SluggerB
                                  • Aug 2020
                                  • 747
                                  • US
                                  There is no voltage getting to the switch. I also cannot get any voltage to VIO. I desoldered the chips on the motherboard and some of those legs WERE getting power with chip off, but with the chip back on, the voltage went away, which I would suspect means one of the chips is bad? I'm not going to hunt down new chips to replace them though since it could be any of the other components on the board and nothing is labeled or marked so I don't know the ratings of any of the SMD components and JBL does not provide schematics.
                                  I'll just toss them in a box and maybe steal the earpiece speakers for something in the future.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    Yeah, I was just going to add here... if the headphones are otherwise nice (comfortable and have nice drivers in them), maybe just get a female 3.5 mm audio jack and also a long 3.5 to 3.5 mm cable, then put the female jack in one of the ear pieces and basically convert these headphones to wired. Not an ideal solution, perhaps, but I figured I'd throw the idea out there.
                                    In regards to troubleshooting these headphones, since they are a portable device and subject to shocks, I suggest checking every SMD ceramic cap for short-circuit or low-resistance (and if you find one, remove and check out of circuit), because SMD ceramic caps have a tendency to crack from vibration and shocks - even the tiny ones. Aside from that, also check for open resistors, though that will be harder to do in-circuit. You may also have to desolder the battery to do these checks, as it may give false readings.
                                    • SluggerB
                                      • Aug 2020
                                      • 747
                                      • US
                                      Even if I found a bad component, nothing is marked, nothing is labeled, and none of the components have any identifying characteristics on them, and JBL wouldn't provide a schematic, so I would have no idea what to replace anything with. I poked around with it some more but nothing was making much sense, and you couldn't see the traces on the board for where things were going, so I just used it for hot air station practice taking things off and putting them back on. I did remove the drivers and set them aside in case I have a need for some in the future.
                                      Can't fix them all, after this I am 2 out of 3 for headphones.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        In some cases, you can get away without a schematic of the device if you look up the datasheet of the ICs and see if they have an application circuit in there. Usually, the circuit in the device will closely resemble the application circuit.
                                        Of course, I totally understand why you're not going after the repair. It would be complicated and probably very time-consuming - hardly worth the effort, even if these were very expensive headphones. Basically, you'd have to figure out what most of the components do... and that may be possible only if you do happen to find a datasheet for the ICs, and if there is an application circuit in there, and if that application circuit resembles your circuit... basically, a lot of IFs and a lot of tracing to figure what component connects to which IC and what it does. JBL definitely didn't intend for anyone to repair these on the component level. Heck, probably even they themselves don't. For warranty, they most likely have "techs" (component swappers) replace the boards and call it done.
                                        That aside, a quick check on the ceramic caps for short-circuit is probably what I would have done before chucking the boards. Before I got my various meters and test equipment, I actually fixed a good amount of devices (mostly LCD monitors) with shorted SMD ceramic caps. I didn't know what value to use, because I didn't have a schematic or a cap meter at the time. But I simply "winged it" and replaced the shorted ceramic caps with ones of same/similar size and if possible, coming out of a similar circuit. Didn't have a case where that didn't work... though there is certainly a bit of luck involved there.
                                        Anyways....
                                        BTW, I'm curious about the size of the drivers in these headphones. 40 mm? 50 mm?
                                          RCA WHP141 wireless headphones wired up
                                          by momaka
                                          OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
                                          Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
                                          As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
                                          02-22-2023, 06:28 PM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • u666sa
                                          HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                                          by u666sa
                                          Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                                          Platform: ipa32 la-m024p rev 1b
                                          Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                                          I found a short on the other side:
                                          10-04-2025, 05:03 PM
                                        • Loretto
                                          Samsung SMPS BN44-00339A
                                          by Loretto
                                          this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                                          I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                                          I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                                          I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                                          03-29-2025, 08:30 AM
                                        • Loretto
                                          by Loretto
                                          03-28-2025, 10:28 AM
