Re: Strange malfunctioning LED audio peak level meter problem
Ok. I'm probably going to relocate this board and run jumper wires from it to individual wired-led's mounted into the plastic housing that mounts to the cassette player's face.
My understanding is that 1 signal goes to one side (let's called it "+" side) of the 1st, 4th, 7th, and 10th led's of both top and bottom rows. Now the other side (let's call it "-" side) of the 1st led goes to the + side of 2nd led. The - side of 2nd led goes to + side of 3rd led. The - side of 3rd led goes back to the IC. This same scenario is repeated for all the groups of 3 led's. There are 4 sets of 3 led groups on each row.
Can someone recommend wired-led's? I'll need some green, amber/yellow and red. They should fit into the plastic housing.
You can test each LED as suggested, and also use high power magnifying glass each bonding wire of the LED.
I also see strange trace layouts.
I am also surprised that exposed bonding and die last this long, but since they cannot put black blob on top like they did for the IC since they are LED, they could have put on clear sealer instead on the LED's.Attached Filesif you find these attachements useful please consider making a small donation to the site
you cant fix them, you have to scrape them off the pads and solder tiny smd ledsLeave a comment:
PicAttached Filesif you find these attachements useful please consider making a small donation to the site
picsAttached Filesif you find these attachements useful please consider making a small donation to the site
So I can see the microscopic wires and pads dislodged from the led's. Thanks! Now...how to reaffix them? Its insanely small.Leave a comment:
Veho Discovery vms-004 usb microscope
Worked years ago on old laptop I had. Windows 10 doesn't have a driverLast edited by JimBanville; 08-12-2020, 09:38 AM.Leave a comment:
so what computer are you using now?
i cant believe you cam a HID/cam device that wont just work in Linux or other windows versions.
the wires are bond leads made of gold and welded at each end.Leave a comment:
Thanks. The more I look at it, the micro sized led's would be beyond my capabilities. Still looking for an old windows 7 pc to use my microscope. Lol
From what I can see with limited magnification it appears that there are tiny single strand wires coming off of the leds!!Leave a comment:
well you probably need to replace the lot - so the brightness matches
i would be tempted to build a new one possibly using a chinese vu meter module as a base and making a new led board to match the original spacings.Last edited by stj; 08-12-2020, 07:34 AM.Leave a comment:
The led's are the size of a grain of salt. I touched a couple and they went out too. I'm going to have to find an old computer running windows 7 so I can use the only usb microscope I have (Veho Discovery VMS004).Leave a comment:
you can use the testpoints either with another led or a multimeter on diode-testLeave a comment:
Cover came off easily after I used a razor blade to slice the white plastic tabs off the back.Attached Filesif you find these attachements useful please consider making a small donation to the site
Did you try flexing the board while power up with signal so you can see flexing will cause the LED's to come and go?
https://www.badcaps.net/forum/attach...3&d=1597194394
Those white plastic dots look to holding the LED assembly to make contact with the PCB.
I tried flexing it. No joy.Leave a comment:
https://www.badcaps.net/forum/attach...1&d=1597194394
I wonder what you will see if you look straight from the side view.Last edited by budm; 08-11-2020, 11:07 PM.Leave a comment:
What I have done when desperate to repair vintage gear is VERY CAREFULLY remove the LED diffuser assembly to access the naked LED's on the PC board. This means cutting/remelting or removing the six plastic pins and pulling off the LED diffuser straight up. If you slide it sideways it will kill all LED's by shearing off the bonding wires. I expect raw LED dies on the PC board with a tiny bonding wire.
You could also just carefully peel off the diffuser overlay to see what's inside.
I would solder in 0603 LED's to replace the defective ones.
edit: to get troubleshoot kind of displays to work in the shop we used freeze spray drops on an LED. I think they get a bad connection to the die, the bonding wire doesn't quite work.Last edited by redwire; 08-11-2020, 10:23 PM.Leave a comment:
Those white plastic dots look to holding the LED assembly to make contact with the PCB.Leave a comment:
So what do u think I should do next? IC problem? Dead LED's? Bad led connections?Leave a comment:
Yep, one of those encapsulated (Black blob) IC on PCB.
It looks like the LED's pins are mated to the PCB using pressure to make contact with the PCB pads.
If you flex the board you may see the LED come and go.Leave a comment:
by chth96I read EBOOK of Testing Electronic Component and found that
"In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
Is it really possible to test small ceramic disc capacitor with analogue...-
Channel: General Capacitor Questions & Issues
by PipolupsHi there !
I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...š
Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me š...10-08-2024, 11:58 AM -
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by jorpecHi
I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
I wonder how i can accomplish this so the meter would be precise at any temperature ?
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the āEā stops and one switching power (24 volt) supply and a transformer... - Loading...
